查看: 5099|回复: 1
悟空四轴姿态控制
2018-7-11
发表于 2019-1-22 10:32:32 | 显示全部楼层 |阅读模式
悟空大四轴的姿态控制,用到了位置PID,有什么作用。
//姿态控制
void stateControl(const sensorData_t *sensorData, const state_t *state, setpoint_t *setpoint, control_t *control, const u32 tick)
        //位置PID
        if (RATE_DO_EXECUTE(POSITION_PID_RATE, tick))
                //Z轴
                if (setpoint->mode.z == modeAbs)
                        setpoint->velocity.z = pidUpdate(&pid[POSHOLD_Z], setpoint->position.z - state->position.z);
                //XY轴
        //速度PID
        if (RATE_DO_EXECUTE(VELOCITY_PID_RATE, tick))
                //Z轴
                if (setpoint->mode.z != modeDisable)
                        altThrustAdj = pidUpdate(&pid[VELOCITY_Z], setpoint->velocity.z - state->velocity.z);
                        altHoldThrust = altThrustAdj + commanderGetALtHoldThrottle();
                //XY轴
        //角度PID(外环)
        if (RATE_DO_EXECUTE(ANGLE_PID_RATE, tick))
                if (setpoint->mode.x == modeDisable || setpoint->mode.y == modeDisable)
                        attitudeDesired.roll = setpoint->attitude.roll;
                        attitudeDesired.pitch = setpoint->attitude.pitch;
                rateDesired.roll = pidUpdate(&pid[ANGLE_ROLL], attitudeDesired.roll - state->attitude.roll);
                rateDesired.pitch = pidUpdate(&pid[ANGLE_PITCH], attitudeDesired.pitch - state->attitude.pitch);
                if (setpoint->attitudeRate.yaw == 0)//yaw遥杆在中位
                        if (attitudeDesired.yaw == 0)//偏航后yaw遥杆并回中时
                                attitudeDesired.yaw = state->attitude.yaw;//锁定当前航向角
                        float yawError = attitudeDesired.yaw - state->attitude.yaw;
                        if (yawError >= +180)
                                yawError -= 360;
                        if (yawError <= -180)
                                yawError += 360;
                        rateDesired.yaw = pidUpdate(&pid[ANGLE_YAW], yawError);
                else//偏航时只进行角速度环控制
                        attitudeDesired.yaw = 0;
                        rateDesired.yaw = setpoint->attitudeRate.yaw;
        //角速度PID(内环)
        if (RATE_DO_EXECUTE(RATE_PID_RATE, tick))
                //速率模式则断开外环
                if (setpoint->mode.roll == modeVelocity || setpoint->mode.pitch == modeVelocity)
                        rateDesired.roll = setpoint->attitudeRate.roll;
                        rateDesired.pitch = setpoint->attitudeRate.pitch;
                        pidReset(&pid[ANGLE_ROLL]);
                        pidReset(&pid[ANGLE_PITCH]);
     //如果油门值小于MINCHECK时即怠速状态,清除PID积分,防止积分累计导致电机转速不一致
                if(rcCommand[THROTTLE] <= RC_COMMANDER_MINCHECK)
                        pidResetIntegral(&pid[RATE_ROLL]);
                        pidResetIntegral(&pid[RATE_PITCH]);
                        pidResetIntegral(&pid[RATE_YAW]);
                        stateControlResetYawHolding();//复位航向角锁定
                control->roll = pidUpdate(&pid[RATE_ROLL], rateDesired.roll - sensorData->gyro.x);
                control->pitch = pidUpdate(&pid[RATE_PITCH], rateDesired.pitch - sensorData->gyro.y);
                control->yaw = pidUpdate(&pid[RATE_YAW], rateDesired.yaw - sensorData->gyro.z);
        //油门
        if (setpoint->mode.z == modeDisable)
                control->thrust = setpoint->thrust;
                control->thrust = altHoldThrust;
168
286
286
2018-12-31
12 小时
发表于 2019-1-22 10:54:10 | 显示全部楼层
多谢楼主分享啊!
GMT+8, 2026-11-11 00:49
