查看: 10345|回复: 13
求教移植st官方Ymodem,发现接收文件有大小限制问题
89
172
609
609
2015-9-7
142 小时
发表于 2018-3-28 16:37:10 | 显示全部楼层 |阅读模式
移植了ST官方的Ymodem,但是发现在128字节模式下最多只能接收255*128=32640字节文件,在1K模式是最多只能接收255K的文件,这个得怎么改啊?/**
  * @file    IAP_Main/Src/ymodem.c
  * @Author  MCD Application Team
  * @version 1.0.0
  * @date    8-April-2015
  * @brief   This file provides all the software functions related to the ymodem
  *          protocol.
  * Licensed under MCD-ST Liberty SW License Agreement V2, (the "License");
  * You may not use this file except in compliance with the License.
  * You may obtain a copy of the License at:
  *        http://www.st.com/software_license_agreement_liberty_v2
  * Unless required by applicable law or agreed to in writing, software
  * distributed under the License is distributed on an "AS IS" BASIS,
  * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
  * See the License for the specific language governing permissions and
  * limitations under the License.
/** @addtogroup STM32L0xx_IAP
/* Includes ------------------------------------------------------------------*/
#include "flash_if.h"
#include "common.h"
#include "ymodem.h"
#include "string.h"
#include "main.h"
#include "menu.h"
#include "aes.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define CRC16_F       /* activate the CRC16 integrity */
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
/* @note ATTENTION - please keep this variable 32bit alligned */
uint8_t aPacketData[PACKET_1K_SIZE + PACKET_DATA_INDEX + PACKET_TRAILER_SIZE];
/* Private function prototypes -----------------------------------------------*/
static void PrepareIntialPacket(uint8_t *p_data, const uint8_t *p_file_name, uint32_t length);
static void PreparePacket(uint8_t *p_source, uint8_t *p_packet, uint8_t pkt_nr, uint32_t size_blk);
static HAL_StatusTypeDef ReceivePacket(uint8_t *p_data, uint32_t *p_length, uint32_t timeout);
uint16_t UpdateCRC16(uint16_t crc_in, uint8_t byte);
uint16_t Cal_CRC16(const uint8_t* p_data, uint32_t size);
uint8_t CalcChecksum(const uint8_t *p_data, uint32_t size);
uint8_t aFileName[FILE_NAME_LENGTH];
/* Private functions ---------------------------------------------------------*/
  * @brief  Receive a packet from sender
  * @param  data
  * @param  length
  *     0: end of transmission
  *     2: abort by sender
  *    >0: packet length
  * @param  timeout
  * @retval HAL_OK: normally return
  *         HAL_BUSY: abort by user
  uint32_t crc;
  uint32_t packet_size = 0;
  HAL_StatusTypeDef status;
  uint8_t char1;
  *p_length = 0;
  status = HAL_UART_Receive(&UartHandle, &char1, 1, timeout);
  if (status == HAL_OK)
    switch (char1)
      case SOH:
        packet_size = PACKET_SIZE;
        break;
      case STX:
        packet_size = PACKET_1K_SIZE;
        break;
      case EOT:
        break;
      case CA:
        if ((HAL_UART_Receive(&UartHandle, &char1, 1, timeout) == HAL_OK) && (char1 == CA))
          packet_size = 2;
          status = HAL_ERROR;
        break;
      case ABORT1:
      case ABORT2:
        status = HAL_BUSY;
        break;
      default:
        status = HAL_ERROR;
        break;
    *p_data = char1;
    if (packet_size >= PACKET_SIZE )
      status = HAL_UART_Receive(&UartHandle, &p_data[PACKET_NUMBER_INDEX], packet_size + PACKET_OVERHEAD_SIZE, timeout);
      /* Simple packet sanity check */
      if (status == HAL_OK )
