查看: 5490|回复: 3
串口通信问题
2017-10-5
发表于 2018-2-7 16:26:54 | 显示全部楼层 |阅读模式
3金钱
STM32F767用到2个串口:串口1,230400,DMA发送,中断接收;串口5,460800,DMA发送,中断接收。初始化程序如下:
//初始化函数
void MX_UART5_Init(void)
  huart5.Instance = UART5;
  huart5.Init.BaudRate = 460800;
  huart5.Init.WordLength = UART_WORDLENGTH_8B;
  huart5.Init.StopBits = UART_STOPBITS_1;
  huart5.Init.Parity = UART_PARITY_NONE;
  huart5.Init.Mode = UART_MODE_TX_RX;
  huart5.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart5.Init.OverSampling = UART_OVERSAMPLING_16;
  huart5.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE;
  huart5.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
  if (HAL_UART_Init(&huart5) != HAL_OK)
    _Error_Handler(__FILE__, __LINE__);
  HAL_UART_Receive_IT(&huart5, RS422Type.RxTmpBuf, 1);
/* USART1 init function */
void MX_USART1_UART_Init(void)
  huart1.Instance = USART1;
  huart1.Init.BaudRate = 230400;
  huart1.Init.WordLength = UART_WORDLENGTH_9B;
  huart1.Init.StopBits = UART_STOPBITS_2;
  huart1.Init.Parity = UART_PARITY_EVEN;
  huart1.Init.Mode = UART_MODE_TX_RX;
  huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart1.Init.OverSampling = UART_OVERSAMPLING_16;
  huart1.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE;
  huart1.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
  if (HAL_UART_Init(&huart1) != HAL_OK)
  HAL_UART_Receive_IT(&huart1, RS232Type.RxTmpBuf, 1);
//串口中断函数
void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart)
        if(huart->Instance==USART1)//如果是串口1
                if(RS232Type.RxTmpBuf[0]==0x55 && RS232Type.rx_len==0)
                        RS232Type.RxBuf[0]=RS232Type.RxTmpBuf[0];
                        RS232Type.rx_len=1;
                else if(RS232Type.RxTmpBuf[0]==0xAA && RS232Type.rx_len==1)
                        RS232Type.RxBuf[1]=RS232Type.RxTmpBuf[0];
                        RS232Type.rx_len=2;
                else if(RS232Type.rx_len>1 && RS232Type.rx_len<12)
                        RS232Type.RxBuf[RS232Type.rx_len]=RS232Type.RxTmpBuf[0];
                        RS232Type.rx_len++;
                        if(RS232Type.rx_len>=12)
                                RS232Type.rx_len=0;
                                HAL_UART_Transmit_DMA(&huart1,RS232Type.RxBuf,12);
                        RS232Type.rx_len=0;
                HAL_UART_Receive_IT(&huart1,RS232Type.RxTmpBuf,1);
        else if(huart->Instance==UART5)//如果是串口5
                if(RS422Type.RxTmpBuf[0]==0x90 && RS232Type.rx_len==0)
                        RS422Type.RxBuf[0]=RS422Type.RxTmpBuf[0];
                        RS422Type.rx_len=1;
                        HAL_GPIO_WritePin(GPIOA, LED2_Pin|LED4_Pin|LED5_Pin|LED3_Pin, GPIO_PIN_RESET);
                else if(RS422Type.rx_len>=1 && RS422Type.rx_len<12)
                        RS422Type.RxBuf[RS422Type.rx_len]=RS422Type.RxTmpBuf[0];
                        RS422Type.rx_len++;
                        if(RS422Type.rx_len>=12)
                                RS422Type.rx_len=0;
                                //90 FF FC 69 FF F9 A0 00 01 DC 00 CA,共12个字节
                        RS422Type.rx_len=0;
                HAL_UART_Receive_IT(&huart5,RS422Type.RxTmpBuf,1);
767先上电,设备再上电通信正常,但设备先上电,再运行767,767进不了串行中断。请指正。
2017-10-5
 楼主| 发表于 2018-2-8 20:48:25 | 显示全部楼层
苦等,
154
434
434
2013-3-18
82 小时
发表于 2018-2-9 10:18:23 | 显示全部楼层
理论上会进中断,但是最大可能是错误的中断,比如溢出,帧错误,等等(必须要清除这些才能正常通信)。建议debug,断点直接设置在中断函数中,而不是接收回调
879
3071
3071
2018-2-7
285 小时
发表于 2018-2-9 10:44:10 | 显示全部楼层
GMT+8, 2026-10-30 22:08
