查看: 8544|回复: 13
STM32F030c8t6的SPI操作W25Q32
156
523
523
2016-1-7
131 小时
发表于 2018-1-26 16:09:36 | 显示全部楼层 |阅读模式
10金钱
STM32F030c8t6的SPI操作W25Q32不成功,求助
STM32F030C8T6里面没有SPI2,只有SPI1,问题就出在这里
156
523
523
2016-1-7
131 小时
 楼主| 发表于 2018-1-26 16:09:37 | 显示全部楼层
156
523
523
2016-1-7
131 小时
 楼主| 发表于 2018-1-26 16:13:23 | 显示全部楼层
[mw_shl_code=c,true]void SPI_FLASH_Init(void)
  GPIO_InitTypeDef  GPIO_InitStruct;
  SPI_InitTypeDef   SPI_InitStruct;
  /*!< SD_SPI_CS_GPIO, SD_SPI_MOSI_GPIO, SD_SPI_MISO_GPIO, SD_SPI_DETECT_GPIO
       and SD_SPI_SCK_GPIO Periph clock enable */
//          RCC_AHBPeriphClockCmd(FLASH_CS_PIN_SCK|FLASH_SCK_PIN_SCK|FLASH_MISO_PIN_SCK | FLASH_MOSI_PIN_SCK, ENABLE);
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA| RCC_AHBPeriph_GPIOB, ENABLE);
  /*!< SD_SPI Periph clock enable */
  RCC_APB2PeriphClockCmd(FLASH_SPI1, ENABLE); //打开SP1时钟
  /*!< Configure SD_SPI pins: SCK */
  GPIO_InitStruct.GPIO_Pin = FLASH_SCK_PIN;
  GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStruct.GPIO_Speed = GPIO_Speed_Level_3;
  GPIO_InitStruct.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStruct.GPIO_PuPd  = GPIO_PuPd_UP;
  GPIO_Init(FLASH_SCK_PORT, &GPIO_InitStruct);
  /*!< Configure SD_SPI pins: MISO */
  GPIO_InitStruct.GPIO_Pin = FLASH_MISO_PIN;
  GPIO_Init(FLASH_MISO_PORT, &GPIO_InitStruct);
  /*!< Configure SD_SPI pins: MOSI */
  GPIO_InitStruct.GPIO_Pin =FLASH_MOSI_PIN;
  GPIO_Init(FLASH_MOSI_PORT, &GPIO_InitStruct);
  /* Connect PXx to SD_SPI_SCK */
  GPIO_PinAFConfig(FLASH_SCK_PORT, FLASH_SCK_SOURCE, FLASH_SCK_AF);
  /* Connect PXx to SD_SPI_MISO */
  GPIO_PinAFConfig(FLASH_MISO_PORT, FLASH_MISO_SOURCE, FLASH_MISO_AF);
  /* Connect PXx to SD_SPI_MOSI */
  GPIO_PinAFConfig(FLASH_MOSI_PORT, FLASH_MOSI_SOURCE, FLASH_MOSI_AF);
         /*!< Configure SD_SPI_CS_PIN pin: SD Card CS pin */
  GPIO_InitStruct.GPIO_Pin =FLASH_CS_PIN;
  GPIO_InitStruct.GPIO_Mode = GPIO_Mode_OUT;
  GPIO_Init(FLASH_CS_PORT, &GPIO_InitStruct);
  SPI_FLASH_CS_HIGH();
  GPIO_SetBits(GPIOA,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
  /*!< SD_SPI Config */
  SPI_InitStruct.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  SPI_InitStruct.SPI_Mode = SPI_Mode_Master;
  SPI_InitStruct.SPI_DataSize = SPI_DataSize_8b;
  SPI_InitStruct.SPI_CPOL = SPI_CPOL_High;
  SPI_InitStruct.SPI_CPHA = SPI_CPHA_2Edge;
  SPI_InitStruct.SPI_NSS = SPI_NSS_Soft;
  SPI_InitStruct.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_64;
  SPI_InitStruct.SPI_FirstBit = SPI_FirstBit_MSB;
  SPI_InitStruct.SPI_CRCPolynomial = 7;
  SPI_Init(SPI1, &SPI_InitStruct);
  SPI_RxFIFOThresholdConfig(SPI1, SPI_RxFIFOThreshold_QF);
  SPI_Cmd(SPI1, ENABLE); /*!< SD_SPI enable */
        // SPI_FLASH_CS_LOW();
* Function Name  : SPI_FLASH_SectorErase
