查看: 6413|回复: 3
校准触摸屏
35
115
115
2013-11-22
发表于 2013-12-27 14:40:47 | 显示全部楼层 |阅读模式
我网上下的一个程序,先触摸校准,就是在屏的左下角和右上角分别画两个圆环,点击校准。一楼是程序。先是左下角出一个圆环,点击能退出第一个do WHILE的循环,继续往下执行,显出“OK”,进入第二个do WHILE的循环,只有释放触摸屏才能跳出第二个do WHILE的循环,从而画第二个右上角的圆环。但是,我在板子上实验,发现就算一直按着触摸屏,依然能够跳出第二个do WHILE的循环。不知道到底为什么。求大神分析。
35
115
115
2013-11-22
 楼主| 发表于 2013-12-27 14:41:09 | 显示全部楼层
void _ExecCalibration(void) {
  int ax_Phys[2],ay_Phys[2];
/* calculate log. ositions */
  int ax[2] = { 15, LCD_XSIZE -1-15};
  int ay[2] = { LCD_YSIZE-1-15, 15};
  CalibrationComplete = 0;
  GUI_TOUCH_SetDefaultCalibration();
  GUI_SetBkColor(GUI_BLUE);
  GUI_Clear();
  GUI_SetColor(GUI_WHITE);  GUI_FillCircle(ax[0], ay[0], 10);
  GUI_SetColor(GUI_RED);    GUI_FillCircle(ax[0], ay[0], 5);
  GUI_DispStringAt("Press here", ax[0]+20, ay[0]);
  do {
    GUI_PID_STATE State;
    GUI_TOUCH_GetState(&State);
    if (State.Pressed) {
      ax_Phys[0] = GUI_TOUCH_GetxPhys();
      ay_Phys[0] = GUI_TOUCH_GetyPhys();
      break;
    GUI_Delay (100);
  } while (1);
/* Tell user to release */
  GUI_Clear();
  GUI_DispStringAt("OK", ax[0]+20, ay[0]);//告诉别人可以放开
  do {
    if (State.Pressed == 0) {
      break;
    GUI_Delay (100);
  } while (1);//放开才继续往下执行
/* _Calibrate lower right */
  GUI_Clear();
  GUI_SetColor(GUI_WHITE);  GUI_FillCircle(ax[1], ay[1], 10);
  GUI_SetColor(GUI_RED);    GUI_FillCircle(ax[1], ay[1], 5);
  GUI_SetTextAlign(GUI_TA_RIGHT);
  GUI_DispStringAt("Press here", ax[1]-20, ay[1]);
  do {
      ax_Phys[1] = GUI_TOUCH_GetxPhys();
      ay_Phys[1] = GUI_TOUCH_GetyPhys();
      break;
    GUI_Delay (100);
  } while (1);
  GUI_TOUCH_Calibrate(GUI_COORD_X, ax[0], ax[1], ax_Phys[0], ax_Phys[1]);
  GUI_TOUCH_Calibrate(GUI_COORD_Y, ay[0], ay[1], ay_Phys[0], ay_Phys[1]);
  { /* calculate and display values for configuration file */
    int x0, x1;
    int y0, y1;
    GUI_Clear();
    _Calibrate(GUI_COORD_X, ax[0], ax[1], ax_Phys[0], ax_Phys[1], &x0, &x1);
    _Calibrate(GUI_COORD_Y, ay[0], ay[1], ay_Phys[0], ay_Phys[1], &y0, &y1);
    GUI_DispStringAt("x0: ", 0, 0); GUI_DispDec(x0, 4); GUI_DispNextLine();
    GUI_DispString  ("x1: ");       GUI_DispDec(x1, 4); GUI_DispNextLine();
    GUI_DispString  ("y0: ");       GUI_DispDec(y0, 4); GUI_DispNextLine();
    GUI_DispString  ("y1: ");       GUI_DispDec(y1, 4); GUI_DispNextLine();
    GUI_DispString  ("Please touch display to continue...");
    GUI_Delay(1000);
    do {
      if (State.Pressed)
        break;
      GUI_Delay (10);
    } while (1);
GUI_Clear();
165779
165779
发表于 2013-12-27 22:34:13 | 显示全部楼层
跟踪进去这个函数GUI_TOUCH_GetState看看究竟。
50
50
2016-4-19
发表于 2016-5-6 11:20:32 | 显示全部楼层
GMT+8, 2026-10-28 20:48
