查看: 10171|回复: 3
STM32 外部脉冲计数值不正确,求解
98
174
174
2014-3-5
发表于 2014-3-12 10:31:50 | 显示全部楼层 |阅读模式
使用的TIM4-CH2(PD.13)产生10K的PWM波,接入TIM1-ETR(PE.7),1ms后读取计数器的值,读的值与实际不符合,实际波形个数如图2所示
源码如下:
EXTI_InitTypeDef EXTI_InitStructure;
TIM_OCInitTypeDef  TIM_OCInitStructure;
void RCC_Configuration(void);
void GPIO_Configuration(void);
void NVIC_Configuration(void);
void Delay(__IO uint32_t nCount);
void tim1_confi(void);
void tim4_confi(void);
u16 Count_pulse(u16 c);
u16 counter=0;
int main(void)
// u8 i=0;
  /* System Clocks Configuration */
  RCC_Configuration();
  /* NVIC configuration */
  NVIC_Configuration();
  /* Configure the GPIO ports */
  GPIO_Configuration();
  /*Configure tim1*/
  tim1_confi();
  tim4_confi();
  while (1)
Delay(10000);  //1ms
TIM_Cmd(TIM1, ENABLE);
TIM_Cmd(TIM4, ENABLE);
Delay(10000);  //1ms
TIM_Cmd(TIM4, DISABLE);
TIM_Cmd(TIM1, DISABLE);
counter=TIM_GetCounter(TIM1);
//      for(i = 0; i < 4; i ++)
//  GPIO_SetBits(GPIOE, GPIO_Pin_8);
//  Delay(100); //15US
//  GPIO_ResetBits(GPIOE, GPIO_Pin_8);
//  Delay(100);
//  //counter=TIM_GetCounter(TIM1);
//  counter=TIM1->CNT;
void Delay(__IO uint32_t nCount)   //0.1us
  for(; nCount != 0; nCount--);
  SystemInit();
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE  | RCC_APB2Periph_AFIO, ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);  //使能定时器TIM1时钟
 GPIO_InitTypeDef  GPIO_InitStructure;
 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE, ENABLE); //使能PE端口时钟
 GPIO_PinRemapConfig (GPIO_FullRemap_TIM1 ,ENABLE );  //重映射
 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7; // 端口配置
 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //输入
 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //IO口速度为50MHz
 GPIO_Init(GPIOE, &GPIO_InitStructure); //根据设定参数初始化GPIOE.7
 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; //PE.8 端口配置
 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出
 GPIO_Init(GPIOE, &GPIO_InitStructure); //根据设定参数初始化GPIOE.8
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE); //使能PD端口时钟
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);  //使能定时器TIM4时钟
  GPIO_PinRemapConfig (GPIO_Remap_TIM4  ,ENABLE );  //重映射
  GPIO_InitStructure.GPIO_Pin=GPIO_Pin_13 ;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
 void tim1_confi(void)  //TIM1初始化
  TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
    TIM_DeInit( TIM1 ) ;
  /* Time Base configuration */
TIM_TimeBaseStructure.TIM_Period = 0XFFFF; //
TIM_TimeBaseStructure.TIM_Prescaler = 0;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
/* TIM1-ETR Configuration */
  TIM_ETRClockMode2Config (TIM1,TIM_ExtTRGPSC_OFF,TIM_ExtTRGPolarity_NonInverted,0);
TIM_SetCounter( TIM1,0) ; //从零计数
TIM_Cmd(TIM1, DISABLE); //使能打开
  void tim4_confi(void)  //TIM4初始化
 // TIM4-CH2基本计数器设置(设置PWM频率)
// 频率=TIM1_CLK/(ARR+1)
     TIM_TimeBaseInitTypeDef TIM_BaseInitStructure;
    TIM_DeInit( TIM4 ) ;
    TIM_BaseInitStructure.TIM_Period = 100;  // 确定T=0.1ms
    TIM_BaseInitStructure.TIM_Prescaler = 72-1;
    TIM_BaseInitStructure.TIM_ClockDivision = 0;
    TIM_BaseInitStructure.TIM_CounterMode = TIM_CounterMode_Up;
    TIM_BaseInitStructure.TIM_RepetitionCounter = 0;
    TIM_TimeBaseInit(TIM4, &TIM_BaseInitStructure);
 //启用ARR的影子寄存器(直到产生更新事件才更改设置)
TIM_ARRPreloadConfig(TIM4, ENABLE);
//TIM4_OC2模块设置
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
TIM_OCInitStructure.TIM_Pulse = 50;
TIM_OC2Init(TIM4, &TIM_OCInitStructure);
TIM_OC2PreloadConfig(TIM4, TIM_OCPreload_Enable);
//TIM3开启
//TIM1_OC通道输出PWM(一定要加)
TIM_CtrlPWMOutputs(TIM4, ENABLE);
Delay(1000);  //1ms
   counter=TIM_GetCounter(TIM1);  //只能读出最终值,采样的时钟要比输入信号快。
   c= counter;
  return c;
#ifdef  USE_FULL_ASSERT
void assert_failed(uint8_t* file, uint32_t line)
  while (1)
#endif
使用红色部分产生20us方波,然后连接PE.7作为输入,计数结果正常。。请问是不是对输入脉冲的频率有要求?
38
2061
3273
3273
2012-1-16
37 小时
发表于 2014-3-12 11:16:17 | 显示全部楼层
回复【楼主位】fangxiaoyanzhou:
那你降低频率看看。
站在巨人的肩膀上不断的前进。。。
98
174
174
2014-3-5
 楼主| 发表于 2014-3-12 12:55:19 | 显示全部楼层
回复【2楼】xiaoyan:
楼主,用定时器输出的方波周期为0.1ms,使用延时产生的方波周期为20us,输入方波的频率已经降低了。。
98
174
174
2014-3-5
 楼主| 发表于 2014-3-12 12:56:18 | 显示全部楼层
回复【2楼】xiaoyan:
http://www.amobbs.com/thread-4146690-1-1.html,参照这个,应该是正常的。。
GMT+8, 2026-11-12 13:03
