查看: 4742|回复: 1
emWin526内置驱动问题
2019-2-15
发表于 2019-2-15 15:26:22 | 显示全部楼层 |阅读模式
用emWin526内置驱动驱动128*64的OLED,控制器是SSD1306的.根据手册配置,选择带缓存的
配置代码如下:
[mw_shl_code=applescript,true]#define XSIZE_PHYS 128
#define YSIZE_PHYS 64
#define COLOR_CONVERSION GUICC_1
#define DISPLAY_DRIVER GUIDRV_SPAGE_1C1
void LCD_X_Config(void) {
  CONFIG_SPAGE Config = {0};
  GUI_DEVICE * pDriver;
  #ifndef WIN32
    GUI_PORT_API PortAPI = {0};
  #endif
  // Set display driver and color conversion for 1st layer
  pDriver = GUI_DEVICE_CreateAndLink(DISPLAY_DRIVER, COLOR_CONVERSION, 0, 0);
  // Display size configuration
  if (LCD_GetSwapXY()) {
    LCD_SetSizeEx (0, YSIZE_PHYS,   XSIZE_PHYS);
    LCD_SetVSizeEx(0, VYSIZE_PHYS,  VXSIZE_PHYS);
  } else {
    LCD_SetSizeEx (0, XSIZE_PHYS,   YSIZE_PHYS);
    LCD_SetVSizeEx(0, VXSIZE_PHYS,  VYSIZE_PHYS);
  // Driver configuration
  Config.FirstSEG = 0;
  Config.FirstCOM = 0;
  GUIDRV_SPage_Config(pDriver, &Config);
  // Configure hardware routines
        PortAPI.pfWrite8_A0 = WriteCmd; // Write CMD
        PortAPI.pfWrite8_A1 = WriteDat; // Write sigle data
        PortAPI.pfWriteM8_A1 = WriteDatM; // Write multi data
        PortAPI.pfReadM8_A1 = 0; // No need to read
        GUIDRV_SPage_SetBus8(pDriver, &PortAPI);
  // Controller configuration
        GUIDRV_SPage_Set1510(pDriver); // SSD1306
}[/mw_shl_code]
现在问题是鼠标移动拖尾,查看手册
按手册说的我这样配置应该是开启显示缓存了吧,弄了好几天了还是不行,来论坛求助一下
发表于 2019-2-16 01:06:05 | 显示全部楼层
GMT+8, 2026-11-28 16:45
