查看: 6113|回复: 5
[探索者F407] 探索者F407+TIM1(CH1CH2CH3CH4)-PE9PE11PE13PE14输出4路PWM测试程序
109
5532
10608
10608
2017-2-18
1921 小时
发表于 2019-2-20 18:59:08 | 显示全部楼层 |阅读模式
有人问到F407TIM1进行PWM输出的问题
https://www.openedv.com/forum.php ... mp;page=1#pid930029
可以用附件中的程序进行测试,测试程序基于探索者F407板子
整个工程最重要的是TIM1_PWM_Init(),具体如下:
[mw_shl_code=c,true]//TIM1 PWM部分初始化
//arr:自动重装值
//psc:时钟预分频数
void TIM1_PWM_Init(u16 arr,u16 psc)
    GPIO_InitTypeDef  GPIO_InitStructure;
    TIM_OCInitTypeDef  TIM_OCInitStructure;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1,ENABLE);            //TIM1时钟使能
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOE,ENABLE);           //使能PORTE时钟
    GPIO_PinAFConfig(GPIOE,GPIO_PinSource9,GPIO_AF_TIM1);          //GPIOE9复用为定时器1
        GPIO_PinAFConfig(GPIOE,GPIO_PinSource11,GPIO_AF_TIM1);        //GPIOE11复用为定时器1
        GPIO_PinAFConfig(GPIOE,GPIO_PinSource13,GPIO_AF_TIM1);        //GPIOE13复用为定时器1
        GPIO_PinAFConfig(GPIOE,GPIO_PinSource14,GPIO_AF_TIM1);        //GPIOE14复用为定时器1
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9|GPIO_Pin_11|GPIO_Pin_13|GPIO_Pin_14;          //GPIOE9,GPIOE11,GPIOE13,GPIOE14
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;       //复用功能
    GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;     //推挽复用输出
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;   //不上下拉
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz; //速度100MHz
    GPIO_Init(GPIOE,&GPIO_InitStructure);              //初始化PE9,PE11,PE13,PE14
        TIM_TimeBaseStructure.TIM_Prescaler = psc;                                     //定时器分频
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;            //向上计数模式
        TIM_TimeBaseStructure.TIM_Period = arr;                                //自动重装载值
        TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
        TIM_TimeBaseInit(TIM1,&TIM_TimeBaseStructure);                           //初始化定时器1
    //初始化TIM1 Channel1,2,3,4 PWM模式
    TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;                             //选择定时器模式:TIM脉冲宽度调制模式2
    TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;          //比较输出使能
    TIM_OCInitStructure.TIM_Pulse = arr;
    TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;                  //输出极性高
        TIM_OC1Init(TIM1, &TIM_OCInitStructure);    //根据T指定的参数初始化外设OC1
        TIM_OC2Init(TIM1, &TIM_OCInitStructure);        //根据T指定的参数初始化外设OC2
        TIM_OC3Init(TIM1, &TIM_OCInitStructure);    //根据T指定的参数初始化外设OC3
        TIM_OC4Init(TIM1, &TIM_OCInitStructure);         //根据T指定的参数初始化外设OC4
        TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable);   //使能TIM1在CCR1上的预装载寄存器
        TIM_OC2PreloadConfig(TIM1, TIM_OCPreload_Enable);        //使能TIM1在CCR2上的预装载寄存器
        TIM_OC3PreloadConfig(TIM1, TIM_OCPreload_Enable);        //使能TIM1在CCR3上的预装载寄存器
        TIM_OC4PreloadConfig(TIM1, TIM_OCPreload_Enable);        //使能TIM1在CCR4上的预装载寄存器
        TIM_ARRPreloadConfig(TIM1,ENABLE);                        //ARPE使能
        TIM_CtrlPWMOutputs(TIM1,ENABLE);                         //使能TIM1的PWM输出
        TIM_Cmd(TIM1,ENABLE);                                                //使能TIM1
}[/mw_shl_code]main函数中调用TIM_SetComparex()来设置占空比
[mw_shl_code=c,true]int main(void)
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//设置系统中断优先级分组2
        delay_init(168);  //初始化延时函数
        TIM1_PWM_Init(500-1,168-1);        //84M/84=1Mhz的计数频率,重装载值500,所以PWM频率为 1M/500=2Khz.
        TIM_SetCompare1(TIM1,250);        //修改占空比
        TIM_SetCompare2(TIM1,250);        //修改占空比
        TIM_SetCompare3(TIM1,250);        //修改占空比
        TIM_SetCompare4(TIM1,250);        //修改占空比
}[/mw_shl_code]
探索者F407 TIM1(CH1CH2CH3CH4)-PE9PE11PE13PE14输出PWM.rar
3.03 MB, 下载次数: 374
168
286
286
2018-12-31
12 小时
发表于 2019-2-21 11:13:17 | 显示全部楼层
很好的啊!!!!
631
1341
1341
2016-8-1
230 小时
发表于 2019-2-21 16:48:26 | 显示全部楼层
谢谢分享
46
46
2017-9-7
15 小时
发表于 2019-11-19 12:27:06 | 显示全部楼层
39
39
2019-8-4
18 小时
发表于 2020-9-11 16:46:46 | 显示全部楼层
谢谢分享
39
39
2019-8-4
18 小时
发表于 2020-9-12 08:54:17 | 显示全部楼层
你好 ,大神,有输出互补的PWM的程序能分享一下吗
GMT+8, 2026-10-31 08:58
