查看: 10711|回复: 3
stm8s timer1 死区设置为什么 没有出现死区反而 oc1和oc1n的输出高脉冲头重叠增加了?求大神解答
117
117
2014-1-12
发表于 2014-1-12 20:14:05 | 显示全部楼层 |阅读模式
/* MAIN.C file
 * Copyright (c) 2002-2005 STMicroelectronics
#include "stm8s207c.h" // 声明中断服务函数
_Bool ZKBJ @PD_IDR:4;
_Bool ZKBQ @PB_IDR:7;
_Bool ZZ   @PB_ODR:6;
_Bool LED  @PC_ODR:3;
_Bool LED1 @PC_ODR:4;
/* 函数声明----------------------------------------------------------------------*/
/* TIM1_PWM初始化 */
void TIM1_PWM_init(void);
void CLK_Init(void);
void GPIO_Init(void);
void SCZWH_Init(void);
void SCZWL_Init(void);
void SCZWH_Int(void);
void SCZWL_Int(void);
void DELAY (unsigned int x);
//void EXTI0_Init(void);
//void EXTI3_Init(void);
void main(void)
      _asm("sim");
 GPIO_Init();
     CLK_Init();
_asm("rim");
        TIM1_PWM_init();
        while(1);
* 函数功能: TIM1_PWM初始化
* 参数: 无
* 返回值: 无
void CLK_Init(void)
 CLK_SWR = 0xB4;
while(!(CLK_SWCR&0x08));
CLK_SWCR |=0x02;
while(CLK_CMSR!=0xB4);
CLK_CSSR |=0x01;
 CLK_CKDIVR = 0x00;
CLK_PCKENR1 = 0x80;
PB_DDR = 0x03;
PB_CR1 = 0x0F;
//PB_CR2 |= 0x03;
PC_DDR |= 0x06;
PC_DDR |= 0X18;
PC_CR1 |= 0X18;
PC_CR1 |= 0x06;
PC_CR2 |= 0x06;
PC_CR1 |= 0x08;
PC_CR2 |= 0x00;
        TIM1_ARRH = 0x00;        // 计数周期
        TIM1_ARRL = 0x20;
        TIM1_CCR1H = 0x00;        // TIM1比较/捕获寄存器1
        TIM1_CCR1L = 0x0b;
TIM1_CCR2H = 0x00;
TIM1_CCR2L = 0x0b;
        TIM1_PSCRH = 0;                // 分频比
        TIM1_PSCRL = 1;
        TIM1_CR1 |= 0x20;        // CMS(01) : Center-aligned mode 1
        TIM1_CR1 |= 0x80;        // set ARPE
TIM1_IER |= 0x03;
TIM1_IER |= 0x04;
//TIM1_IER |= 0x20;
//TIM1_IER |= 0x40;
//TIM1_IER |= 0x80;
        TIM1_CCMR1 |= 0x60;        // OC1M(110) : PWM Mode 1
        TIM1_CCMR1 |= 0x08; // set OC1PE
TIM1_CCMR2 |= 0x60;
TIM1_CCMR2 |= 0x08;
        TIM1_CCER1 |= 0x01;        // set CC1E
        TIM1_CCER1 |= 0x08;        // set CC1NP
        TIM1_CCER1 |= 0x04;        // set CC1NE
TIM1_CCER1 |= 0x02;
TIM1_CCER1 |= 0x10;        // set CC1E
        TIM1_CCER1 |= 0x20;        // set CC1NP
        TIM1_CCER1 |= 0x40;        // set CC1NE
TIM1_CCER1 |= 0x80;
        TIM1_CR2 |= 0x01;        // set CCPC
TIM1_CR2 |= 0x04;
TIM1_CR2 |= 0x04;
        TIM1_EGR |= 0x20;        // set COMG
        TIM1_DTR = 0x05;        // Deadtime generator
        TIM1_BKR |= 0x08;        // set OSSR
        TIM1_BKR |= 0x80;        // set MOE
        TIM1_CR1 |= 0x01;        // 开启计数?
TIM1_OISR |= 0x0f;
发表于 2014-1-13 22:53:10 | 显示全部楼层
117
117
2014-1-12
 楼主| 发表于 2014-1-14 20:23:35 | 显示全部楼层
回复【2楼】正点原子:
谢谢原子哥,问题已经解决,程序没有问题的。
2017-8-25
发表于 2017-8-25 17:19:58 | 显示全部楼层
GMT+8, 2026-10-31 06:19
