查看: 4223|回复: 0
分享一个ESP32命令行解析框架
103
103
2018-10-15
11 小时
发表于 2018-11-7 11:11:40 | 显示全部楼层 |阅读模式
该命令行解析框架,可以轻松实现,读写HEX类型的数据,读写数值型数据,读写IP,MAC,字符串,运行函数,浮点型数据暂时不支持,带符号的数据暂时不支持。
命令行解析框架,使用链表将所有注册的信息串联起来,然后每个节点node包含了,keyword,help,数据类型描述,命令执行的回调函数,和参数存储的回调函数。主要的操作是,已知函数变量地址,类型,和地址宽度,然后强制转换后对变量读写操作。
命令节点结构如下
  • typedef                struct  fun_node
  •         struct  fun_node *pNext;
  •         const                char        *pHelp;
  •         const                char        *pName;
  •         uint8_t                 paraNum;
  •         FUN_CMD_BK  RunFun;
  •         uint8_t                 EnableState;
  • }ST_FUN_NODE;
  • typedef                enum
  •         emCmdDataType_Dec                =1,
  •         emCmdDataType_Hex                =2,
  •         emCmdDataType_Str                =3,
  •         emCmdDataType_IP                =4,
  •         emCmdDataType_MAC                =5,
  • }EM_CMD_DATA_TYPE;
  • typedef                struct   cmd_para
  •         struct   cmd_para  *pNext;
  •         void                 *pDataAddr;
  •         uint16_t        dataLen;
  •         EM_CMD_DATA_TYPE  dataType;
  • }ST_CMD_PARA;
  • typedef                struct        cmd_node
  •         const        char         *pKeyword;
  •         ST_CMD_PARA  *pData;
  •         ST_FUN_NODE         *pFuntion;
  •         FUN_STOR_BK   StorageFun;
  • }ST_CMD_NODE;
[color=rgb(51, 102, 153) !important]复制代码
参数注册配置实例如下:
  • void         cla_parametersConfig(void)
  •                 cla_init();
  •                 cla_regsister("uuid","uuid ");
  •                 cla_addParameter("uuid","uuid ",(void *)&uuid,emCmdDataType_Str,               sizeof(uuid));
  •                 cla_regsister("wifi","wifi or wifi ssid=xxx password=xxx");
  •                 cla_addParameter("wifi","ssid",(void *)ssid,emCmdDataType_Str,                        sizeof(ssid));
  •                 cla_addParameter("wifi","password",(void *)password,emCmdDataType_Str,        sizeof(password));
  •                 cla_regsister("hex","hex or hex hex8=xx hex16=xx hex32=xx");
  •                 cla_addParameter("hex","hex8",(void *)&hex8,emCmdDataType_Hex,                        sizeof(data8));
  •                 cla_addParameter("hex","hex16",(void *)&hex16,emCmdDataType_Hex,                sizeof(data16));
  •                 cla_addParameter("hex","hex32",(void *)&hex32,emCmdDataType_Hex,                sizeof(data32));
  •                 cla_regsister("data","data or data data8=xx data16=xx data32=xx");
  •                 cla_addParameter("data","data8",(void *)&data8,emCmdDataType_Dec,                sizeof(data8));
  •                 cla_addParameter("data","data16",(void *)&data16,emCmdDataType_Dec,                sizeof(data16));
  •                 cla_addParameter("data","data32",(void *)&data32,emCmdDataType_Dec,                sizeof(data32));
  •                 cla_regsister("ipconfig","ipconfig or ipconfig ipaddr=192.168.1.1");
  •                 cla_addParameter("ipconfig","ipaddr",(void *)IPaddr,emCmdDataType_IP,        sizeof(IPaddr));
  •                 cla_addParameter("ipconfig","mask",(void *)maskIP,emCmdDataType_IP,               sizeof(maskIP));
  •                 cla_addParameter("ipconfig","dns",(void *)dnsIP,emCmdDataType_IP,               sizeof(dnsIP));
  •                 cla_addParameter("ipconfig","mac",(void *)Mac,emCmdDataType_MAC,               sizeof(Mac));
  •                 cla_regsister("run","");
  •                 cla_addRunFun("run",ptest_3fun_help,"test",test_3fun,3);
  •                 cla_addRunFun("run",ptest_2fun_help,"test2",test_2fun,2);
命令解析的进程如下:
  • void        cla_precess(uint8_t *pCmd,uint16_t cmdLen,FUN_PRINT_OUT printFun)
  •         uint16_t         i,outlen;
  •         FUN_STOR_BK                storageFun=NULL;
  •         BOOLEAN         res;
  •         static        ST_CMD_STR                cmdStr;
  •         static        char        outBuff[OUT_BUFF_MAX_LEN];
  •         if((pCmd !=NULL)&&(cmdLen > 2))
  •                         cla_cmdMake(&cmdStr,pCmd,cmdLen);
  •                         if((cla_CheckIn(&cmdStr,printFun))&&(cmdStr.argCount >= 1))
  •                                 for(i=0;i
  •                                          if(CmdNodeGroup.pKeyword != NULL)
  •                                                    if(strcmp((const char *)CmdNodeGroup.pKeyword,cmdStr.pArgValue[0]) == 0)
  •        if(cmdStr.argCount  == 1)//查询参数
  •        outlen =cla_sprintfPara(CmdNodeGroup.pData,outBuff,OUT_BUFF_MAX_LEN);
  •        if(printFun !=NULL)
  •        printFun(outBuff,outlen);
  •        Debug("out done\n");
  •        else if(strcmp("run",cmdStr.pArgValue[0]) == 0)
  •        cmdStr.argPos                =1;
  •        res       =cla_runFuntion(CmdNodeGroup.pFuntion,&cmdStr);
  •        Debug("run done\n");
  •        else
  •        cmdStr.argPos                =1;
  •        res         =cla_scanfPara(CmdNodeGroup.pData,&cmdStr);
  •        if(res)
  •        Debug("cfg done\n");
  •        storageFun =CmdNodeGroup.StorageFun;
  •        if(storageFun !=NULL)
  •        storageFun();
  •        return ;
  •                                                         else if(strcmp("help",cmdStr.pArgValue[0]) == 0)
  •        cla_help(printFun,outBuff,OUT_BUFF_MAX_LEN);
  •        return ;
GMT+8, 2026-11-11 01:40
