查看: 10012|回复: 16
[战舰F103] 战舰V3&精英TFTLCD汉字显示测试程序(从片内FLASH读取汉字点阵数据)
109
5532
10608
10608
2017-2-18
1921 小时
发表于 2018-11-19 18:41:09 | 显示全部楼层 |阅读模式
有用户问战舰V3板子想利用片内FLASH显示汉字,所以基于战舰V3板子的TFTLCD液晶显示实验移植了这个程序,相比源程序,多了个TEXT文件夹,该文件夹下存放了与片内FLASH显示汉字相关函数的text.c和text.h
程序适合战舰V3&MINI,支持2.8寸、3.5寸、4.3寸和7寸V2MCU屏
利用PCtoLCD2002生成“开” “发” “板”三个点阵库并存放在片内FLASH,这三个点阵库数据存放在text.c中
[mw_shl_code=c,true]//24*24的OLED汉字点阵,包括三个汉字:开、发、板。这三个汉字的点阵库,是利用PCtoLCD2002生产的,
//软件设置的取模方式同OLED实验ASCII的取模方式一样,字体采用24*24大小,一个汉字点阵占用72字节。
const u8 LCD_HZK_TBL[3][72]=
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x08,0x08,0x02,0x08,0x08,0x04,0x08,0x08,0x08,0x08,0x08,0x10,0x08,0x08,0xE0,
0x0F,0xFF,0x80,0x08,0x08,0x00,0x08,0x08,0x00,0x08,0x08,0x00,0x08,0x08,0x00,0x08,0x08,0x00,0x08,0x08,0x00,0x0F,0xFF,0xFE,
0x0F,0xFF,0xFE,0x08,0x08,0x00,0x08,0x08,0x00,0x10,0x08,0x00,0x10,0x10,0x00,0x00,0x30,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"开",0*/
{0x00,0x00,0x00,0x00,0x00,0x02,0x00,0x00,0x04,0x01,0x80,0x08,0x0F,0x00,0x10,0x1C,0x80,0x60,0x00,0x81,0xC2,0x00,0x87,0x02,
0x00,0xFC,0x02,0x1F,0xF0,0x04,0x3C,0x9C,0x08,0x20,0x92,0x08,0x00,0x91,0x90,0x00,0x90,0x70,0x00,0x90,0x60,0x20,0x91,0x90,
0x10,0x93,0x18,0x1C,0x9C,0x08,0x0C,0x98,0x0C,0x00,0x80,0x04,0x01,0x00,0x06,0x01,0x00,0x04,0x00,0x00,0x04,0x00,0x00,0x00},/*"发",1*/
{0x00,0x00,0x00,0x00,0x00,0xC0,0x01,0x01,0x00,0x01,0x0E,0x00,0x01,0xF8,0x00,0x3F,0xFF,0xFE,0x21,0x20,0x00,0x01,0x10,0x02,
0x02,0x0C,0x0E,0x00,0x00,0x12,0x00,0x07,0xE4,0x0F,0xFE,0x04,0x08,0x40,0x08,0x08,0x78,0x10,0x08,0x47,0x30,0x08,0x41,0xE0,
0x10,0x41,0xE0,0x10,0x47,0x30,0x30,0x7C,0x18,0x30,0xE0,0x0C,0x10,0x00,0x0C,0x00,0x00,0x04,0x00,0x00,0x00,0x00,0x00,0x00},/*"板",2*/
};[/mw_shl_code]
整个程序最重要的是LCD_Show_Font()这个函数就是用来支持从片内FLASH读取汉字点阵库并显示在液晶上
[mw_shl_code=c,true]//在指定位置,显示一个24*24大小的汉字
//x,y :汉字的坐标
//index:汉字编号(在字库数组里面的编号)
void LCD_Show_Font(u16 x,u16 y,u8 index)
        u8 temp,t,t1;
        u16 y0=y;
        u8 *dzk;
        u8 csize=72;                                        //一个24*24的汉字72字节
        dzk=(u8*)LCD_HZK_TBL[index];        //得到汉字编号对应的点阵库
        for(t=0;t<csize;t++)
                temp=dzk[t];                                //得到点阵数据
                for(t1=0;t1<8;t1++)                        //按照从高位到低位的顺序画点
                        if(temp&0x80)LCD_Fast_DrawPoint(x,y,POINT_COLOR);
                        else LCD_Fast_DrawPoint(x,y,BACK_COLOR);
                        temp<<=1;
                        y++;
                        if((y-y0)==24)                        //对y坐标的处理,当y坐标距起始坐标差24个像素点,x坐标加1
                                y=y0;
                                x++;
                                break;
}[/mw_shl_code]
main.c中程序如下
[mw_shl_code=c,true] int main(void)
        delay_init();             //延时初始化
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);// 设置中断优先级分组2
        LED_Init();                          //初始化与LED连接的硬件接口
        uart_init(115200);
        LCD_Init();
        POINT_COLOR=RED;
        LCD_Show_Font(100,40,0);
        LCD_Show_Font(100,80,1);
        LCD_Show_Font(100,120,2);
        LCD_ShowString(75,180,150,24,24,"ALIENTEK");
        LCD_ShowString(75,210,150,24,24,"WarshipSTM32");
                delay_ms(500);
                LED0=!LED0;
}[/mw_shl_code]
战舰V3&amp;精英TFTLCD汉字显示测试程序(从片内FLASH读取汉字数据).rar
2.53 MB, 下载次数: 1178
36
59
59
2018-11-19
21 小时
发表于 2018-11-19 22:29:53 | 显示全部楼层
学到了,多谢作者!!!
64
64
2019-4-15
39 小时
发表于 2019-4-29 09:58:56 | 显示全部楼层
多谢分享
802
802
2019-6-16
132 小时
发表于 2019-6-16 11:18:23 | 显示全部楼层
115
115
2019-7-9
14 小时
发表于 2019-7-28 15:02:59 | 显示全部楼层
每天已回复
272
272
2019-7-19
63 小时
发表于 2019-9-29 00:08:59 | 显示全部楼层
谢谢分享
23
23
2019-5-18
发表于 2019-10-20 02:27:55 | 显示全部楼层
感谢感谢 学到了
61
382
382
2019-6-4
77 小时
发表于 2019-10-21 22:04:30 | 显示全部楼层
为什么我取模出来的数据和楼主的怎么不一样??    和原子哥的oled一样
166
166
2019-9-20
49 小时
发表于 2020-2-23 18:36:21 | 显示全部楼层
正好需要,谢谢楼主
2020-5-3
发表于 2020-5-20 20:19:22 | 显示全部楼层
谢谢分享
23
23
2020-6-22
发表于 2020-6-23 19:51:47 | 显示全部楼层
多谢分享!正好学习了!
120
120
2016-7-19
11 小时
发表于 2020-9-28 16:51:46 | 显示全部楼层
谢谢楼主分享!
78
78
2020-9-27
23 小时
发表于 2020-10-4 21:41:31 | 显示全部楼层
楼主你好 按照你的方法试了一下  LCD屏幕没有显示这几个汉字
2020-11-7
发表于 2020-11-7 20:47:56 | 显示全部楼层
感谢大佬分享 太棒了 自己搞半天不如来这逛一逛
2021-7-11
发表于 2021-10-3 21:48:26 | 显示全部楼层
多谢楼主
185
185
2020-9-2
37 小时
发表于 2021-10-8 19:17:37 | 显示全部楼层
取模方向是什么啊?
185
185
2020-9-2
37 小时
发表于 2021-10-8 20:36:41 | 显示全部楼层
原来是逐列式顺向
GMT+8, 2026-10-31 09:32
