查看: 6933|回复: 9
应网友要求:开源一个串口类
44
187
566
566
2016-9-28
158 小时
发表于 2018-8-22 21:12:05 | 显示全部楼层 |阅读模式
[mw_shl_code=csharp,true]using System;
using System.Collections.Generic;
using System.IO;
using System.IO.Ports;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
namespace ControlPoxy
    public class Serial_Proxy
        public int DataLength;
        public byte[] RtBuff = new byte[1024 * 10];
        public bool b_SerialPortStaus = false;
        public bool b_SerialReceiveReady = false;
        private System.IO.Ports.SerialPort serialPortMode = new System.IO.Ports.SerialPort();
        private string comport;
        private int baud;
        private Parity parity;
        private int timeOut;
        public int TimeOut
            get { return timeOut; }
            set{  timeOut = value; }
        public string Comport
            get{ return comport; }
            set{ comport = value; }
        public int Baud
            get{ return baud; }
            set{ baud = value; }
        public Parity Parity
            get{ return parity; }
            set{ parity = value; }
        public bool SerialPort_Start()
            return serial_Inial();
        public void SerialPort_Stop()
            if (serialPortMode.IsOpen)
                serialPortMode.Close();
                this.serialPortMode.DataReceived -= new System.IO.Ports.SerialDataReceivedEventHandler(this.serialPortMode_DataReceived);
        public void SerialSend(byte[] data, int len)
            if (b_SerialPortStaus)
                serialPortMode.Write(data, 0, len);
        public int SerialPort_ReaDBuff(byte[] buff)
            int length = 0;
            if (DataLength > 0)
                if (DataLength > buff.Length)
                    length = buff.Length;
                    length = DataLength;
                RtBuff.CopyTo(buff, length);
                DataLength = 0;
            return length;
        private bool serial_Inial()
            if (b_SerialPortStaus == true)
                if (!serialPortMode.IsOpen)
                    serialPortMode.BaudRate = Baud;
                    serialPortMode.PortName = Comport;
                    serialPortMode.DataBits = 8;
                    serialPortMode.Parity = parity;
                    serialPortMode.Open();
                    b_SerialPortStaus = true;
                    this.serialPortMode.DataReceived += new System.IO.Ports.SerialDataReceivedEventHandler(this.serialPortMode_DataReceived);
            return b_SerialPortStaus;
        /// <summary>
        /// serial port receive data packet
        /// </summary>
        /// <param name="sender"></param>
        /// <param name="e"></param>
        private void serialPortMode_DataReceived(object sender, System.IO.Ports.SerialDataReceivedEventArgs e)
            try
                if (TimeOut > 0)
                    System.Threading.Thread.Sleep(TimeOut);
                DataLength = serialPortMode.BytesToRead;
                if (DataLength > 0)
                    if (DataLength > RtBuff.Length)
                        DataLength = RtBuff.Length;
                    serialPortMode.Read(RtBuff, 0, DataLength);
                    b_SerialReceiveReady = true;
            catch
/* End of this file */
[/mw_shl_code]
113
1777
1777
2013-9-2
753 小时
发表于 2018-8-22 22:27:17 | 显示全部楼层
谢谢,楼主无私的开源
1149
7464
7464
2015-1-15
1368 小时
发表于 2018-8-22 22:33:24 来自手机 | 显示全部楼层
C#嘛,楼主其实可以把协议也封装了,自定义的或者modbus的也可以
52
349
349
2018-7-26
75 小时
发表于 2018-8-23 08:12:42 | 显示全部楼层
113
1777
1777
2013-9-2
753 小时
发表于 2018-10-2 16:42:30 | 显示全部楼层
楼主,我用你的类,发现串口无法触发 SerialDataReceivedEventHandler 接受的函数 serialPortMode_DataReceived。是什么地方需要初始化
44
187
566
566
2016-9-28
158 小时
 楼主| 发表于 2018-10-3 07:52:15 | 显示全部楼层
lovely-teddy198 发表于 2018-10-2 16:42
楼主,我用你的类,发现串口无法触发 SerialDataReceivedEventHandler 接受的函数 serialPortMode_DataRece ...
查看我的其它帖子,里面有范例
113
1777
1777
2013-9-2
753 小时
发表于 2018-10-3 10:07:17 | 显示全部楼层
好的,在本论坛?有链接?
113
1777
1777
2013-9-2
753 小时
发表于 2018-10-5 21:08:59 | 显示全部楼层
mftang2016 发表于 2018-10-3 07:52
查看我的其它帖子,里面有范例
有链接?
69
472
472
2015-3-1
123 小时
发表于 2018-10-10 09:55:33 | 显示全部楼层
楼主这么优秀的吗~~~
- -个性的签名
2019-5-20
发表于 2019-11-28 14:31:00 | 显示全部楼层
好帖,正需要。
GMT+8, 2026-11-11 02:17