* Description    : Erases the specified FLASH sector.擦除FLASH扇区
* Input          : SectorAddr: address of the sector to erase.要擦除的扇区地址
* Output         : None
* Return         : None
void SPI_FLASH_SectorErase(uint32_t SectorAddr)
  /* Send write enable instruction */
  SPI_FLASH_WriteEnable();
  SPI_FLASH_WaitForWriteEnd();
  /* Sector Erase */
  /* Select the FLASH: Chip Select low */
  SPI_FLASH_CS_LOW();
  /* Send Sector Erase instruction */
  SPI_FLASH_SendByte(W25X_SectorErase);
  /* Send SectorAddr high nibble address byte */
  SPI_FLASH_SendByte((SectorAddr & 0xFF0000) >> 16);
  /* Send SectorAddr medium nibble address byte */
  SPI_FLASH_SendByte((SectorAddr & 0xFF00) >> 8);
  /* Send SectorAddr low nibble address byte */
  SPI_FLASH_SendByte(SectorAddr & 0xFF);
  /* Deselect the FLASH: Chip Select high */
  /* Wait the end of Flash writing */
* Function Name  : SPI_FLASH_BulkErase
* Description    : Erases the entire FLASH.   擦除FLASH扇区,整片擦除
* Input          : None
* Output         : None
* Return         : None
void SPI_FLASH_BulkErase(void)
  /* Bulk Erase */
  SPI_FLASH_CS_LOW();
  /* Send Bulk Erase instruction  */
  SPI_FLASH_SendByte(W25X_ChipErase);
* Function Name  : SPI_FLASH_PageWrite
* Description    : Writes more than one byte to the FLASH with a single WRITE   对FLASH按页写入数据,调用本函数写入数据前需要先擦除扇区
*                  cycle(Page WRITE sequence). The number of byte can't exceed
*                  the FLASH page size.
* Input          : - pBuffer : pointer to the buffer  containing the data to be   pBuffer,要写入数据的指针
*                    written to the FLASH.
*                  - WriteAddr : FLASH's internal address to write to.   写入地址
*                  - NumByteToWrite : number of bytes to write to the FLASH, NumByteToWrite,写入数据长度,必须小于等于SPI_FLASH_PerWritePageSize
*                    must be equal or less than "SPI_FLASH_PageSize" value.
* Output         : None
* Return         : None
void SPI_FLASH_PageWrite(uint8_t* pBuffer, uint32_t WriteAddr, uint16_t NumByteToWrite)
  /* Enable the write access to the FLASH */
  SPI_FLASH_CS_LOW();
  /* Send "Write to Memory " instruction */
  SPI_FLASH_SendByte(W25X_PageProgram);
  /* Send WriteAddr high nibble address byte to write to */
  SPI_FLASH_SendByte((WriteAddr & 0xFF0000) >> 16);
  /* Send WriteAddr medium nibble address byte to write to */
  SPI_FLASH_SendByte((WriteAddr & 0xFF00) >> 8);
  /* Send WriteAddr low nibble address byte to write to */
  SPI_FLASH_SendByte(WriteAddr & 0xFF);
  if(NumByteToWrite > SPI_FLASH_PerWritePageSize)
     NumByteToWrite = SPI_FLASH_PerWritePageSize;
     //printf("\n\r Err: SPI_FLASH_PageWrite too large!");
  /* while there is data to be written on the FLASH */
  while (NumByteToWrite--)
    /* Send the current byte */
    SPI_FLASH_SendByte(*pBuffer);
