查看: 4826|回复: 1
[MDK使用] 阿波罗H743TFTLCD汉字显示测试程序(从片内FLASH读取汉字数据)
109
5532
10608
10608
2017-2-18
1921 小时
发表于 2018-12-1 18:33:18 | 显示全部楼层 |阅读模式
有用户问阿波罗H743,想利用片内FLASH显示汉字,所以基于阿波罗H743板子的RTC实时时钟实验移植了这个程序,相比源程序多了个TEXT文件夹,该文件夹下存放了与片内FLASH显示汉字相关函数的text.c和text.h,删减了与RTC相关的代码
程序适合阿波罗H743开发板,支持原子2.8寸/3.5寸/4.3寸MCU屏,7寸V2MCU屏和4.3寸/7寸10.1寸RGB屏
利用PCtoLCD2002生成“开” “发” “板”三个点阵库并存放在片内FLASH,这三个点阵库数据存放在text.c中
[mw_shl_code=c,true]//24*24的OLED汉字点阵,包括三个汉字:开、发、板。这三个汉字的点阵库,是利用PCtoLCD2002生产的,
//软件设置的取模方式同OLED实验ASCII的取模方式一样,字体采用24*24大小,一个汉字点阵占用72字节。
const u8 LCD_HZK_TBL[3][72]=
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x08,0x08,0x02,0x08,0x08,0x04,0x08,0x08,0x08,0x08,0x08,0x10,0x08,0x08,0xE0,
0x0F,0xFF,0x80,0x08,0x08,0x00,0x08,0x08,0x00,0x08,0x08,0x00,0x08,0x08,0x00,0x08,0x08,0x00,0x08,0x08,0x00,0x0F,0xFF,0xFE,
0x0F,0xFF,0xFE,0x08,0x08,0x00,0x08,0x08,0x00,0x10,0x08,0x00,0x10,0x10,0x00,0x00,0x30,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*"开",0*/
{0x00,0x00,0x00,0x00,0x00,0x02,0x00,0x00,0x04,0x01,0x80,0x08,0x0F,0x00,0x10,0x1C,0x80,0x60,0x00,0x81,0xC2,0x00,0x87,0x02,
0x00,0xFC,0x02,0x1F,0xF0,0x04,0x3C,0x9C,0x08,0x20,0x92,0x08,0x00,0x91,0x90,0x00,0x90,0x70,0x00,0x90,0x60,0x20,0x91,0x90,
0x10,0x93,0x18,0x1C,0x9C,0x08,0x0C,0x98,0x0C,0x00,0x80,0x04,0x01,0x00,0x06,0x01,0x00,0x04,0x00,0x00,0x04,0x00,0x00,0x00},/*"发",1*/
{0x00,0x00,0x00,0x00,0x00,0xC0,0x01,0x01,0x00,0x01,0x0E,0x00,0x01,0xF8,0x00,0x3F,0xFF,0xFE,0x21,0x20,0x00,0x01,0x10,0x02,
0x02,0x0C,0x0E,0x00,0x00,0x12,0x00,0x07,0xE4,0x0F,0xFE,0x04,0x08,0x40,0x08,0x08,0x78,0x10,0x08,0x47,0x30,0x08,0x41,0xE0,
0x10,0x41,0xE0,0x10,0x47,0x30,0x30,0x7C,0x18,0x30,0xE0,0x0C,0x10,0x00,0x0C,0x00,0x00,0x04,0x00,0x00,0x00,0x00,0x00,0x00},/*"板",2*/
};[/mw_shl_code]
整个程序最重要的是LCD_Show_Font()这个函数就是用来支持从片内FLASH读取汉字点阵库并显示在液晶上
[mw_shl_code=c,true]//在指定位置,显示一个24*24大小的汉字
//x,y :汉字的坐标
//index:汉字编号(在字库数组里面的编号)
void LCD_Show_Font(u16 x,u16 y,u8 index)
        u8 temp,t,t1;
        u16 y0=y;
        u8 *dzk;
        u8 csize=72;                                        //一个24*24的汉字72字节
        dzk=(u8*)LCD_HZK_TBL[index];        //得到汉字编号对应的点阵库
        for(t=0;t<csize;t++)
                temp=dzk[t];                                //得到点阵数据
                for(t1=0;t1<8;t1++)                        //按照从高位到低位的顺序画点
                        if(temp&0x80)LCD_Fast_DrawPoint(x,y,POINT_COLOR);
                        else LCD_Fast_DrawPoint(x,y,BACK_COLOR);
                        temp<<=1;
                        y++;
                        if((y-y0)==24)                        //对y坐标的处理,当y坐标距起始坐标差24个像素点,x坐标加1
                                y=y0;
                                x++;
                                break;
}[/mw_shl_code]
main()如下
[mw_shl_code=c,true]int main(void)
        HAL_Init();                                                        //初始化HAL库
        Stm32_Clock_Init(160,5,2,4);                      //设置时钟,400Mhz
        delay_init(400);                                                //延时初始化
        uart_init(115200);                                                //串口初始化
        LED_Init();        //初始化LED
        SDRAM_Init();                                   //初始化SDRAM
        LCD_Init();        //初始化LCD
          POINT_COLOR=RED;
    POINT_COLOR=RED;
        LCD_Show_Font(100,40,0);
        LCD_Show_Font(100,80,1);
        LCD_Show_Font(100,120,2);
        LCD_ShowString(75,180,150,24,24,"ALIENTEK");
        LCD_ShowString(75,210,150,24,24,"Apollo STM32");
                delay_ms(500);
                LED1_Toggle;
}[/mw_shl_code]
阿波罗H743TFTLCD汉字显示测试程序(从片内FLASH读取汉字数据).rar
25.45 MB, 下载次数: 99
2020-5-3
发表于 2020-5-20 20:25:28 | 显示全部楼层
谢谢分享,学习一下
GMT+8, 2026-10-31 08:58
