查看: 11695|回复: 6
LwIP分配内存失败,求解?
95
748
1886
1886
2012-9-16
296 小时
发表于 2014-1-14 10:45:05 | 显示全部楼层 |阅读模式
LwIP中发送小数据可以,发送140个字节的数据发送失败,查找原因,是分配内存失败,返回是men->used 为121
按道理说即使分配失败,used返回的数据也是1也不会是121?
mem_malloc(mem_size_t size)
  mem_size_t ptr, ptr2;
  struct mem *mem, *mem2;
#if LWIP_ALLOW_MEM_FREE_FROM_OTHER_CONTEXT
  u8_t local_mem_free_count = 0;
#endif /* LWIP_ALLOW_MEM_FREE_FROM_OTHER_CONTEXT */
  LWIP_MEM_ALLOC_DECL_PROTECT();
  if (size == 0) {
    return NULL;
printf("size %d \n",size);
  /* Expand the size of the allocated memory region so that we can
     adjust for alignment. */
  size = LWIP_MEM_ALIGN_SIZE(size);
  if(size < MIN_SIZE_ALIGNED) {
    /* every data block must be at least MIN_SIZE_ALIGNED long */
    size = MIN_SIZE_ALIGNED;
  if (size > MEM_SIZE_ALIGNED) {
    return NULL;
  /* protect the heap from concurrent access */
  sys_arch_sem_wait(mem_sem, 0);
  LWIP_MEM_ALLOC_PROTECT();
  /* run as long as a mem_free disturbed mem_malloc */
  do {
    /* Scan through the heap searching for a free block that is big enough,
     * beginning with the lowest free block.
    for (ptr = (u8_t *)lfree - ram; ptr < MEM_SIZE_ALIGNED - size;
         ptr = ((struct mem *)&ram[ptr])->next) {
  mem = (struct mem *)&ram[ptr];
      mem_free_count = 0;
      LWIP_MEM_ALLOC_UNPROTECT();
      /* allow mem_free to run */
      if (mem_free_count != 0) {
        local_mem_free_count = mem_free_count;
      mem_free_count = 0;
printf("mem->used %d \n",mem->used);
      if ((!mem->used) &&
          (mem->next - (ptr + SIZEOF_STRUCT_MEM)) >= size) {
        /* mem is not used and at least perfect fit is possible:
         * mem->next - (ptr + SIZEOF_STRUCT_MEM) gives us the 'user data size' of mem */
if (mem->next - (ptr + SIZEOF_STRUCT_MEM) >= (size + SIZEOF_STRUCT_MEM + MIN_SIZE_ALIGNED)) {
          /* (in addition to the above, we test if another struct mem (SIZEOF_STRUCT_MEM) containing
           * at least MIN_SIZE_ALIGNED of data also fits in the 'user data space' of 'mem')
           * -> split large block, create empty remainder,
           * remainder must be large enough to contain MIN_SIZE_ALIGNED data: if
           * mem->next - (ptr + (2*SIZEOF_STRUCT_MEM)) == size,
           * struct mem would fit in but no data between mem2 and mem2->next
           * @todo we could leave out MIN_SIZE_ALIGNED. We would create an empty
           *       region that couldn't hold data, but when mem->next gets freed,
           *       the 2 regions would be combined, resulting in more free memory
          ptr2 = ptr + SIZEOF_STRUCT_MEM + size;
          /* create mem2 struct */
          mem2 = (struct mem *)&ram[ptr2];
          mem2->used = 0;
          mem2->next = mem->next;
          mem2->prev = ptr;
          /* and insert it between mem and mem->next */
          mem->next = ptr2;
          mem->used = 1;
          if (mem2->next != MEM_SIZE_ALIGNED) {
            ((struct mem *)&ram[mem2->next])->prev = ptr2;
          MEM_STATS_INC_USED(used, (size + SIZEOF_STRUCT_MEM));
        } else {
          /* (a mem2 struct does no fit into the user data space of mem and mem->next will always
           * be used at this point: if not we have 2 unused structs in a row, plug_holes should have
           * take care of this).
           * -> near fit or excact fit: do not split, no mem2 creation
           * also can't move mem->next directly behind mem, since mem->next
           * will always be used at this point!
          mem->used = 1;
          MEM_STATS_INC_USED(used, mem->next - ((u8_t *)mem - ram));
        if (mem == lfree) {
          /* Find next free block after mem and update lowest free pointer */
          while (lfree->used && lfree != ram_end) {
            /* prevent high interrupt latency... */
            lfree = (struct mem *)&ram[lfree->next];
          LWIP_ASSERT("mem_malloc: !lfree->used", ((lfree == ram_end) || (!lfree->used)));
        sys_sem_signal(mem_sem);
        LWIP_ASSERT("mem_malloc: allocated memory not above ram_end.",
         (mem_ptr_t)mem + SIZEOF_STRUCT_MEM + size <= (mem_ptr_t)ram_end);
        LWIP_ASSERT("mem_malloc: allocated memory properly aligned.",
         ((mem_ptr_t)mem + SIZEOF_STRUCT_MEM) % MEM_ALIGNMENT == 0);
        LWIP_ASSERT("mem_malloc: sanity check alignment",
          (((mem_ptr_t)mem) & (MEM_ALIGNMENT-1)) == 0);
        return (u8_t *)mem + SIZEOF_STRUCT_MEM;
    /* if we got interrupted by a mem_free, try again */
  } while(local_mem_free_count != 0);
  LWIP_DEBUGF(MEM_DEBUG | LWIP_DBG_LEVEL_SERIOUS, ("mem_malloc: could not allocate %"S16_F" bytes\n", (s16_t)size));
  MEM_STATS_INC(err);
  return NULL;
#endif /* MEM_USE_POOLS */
纵浪大化中,不喜亦不惧;应尽便须尽,无复独多虑!
95
748
1886
1886
2012-9-16
296 小时
 楼主| 发表于 2014-1-14 12:40:34 | 显示全部楼层
38
2061
3273
3273
2012-1-16
37 小时
发表于 2014-1-14 16:06:54 | 显示全部楼层
是不是字节没有对齐?
站在巨人的肩膀上不断的前进。。。
发表于 2014-1-14 16:08:12 | 显示全部楼层
95
748
1886
1886
2012-9-16
296 小时
 楼主| 发表于 2014-1-14 16:36:15 | 显示全部楼层
也配置了啊,如果虚拟140个字节,最后形成包是212个字节,是可以发送的,并且与上位机通信正常
但是,如果使用485,从控制器获取数据140个字节,再把获取的通过TCP发送出去,就发不出去了,但是20个字节可以,最想不明白的是used应该是1或0 ,而现在却是121,不知道这个数据怎么出现。
整个系统设计如下
95
748
1886
1886
2012-9-16
296 小时
 楼主| 发表于 2014-1-15 15:43:34 | 显示全部楼层
回复【4楼】正点原子:
感谢原子哥,问题已解决,原因是定义了这样几个数组MODBUS_RECEIVE_SBUF[],影响了协议栈的内存,导致数据出错,内存泄露!改正方法是MODBUS_RECEIVE_SBUF[确定值]!
95
748
1886
1886
2012-9-16
296 小时
 楼主| 发表于 2014-1-15 15:46:13 | 显示全部楼层
GMT+8, 2026-11-4 03:43
