查看: 7771|回复: 2
freertos+lwip tcp接收数据超时问题
2018-8-29
发表于 2018-8-29 12:38:23 | 显示全部楼层 |阅读模式
int8_t send_http_request(char* sendBuf,void (*handle_function)(cJSON* valid_data))
        IP4_ADDR(&server_ipaddr,MAIN_SERVER_IP_ADDR0,MAIN_SERVER_IP_ADDR1,MAIN_SERVER_IP_ADDR2,MAIN_SERVER_IP_ADDR3);
        server_port = MAIN_SERVER_PORT;
        tcp_clientconn = netconn_new(NETCONN_TCP);
        if(tcp_clientconn==NULL)
                printf("新建连接失败\r\n");
                return;
        errCode = netconn_connect(tcp_clientconn,&server_ipaddr,server_port);
        if(errCode == ERR_OK)
                finalRecvBuf = (char*)mymalloc(4000*sizeof(char));//定义finalRecvBuf长度是数据包的总长度
                memset(finalRecvBuf,0x00,4000);
                tcp_clientconn->send_timeout = 3000;//发送超时时间设定3秒
                //NETCONN_COPY,会将数据拷贝给内核进程,这种方式,用户可以直接复用buf
                errCode = netconn_write(tcp_clientconn,sendBuf,strlen((const char*) sendBuf),NETCONN_NOCOPY);
//                if(errCode == ERR_OK)
//                        DEBUG_PRINT_VAR("send sucess\r\n");
//                else
//                        DEBUG_PRINT_VAR("send failure\r\n");
                tcp_clientconn->recv_timeout  = 5000;//接收超时时间设定5秒
//                netconn_recv(tcp_clientconn,&recevingBuf);
                //循环接收数据
                        errCode = netconn_recv(tcp_clientconn,&recevingBuf);
                        printf("errCode--->%d\r\n",errCode);
                        if(errCode == ERR_OK && recevingBuf!=NULL)
                                taskENTER_CRITICAL();         //进入临界区
                                for(;;)
                                        //若第一个数据包的长度和总长度大小相等,直接拷贝出来
                                        if(recevingBuf->p->tot_len == recevingBuf->p->len)
//                                                DEBUG_PRINT_VAR("尾包数据包------->%s\r\n",(char *)recevingBuf->p->payload);
                                                strncat(finalRecvBuf,(char *)recevingBuf->p->payload,recevingBuf->p->tot_len);
                                                break;
                                        //若第一个数据包的长度和总长度大小不相等,需要循环将每个包里的内容拼接到buf中
//                                                DEBUG_PRINT_VAR("单个数据包------->%s\r\n",(char *)recevingBuf->p->payload);
                                                strncat(finalRecvBuf,(char *)recevingBuf->p->payload,recevingBuf->p->len);
        //                                        DEBUG_PRINT_VAR("p->payload 累加buf---->%s\r\n",finalRecvBuf);
        //                                        DEBUG_PRINT_VAR("数据包长度--->%d\r\n",strlen(finalRecvBuf));
                                                recevingBuf->p = recevingBuf->p->next;
                                printf("接收正常\r\n");
//                                printf("p->payload total内容是 ---->%s,接收数据长度--->%d\r\n",finalRecvBuf,strlen(finalRecvBuf));
                                netbuf_delete(recevingBuf);//需要在此时释放recevingBuf否则会导致内存异常
                                recevingBuf = NULL;
                                taskEXIT_CRITICAL();
                        else if(errCode == ERR_MEM)
                                break;
                        else if(errCode == ERR_CLSD)//服务器关闭连接
                                errCode = 0;
                                netconn_close(tcp_clientconn);
                                netconn_delete(tcp_clientconn);
                                break;
                        else if(errCode == ERR_TIMEOUT)//超时也break出去
                                printf("接收超时\r\n");
                                errCode = -1;
                                continue;
这个函数接收1000字节以上的数据,能够成功3、4次,之后便一直是超时,很郁闷,求指点迷津
记录一下,目前已经解决了这个问题。是lwip内存分配策略导致的问题,将pbuf_pool_bufsize 改为了LWIP_MEM_ALIGN_SIZE(TCP_MSS+40+PBUF_LINK_HLEN),并将分配策略改为MEMP_MEM_MALLOC
2018-8-29
 楼主| 发表于 2018-8-29 12:38:24 | 显示全部楼层
2018-8-29
 楼主| 发表于 2018-8-29 12:42:47 | 显示全部楼层
而且是不可恢复的超时,即便新建连接、发送、接收,还是超时,逆天了。ps:接收少量内容<200字节没用这个现象
GMT+8, 2026-11-4 05:36