        if (p_data[PACKET_NUMBER_INDEX] != ((p_data[PACKET_CNUMBER_INDEX]) ^ NEGATIVE_BYTE))
          packet_size = 0;
          status = HAL_ERROR;
          /* Check packet CRC */
          crc = p_data[ packet_size + PACKET_DATA_INDEX ] << 8;
          crc += p_data[ packet_size + PACKET_DATA_INDEX + 1 ];
          if (HAL_CRC_Calculate(&CrcHandle, (uint32_t*)&p_data[PACKET_DATA_INDEX], packet_size) != crc )
            packet_size = 0;
            status = HAL_ERROR;
        packet_size = 0;
  *p_length = packet_size;
  return status;
  * @brief  Prepare the first block
  * @param  p_data:  output buffer
  * @param  p_file_name: name of the file to be sent
  * @param  length: length of the file to be sent in bytes
  * @retval None
  uint32_t i, j = 0;
  uint8_t astring[10];
  /* first 3 bytes are constant */
  p_data[PACKET_START_INDEX] = SOH;
  p_data[PACKET_NUMBER_INDEX] = 0x00;
  p_data[PACKET_CNUMBER_INDEX] = 0xff;
  /* Filename written */
  for (i = 0; (p_file_name != '\0') && (i < FILE_NAME_LENGTH); i++)
    p_data[i + PACKET_DATA_INDEX] = p_file_name;
  p_data[i + PACKET_DATA_INDEX] = 0x00;
  /* file size written */
  Int2Str (astring, length);
  i = i + PACKET_DATA_INDEX + 1;
  while (astring[j] != '\0')
    p_data[i++] = astring[j++];
  /* padding with zeros */
  for (j = i; j < PACKET_SIZE + PACKET_DATA_INDEX; j++)
    p_data[j] = 0;
  * @brief  Prepare the data packet
  * @param  p_source: pointer to the data to be sent
  * @param  p_packet: pointer to the output buffer
  * @param  pkt_nr: number of the packet
  * @param  size_blk: length of the block to be sent in bytes
  * @retval None
  uint8_t *p_record;
  uint32_t i, size, packet_size;
  /* Make first three packet */
  packet_size = size_blk >= PACKET_1K_SIZE ? PACKET_1K_SIZE : PACKET_SIZE;
  size = size_blk < packet_size ? size_blk : packet_size;
  if (packet_size == PACKET_1K_SIZE)
    p_packet[PACKET_START_INDEX] = STX;
    p_packet[PACKET_START_INDEX] = SOH;
  p_packet[PACKET_NUMBER_INDEX] = pkt_nr;
  p_packet[PACKET_CNUMBER_INDEX] = (~pkt_nr);
  p_record = p_source;
  /* Filename packet has valid data */
  for (i = PACKET_DATA_INDEX; i < size + PACKET_DATA_INDEX;i++)
    p_packet = *p_record++;
  if ( size  <= packet_size)
    for (i = size + PACKET_DATA_INDEX; i < packet_size + PACKET_DATA_INDEX; i++)
      p_packet = 0x1A; /* EOF (0x1A) or 0x00 */
  * @brief  Update CRC16 for input byte
  * @param  crc_in input value
  * @param  input byte
  * @retval None
  uint32_t crc = crc_in;
  uint32_t in = byte | 0x100;
  do
    crc <<= 1;
    in <<= 1;
    if(in & 0x100)
      ++crc;
    if(crc & 0x10000)
      crc ^= 0x1021;
  while(!(in & 0x10000));
  return crc & 0xffffu;
  * @brief  Cal CRC16 for YModem Packet
  * @param  data
  * @param  length
  * @retval None
  uint32_t crc = 0;
  const uint8_t* dataEnd = p_data+size;
  while(p_data < dataEnd)
    crc = UpdateCRC16(crc, *p_data++);
  crc = UpdateCRC16(crc, 0);
  return crc&0xffffu;
  * @brief  Calculate Check sum for YModem Packet
  * @param  p_data Pointer to input data
  * @param  size length of input data
  * @retval uint8_t checksum value
  uint32_t sum = 0;
  const uint8_t *p_data_end = p_data + size;
  while (p_data < p_data_end )
    sum += *p_data++;
  return (sum & 0xffu);
/* Public functions ---------------------------------------------------------*/
  * @brief  Receive a file using the ymodem protocol with CRC16.
  * @param  p_size The size of the file.