    /* Point on the next byte to be written */
    pBuffer++;
* Function Name  : SPI_FLASH_BufferWrite
* Description    : Writes block of data to the FLASH. In this function, the
*                  number of WRITE cycles are reduced, using Page WRITE sequence. 对FLASH写入数据,调用本函数写入数据前需要先擦除扇区
*                  - NumByteToWrite : number of bytes to write to the FLASH.      写入数据长度
* Output         : None
* Return         : None
void SPI_FLASH_BufferWrite(uint8_t* pBuffer, uint32_t WriteAddr, uint16_t NumByteToWrite)
  uint8_t NumOfPage = 0, NumOfSingle = 0, Addr = 0, count = 0, temp = 0;
  Addr = WriteAddr % SPI_FLASH_PageSize;
  count = SPI_FLASH_PageSize - Addr;
  NumOfPage =  NumByteToWrite / SPI_FLASH_PageSize;
  NumOfSingle = NumByteToWrite % SPI_FLASH_PageSize;
  if (Addr == 0) /* WriteAddr is SPI_FLASH_PageSize aligned  */
    if (NumOfPage == 0) /* NumByteToWrite < SPI_FLASH_PageSize */
      SPI_FLASH_PageWrite(pBuffer, WriteAddr, NumByteToWrite);
    else /* NumByteToWrite > SPI_FLASH_PageSize */
      while (NumOfPage--)
        SPI_FLASH_PageWrite(pBuffer, WriteAddr, SPI_FLASH_PageSize);
        WriteAddr +=  SPI_FLASH_PageSize;
        pBuffer += SPI_FLASH_PageSize;
      SPI_FLASH_PageWrite(pBuffer, WriteAddr, NumOfSingle);
  else /* WriteAddr is not SPI_FLASH_PageSize aligned  */
      if (NumOfSingle > count) /* (NumByteToWrite + WriteAddr) > SPI_FLASH_PageSize */
        temp = NumOfSingle - count;
        SPI_FLASH_PageWrite(pBuffer, WriteAddr, count);
        WriteAddr +=  count;
        pBuffer += count;
        SPI_FLASH_PageWrite(pBuffer, WriteAddr, temp);
      NumByteToWrite -= count;
      WriteAddr +=  count;
      pBuffer += count;
      while (NumOfPage--)
      if (NumOfSingle != 0)
}[/mw_shl_code]
460
906
906
2017-12-15
111 小时
发表于 2018-1-26 16:13:27 | 显示全部楼层
159
963
2097
2097
2014-3-7
491 小时
发表于 2018-1-26 16:31:03 | 显示全部楼层
吴京都来写程序。
680
3447
3447
2017-7-4
869 小时
发表于 2018-1-26 16:49:08 | 显示全部楼层
155
882
882
2017-8-7
200 小时
发表于 2018-1-26 17:26:08 | 显示全部楼层
让我在战狼3里当男3我就告诉你
156
523
523
2016-1-7
131 小时
 楼主| 发表于 2018-1-26 19:03:51 | 显示全部楼层
a496298685 发表于 2018-1-26 16:13
请努力调试。。。目前遭遇了什么问题?
无法读,也无法写
156
523
523
2016-1-7
131 小时
 楼主| 发表于 2018-1-26 19:04:13 | 显示全部楼层
无法读也无法写
156
523
523
2016-1-7
131 小时
 楼主| 发表于 2018-1-29 11:08:04 | 显示全部楼层
该问题已解决,一个细节忽略了
460
906
906
2017-12-15
111 小时
发表于 2018-1-29 13:41:49 | 显示全部楼层
lumilu 发表于 2018-1-29 11:08
该问题已解决,一个细节忽略了
说出来看看?
235
235
2015-7-22
45 小时
发表于 2019-8-24 12:39:21 | 显示全部楼层
请问有文档说明吗??我操作SPI2也是不行,但是网上有些案列我看都是使用STM32F030C8T6的SPI2 写的
95
490
490
2019-12-6
153 小时
发表于 2020-3-4 17:43:30 | 显示全部楼层
能不能给下程序代码  我ID都读不对
69
586
586
2016-7-29
132 小时
发表于 2025-8-7 18:15:09 | 显示全部楼层
前辈,我遇到同样问题了,SPI1无法读写W25Q32,程序和你发的差不多,读出的ID始终为0xEFEF,可以传授下您的经验吗?
GMT+8, 2026-10-31 02:48
