查看: 5695|回复: 0
STM8S定时器1中断进不去
2018-11-25
发表于 2018-11-25 17:29:35 | 显示全部楼层 |阅读模式
设置的定时器1发送PWM,定时器2接收,现在程序运行时一直进定时器2,没有进定时器1,都是用寄存器编写的,这个是怎么回事?求助
u8 SendPuls(u8 Halfperiod)
  GPIO_Config();
  TIM1_DeInit();
  TIM2_DeInit();
  //TIM1_Config(Halfperiod);                                                    //发射设置
  TIM1_ARRH = Halfperiod/256;                                                   //装载频率
  TIM1_ARRL = Halfperiod%256;
  float Duty = 0.5;
  float a;
  a = Halfperiod*Duty;
  TIM1_CCR1H = ((u16)(a))/256;                                                  //装载占空比
  TIM1_CCR1L = ((u16)(a))%256;
  TIM1_CNTRH = 0;
  TIM1_CNTRL = 0;
  TIM1_CR1 &= 0xFE;
  // delay_us(10);
  TIM1_CCMR1 |= 0x60;                                                           //PWM1模式
  TIM1_CR1 &= 0x8F;                                                             //中央对齐上下计数上下溢出置1
  TIM1_CCMR1 |= 0x08;
  TIM1_CCMR1 &= 0xFC;
  TIM1_CCER1 &= 0xFD;                                                           //OC1高电平有效
  TIM1_CCMR1 |=0x08;
  TIM1_CCER1 |= 0x01;                                                           //输出使能
  //TIM1_EGR |= 0x01;                                                           //事件产生
  //TIM1_OISR |=0x00;                                                             //输出空闲高电平
  TIM1_BKR |= 0x80;                                                             //主动输出
  //TIM2_Config(Halfperiod);                                                    //接收设置
  PulsHi = (BurstCount + 6) * Halfperiod / 32;
  PulsLo = (BurstCount - 5) * Halfperiod / 32;
  rx_stat = 0;        //接收空闲
  TIM2_CCMR1 &= 0x0F;                                                           //无滤波器
  TIM2_CCER1_CC1P = 1;                                                         //低电平触发
  //TIM1_CR1 &= 0x8FD;
  TIM2_CCER1 |= 0x01;                                                           //使能捕获
  TIM2_IER = 0x02;                                                             //更新中断使能
  TIM2_CCMR1 |= 0x04;                                                           //通道选择
  tx_stat = 1;        //置位开始发送
  //TIM1_SR1 = 0;        //清除标志
  //TIM2_SR1 = 0;
  asm("rim");
  TIM1_EGR = 0x01;
  TIM1_IER = 0x02;                                                             //通道1比较允许
  TIM1_CR1 |= 0x01;                                                             //使能计数
  TIM2_CR1 |= 0x01;
  while (tx_stat != 0);                                                        //等待发送空闲状态结束
  //TIM1_CR1 &= 0xFE;
  //InCapture = (u16)TIM2_CCR1H <<8;
  //InCapture |=TIM2_CCR1L;
  switch (rx_stat)
    case 0:        //接收空闲
      TimeCount = -1;                                                           //无数据接收
      break;
    case 1:        //接收进行
      while(rx_stat == 1);
      //break;
    case 2:        //接收完成
      TimeCount = InCapture;                                                    //保存接收脉冲
      rx_stat = 0;
      if ( !((TimeCount > PulsLo) && (TimeCount < PulsHi)))                     //判断脉冲有效性
       TimeCount = 2;
      break;
  asm("sim");
  return TimeCount;
void GPIO_Config(void)
  PC_DDR_DDR6 = 1;
  PC_CR1_C16 = 1;
  PC_CR2_C26 = 0;
  PD_DDR_DDR4 = 0;
  PD_CR1_C14 = 1;
  PD_CR2_C24 = 0;
  PD_DDR_DDR3 = 1;
  PD_CR1_C13 = 1;
  PD_CR2_C23 = 0;
  PD_ODR_ODR3 = 0;
  PD_DDR_DDR2 = 1;
  PD_CR1_C12 = 1;
  PD_CR2_C22 = 0;
  PD_ODR_ODR2 = 1;
#pragma vector = 0x0C
__interrupt void TIM1_CAP_COM_IRQHandler(void)
  static u16 CarrierCount;
  CarrierCount ++;
  if(CarrierCount ++ >= 25)
  CarrierCount = 0;
  tx_stat = 0;        //发送结束
  PC_DDR_DDR6 = 0;
  TIM1_ClearITPendingBit(TIM1_IT_CC1);
#pragma vector = 0x0E
__interrupt void TIM2_CAP_COM_IRQHandler(void)
  u8 intCount = TIM2_CCER1_CC1P;
  TIM2_ClearFlag(TIM2_FLAG_CC1);
  switch(intCount)
  case 0:
    TIM2_CNTRH = 0;
    TIM2_CNTRL = 0;
    rx_stat = 1;        //开始接收
    break;
  case 1:
    InCapture |= TIM2_CCR1L;
    TIM2_CCER1_CC1P = 0;
    rx_stat = 0;        //发送结束
    //TIM1_BKR &= 0x7F;                                                         //停止输出
    //PC_ODR_ODR6 = 0;
    //PD_ODR_ODR3 = 0;
    //TIM1_CR1 &= 0xFE;
    break;
GMT+8, 2026-11-12 12:51