  * @retval COM_StatusTypeDef result of reception/programming
COM_StatusTypeDef Ymodem_Receive ( uint32_t *p_size )
  uint32_t i, packet_length, session_done = 0, file_done, errors = 0, session_begin = 0;
  uint32_t flashdestination, filesize;
  uint8_t *file_ptr;
  uint8_t file_size[FILE_SIZE_LENGTH], tmp;
        uint32_t  packets_received;
  COM_StatusTypeDef result = COM_OK;
  /* Initialize flashdestination variable */
  flashdestination = APPLICATION_ADDRESS;
  while ((session_done == 0) && (result == COM_OK))
    packets_received = 0;
    file_done = 0;
    while ((file_done == 0) && (result == COM_OK))
      switch (ReceivePacket(aPacketData, &packet_length, DOWNLOAD_TIMEOUT))
        case HAL_OK:
          errors = 0;
          switch (packet_length)
            case 2:
              /* Abort by sender */
              Serial_PutByte(ACK);
              result = COM_ABORT;
              break;
            case 0:
              /* End of transmission */
              file_done = 1;
              break;
            default:
              /* Normal packet */
              if (aPacketData[PACKET_NUMBER_INDEX] != packets_received)
                Serial_PutByte(NAK);
                if (packets_received == 0)
                  /* File name packet */
                  if (aPacketData[PACKET_DATA_INDEX] != 0)
                    /* File name extraction */
                    i = 0;
                    file_ptr = aPacketData + PACKET_DATA_INDEX;
                    while ( (*file_ptr != 0) && (i < FILE_NAME_LENGTH))
                      aFileName[i++] = *file_ptr++;
                    /* File size extraction */
                    aFileName[i++] = '\0';
                    i = 0;
                    file_ptr ++;
                    while ( (*file_ptr != ' ') && (i < FILE_SIZE_LENGTH))
                      file_size[i++] = *file_ptr++;
                    file_size[i++] = '\0';
                    Str2Int(file_size, &filesize);
                    /* Test the size of the image to be sent */
                    /* Image size is greater than Flash size */
                    if (*p_size > (USER_FLASH_SIZE + 1))
                      /* End session */
                      tmp = CA;
                      HAL_UART_Transmit(&UartHandle, &tmp, 1, NAK_TIMEOUT);
                      result = COM_LIMIT;
                    /* erase user application area */
                    FLASH_If_Erase(APPLICATION_ADDRESS);   //收到第一帧后擦除flash
                    *p_size = filesize;
                    Serial_PutByte(CRC16);
                  /* File header packet is empty, end session */
                    file_done = 1;
                    session_done = 1;
                    break;
                else /* Data packet */
//                  ramsource =&aPacketData[PACKET_DATA_INDEX];
                  /* Write received data in Flash */
                  if (FLASH_If_Write(flashdestination,(uint8_t *)&aPacketData[PACKET_DATA_INDEX], packet_length) == FLASHIF_OK)
                    flashdestination += packet_length;
                  else /* An error occurred while writing to Flash memory */
                    /* End session */
                    Serial_PutByte(CA);
                    Serial_PutByte(CA);
                    result = COM_DATA;
                packets_received ++;
                session_begin = 1;
