查看: 5984|回复: 0
Power by Linear 电源管理工具,你用过哪款?
72
72
2018-1-29
发表于 2018-4-21 11:55:15 | 显示全部楼层 |阅读模式
LTpowerPlay
LTpowerPlay® isa powerful, Windows-based development environment supporting Analog Devices'Digital Power System Management (PSM) products.Whether you’re new toLTpowerPlay or already a power user, learn how to configure, design, evaluate,diagnose, and debug from the experts.
LTpowerPlay 使用教程、下载等,请点击:https://ezchina.analog.com/thread/18121
LTpowerCAD
The LTpowerCAD®design tool is a complete power supply design tool program that cansignificantly ease the tasks of power supply design with μModule regulators andmany other products, mostly monolithic buck step-down regulators. Unlikeconventional simulation tools, this LTpowerCAD tool guides users throughout thewhole supply design process: it searches suitable parts according to user’ssupply specifications; then it guides the user to select and optimize circuitcomponent values with suggestions and warnings. The tool shows real-timeresults of feedback loop bode plot, as well as the power stage performance. Thedesign can be exported to LTspice simulation circuit for users to furtherverify their designs. The tool also provides PCB layout examples. Currently,this design tool works on Microsoft Windows based PC with Excel 2000, 2003,2007, 2010 and 2013. With internet connection, the user can make real timeupdate of the program and its component library.
LTpowerCAD 使用教程、下载等,请点击:https://ezchina.analog.com/thread/18121
ADIsimPE由SIMetrix/SIMPLIS驱动个人版电路仿真器ADIsimPE由SIMetrix/SIMPLIS供电,是针对模拟和混合信号电路设计和开发而优化的电路仿真套件。 SIMetrix模式适合用来仿真通用非开关电路。 它能完全兼容Pspice,用于工业标准SPICE模型中。 SIMPLIS(仿真分段线性系统)模式可仿真开关电路的工作情况,相比标准SPICE极大地改善了稳定性、速度和精度。 它尤为适合开关电源、PLL和ADC/DAC应用。
ADIsimPE 面向没有完整SIMetrix/SIMPLIS程序许可的ADI公司客户。 它可读取ADI公司加密原理图,以及未加密的兼容原理图介绍。
下载 ADIsimPE 请点击: https://ezchina.analog.com/thread/18121
最快、最精确的电源管理设计工具 ADIsimPower™ Voltage Regulator Design ToolADIsimPower设计中心让您通过简单的三个步骤设计电源电路:
  •         第一步: 器件选型
  •         第二步: 设计和优化
  •      第三步: 仿真
ADIsimPower
选择器根据您的特定应用要求,比较超过300个电源管理器件和超过10种不同拓扑架构的解决方案。每个解决方案都考虑了IC、外部器件和工作条件,以匹配期望性能。
下载或在线使用ADIsimPower请点击:https://ezchina.analog.com/thread/18121
GMT+8, 2026-11-28 12:11