              break;
          break;
        case HAL_BUSY: /* Abort actually */
          Serial_PutByte(CA);
          Serial_PutByte(CA);
          result = COM_ABORT;
          break;
        default:
          if (session_begin > 0)
            errors ++;
          if (errors > MAX_ERRORS)
            /* Abort communication */
            Serial_PutByte(CA);
            Serial_PutByte(CA);
            Serial_PutByte(CRC16); /* Ask for a packet */
          break;
  return result;
  * @brief  Transmit a file using the ymodem protocol
  * @param  p_buf: Address of the first byte
  * @param  p_file_name: Name of the file sent
  * @param  file_size: Size of the transmission
  * @retval COM_StatusTypeDef result of the communication
COM_StatusTypeDef Ymodem_Transmit (uint8_t *p_buf, const uint8_t *p_file_name, uint32_t file_size)
  uint32_t errors = 0, ack_recpt = 0, size = 0, pkt_size;
  uint8_t *p_buf_int;
  uint32_t blk_number = 1;
  uint8_t a_rx_ctrl[2];
  uint8_t i;
#ifdef CRC16_F
  uint32_t temp_crc;
#else /* CRC16_F */
  uint8_t temp_chksum;
#endif /* CRC16_F */
  /* Prepare first block - header */
  PrepareIntialPacket(aPacketData, p_file_name, file_size);
  while (( !ack_recpt ) && ( result == COM_OK ))
    /* Send Packet */
    HAL_UART_Transmit(&UartHandle, &aPacketData[PACKET_START_INDEX], PACKET_SIZE + PACKET_HEADER_SIZE, NAK_TIMEOUT);
    /* Send CRC or Check Sum based on CRC16_F */
#ifdef CRC16_F
    temp_crc = HAL_CRC_Calculate(&CrcHandle, (uint32_t*)&aPacketData[PACKET_DATA_INDEX], PACKET_SIZE);
    Serial_PutByte(temp_crc >> 8);
    Serial_PutByte(temp_crc & 0xFF);
#else /* CRC16_F */
    temp_chksum = CalcChecksum (&aPacketData[PACKET_DATA_INDEX], PACKET_SIZE);
    Serial_PutByte(temp_chksum);
    /* Wait for Ack and 'C' */
    if (HAL_UART_Receive(&UartHandle, &a_rx_ctrl[0], 1, NAK_TIMEOUT) == HAL_OK)
      if (a_rx_ctrl[0] == ACK)
        ack_recpt = 1;
      else if (a_rx_ctrl[0] == CA)
        if ((HAL_UART_Receive(&UartHandle, &a_rx_ctrl[0], 1, NAK_TIMEOUT) == HAL_OK) && (a_rx_ctrl[0] == CA))
          HAL_Delay( 2 );
          __HAL_UART_FLUSH_DRREGISTER(&UartHandle);
          __HAL_UART_CLEAR_IT(&UartHandle, UART_CLEAR_OREF);
          result = COM_ABORT;
      errors++;
    if (errors >= MAX_ERRORS)
      result = COM_ERROR;
  p_buf_int = p_buf;
  size = file_size;
  /* Here 1024 bytes length is used to send the packets */
  while ((size) && (result == COM_OK ))
    /* Prepare next packet */
    PreparePacket(p_buf_int, aPacketData, blk_number, size);
    ack_recpt = 0;
    a_rx_ctrl[0] = 0;
    errors = 0;
    /* Resend packet if NAK for few times else end of communication */
      /* Send next packet */
      if (size >= PACKET_1K_SIZE)
        pkt_size = PACKET_1K_SIZE;
        pkt_size = PACKET_SIZE;
      HAL_UART_Transmit(&UartHandle, &aPacketData[PACKET_START_INDEX], pkt_size + PACKET_HEADER_SIZE, NAK_TIMEOUT);
#ifdef CRC16_F
      temp_crc = HAL_CRC_Calculate(&CrcHandle, (uint32_t*)&aPacketData[PACKET_DATA_INDEX], pkt_size);
#else /* CRC16_F */
      temp_chksum = CalcChecksum (&aPacketData[PACKET_DATA_INDEX], pkt_size);
      /* Wait for Ack */
      if ((HAL_UART_Receive(&UartHandle, &a_rx_ctrl[0], 1, NAK_TIMEOUT) == HAL_OK) && (a_rx_ctrl[0] == ACK))
        ack_recpt = 1;
        if (size > pkt_size)
          p_buf_int += pkt_size;
          size -= pkt_size;
          if (blk_number == (USER_FLASH_SIZE / PACKET_1K_SIZE))
            result = COM_LIMIT; /* boundary error */
            blk_number++;
          size = 0;
        errors++;
      /* Resend packet if NAK  for a count of 10 else end of communication */
        result = COM_ERROR;
  /* Sending End Of Transmission char */
  ack_recpt = 0;
  a_rx_ctrl[0] = 0x00;
  errors = 0;
    Serial_PutByte(EOT);
    /* Wait for Ack */
        ack_recpt = 1;
          HAL_Delay( 2 );
          result = COM_ABORT;
      errors++;
      result = COM_ERROR;
  /* Empty packet sent - some terminal emulators need this to close session */
  if ( result == COM_OK )
    /* Preparing an empty packet */
    aPacketData[PACKET_START_INDEX] = SOH;
    aPacketData[PACKET_NUMBER_INDEX] = 0;
    aPacketData[PACKET_CNUMBER_INDEX] = 0xFF;
    for (i = PACKET_DATA_INDEX; i < (PACKET_SIZE + PACKET_DATA_INDEX); i++)
      aPacketData = 0x00;
    /* Send Packet */
#ifdef CRC16_F
#else /* CRC16_F */
          HAL_Delay( 2 );
          result = COM_ABORT;
  return result; /* file transmitted successfully */
/*******************(C)COPYRIGHT 2015 STMicroelectronics *****END OF FILE****/
packets_received 声明为U32类型的数据,判断的时候修改如下 if (aPacketData != (packets_received & 0xff)) 官方的BUG挺多的
2019-5-8
发表于 2018-3-28 16:37:11 | 显示全部楼层
if (aPacketData[PACKET_NUMBER_INDEX] != (packets_received & 0xff))
官方的BUG挺多的
207
1036
1036
2016-4-6
241 小时
发表于 2018-3-28 21:00:06 | 显示全部楼层
楼主,可以上传整个工程看看嘛?最近也在搞HAL库的IAP..平台是F429的。好像官方只有L4的。
1149
7464
7464
2015-1-15
1368 小时
发表于 2018-3-28 22:29:31 来自手机 | 显示全部楼层
89
172
609
609
2015-9-7
142 小时
 楼主| 发表于 2018-3-28 22:57:06 | 显示全部楼层
yklstudent 发表于 2018-3-28 22:29
楼主实际测试过吗?
实际测过
23
345
2365
2365
2017-7-6
285 小时
发表于 2018-6-20 15:14:05 | 显示全部楼层
F1的有,F4你找找的看
23
345
2365
2365
2017-7-6
285 小时
发表于 2018-6-20 15:16:43 | 显示全部楼层
你说的这是个问题,毕竟序列号就8位最多255,ymodem就第一次传文件名和大小是128字节,后面数据超过1K肯定用1K的数据包的。那超过255K的APP怎么办
62
427
427
2016-3-9
75 小时
发表于 2018-8-15 14:06:27 | 显示全部楼层
用secureCRT进行ST官方的Ymodem进行串口IAP的时候,最大只能下载小于32KB的程序,问题找到了,是一个BUG。我用的secureCRT每包只传输128个字节的有效数据,而每个帧的标号由一个字节表示,所以等到标号到达0xFF之后,下一个帧的标号又变为0,而官方Ymodem程序是判断帧标号为0则认为是传输文件的第一个帧,即文件名和文件大小。所以等到标号由0x00-0xff再到0x00的时候,它认为是一个新的文件,所以出错。只要加一个标志标明第一次出现的帧标号为0的帧为第一帧就OK了。文采不好,说的比较啰嗦
2019-6-18
发表于 2019-8-20 09:26:30 | 显示全部楼层
if (aPacketData != (packets_received & 0x ...
大佬还是真是这个问题
2019-7-29
16 小时
发表于 2019-9-28 17:23:34 | 显示全部楼层
   感谢 题主、感谢 答主、感谢Openedv
           case 0:
       Usart_TX_set_enable();
              file_done = 1;
              break;
            default:
              /* Normal packet */
/******************/ if (aPacketData[PACKET_NUMBER_INDEX] != (packets_received & 0xff))/*****************/
/********************************************************************/:原始产生错误的判断条件//if (aPacketData[PACKET_NUMBER_INDEX] != packets_received)
/********************************************************************/:修改后的判断条件//if (aPacketData[PACKET_NUMBER_INDEX] != (packets_received & 0xff))
                    i = 0;
                    i = 0;
                    file_ptr ++;
2019-7-29
16 小时
发表于 2019-9-28 17:25:51 | 显示全部楼层
           case 0:
完全正确!!!!!!!!
345
3656
3656
2016-2-21
542 小时
发表于 2019-9-30 09:55:57 | 显示全部楼层
mark 一下
83
83
2017-7-22
12 小时
发表于 2020-8-22 10:37:40 | 显示全部楼层
我还纳闷为什么刚好接收到32640(31k)就停止了,感谢此贴,让我这么快解决了这个问题。
115
115
2023-6-8
31 小时
发表于 2025-1-6 13:49:23 | 显示全部楼层
Mark一下
GMT+8, 2026-10-31 08:20
