查看: 9625|回复: 15
ENC424J600驱动无法ping通
214
214
2017-2-16
69 小时
发表于 2019-2-23 16:16:11 | 显示全部楼层 |阅读模式
ENC424J600驱动无法ping通,求助
网上找了一份底层配置代码,但是无法ping通
//enc424j600 driver
//20110822
//hubing
#include "enc424j600.h"
static u8 Enc424j600Bank;
static u16 NextPacketPtr;
extern void delay_mS(u16 time_ms);
// 函数名                     : SPI1_ETHERNET_Init
//描述           : 配置 SPI1
//入口参数       : None
//出口参数       : None
//返回           : None
void SPI1_ETH_Init (void)
  SPI_InitTypeDef  SPI_InitStructure;
  //------ Enable SPI1 GPIOA and GPIOB clocks
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1 | RCC_APB2Periph_GPIOA |RCC_APB2Periph_GPIOD, ENABLE);
  //------ Configure SPI1 pins: NSS=PA4, SCK=PA5, MISO=PA6 and MOSI=PA7
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
/*   //MISO为浮空输入
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_6 ;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  GPIO_Init(GPIOA, &GPIO_InitStructure);          */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;        //  区别于别的SPI
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOD, &GPIO_InitStructure);        //GPIOD
  SPI1_ENC424J600_CS_HIGH();
  SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
  SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;//=0 逻辑低电平出于空闲状态         0,0模式
  SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;//=0
  SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;         //=1
  SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_8;
  SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; //=0
  SPI_InitStructure.SPI_CRCPolynomial = 7;
  SPI_Init(SPI1, &SPI_InitStructure);
  SPI_Cmd(SPI1, ENABLE);
u8 SPI1_ETH_SendByte(u8 byte)
  while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);
  SPI_I2S_SendData(SPI1, byte);
  while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET);
  return SPI_I2S_ReceiveData(SPI1);
void enc424j600SetBank(unsigned char address)
        // set the bank (if needed)
        if((address & BANK_MASK) != Enc424j600Bank)
        // set the bank
            SPI1_ENC424J600_CS_LOW();
            SPI1_FRAM_CS_HIGH();
        SPI1_FLASH_CS_HIGH();
//            delay_mS(5);
        SPI1_ETH_SendByte(((address & BANK_MASK)>>4)|0xC0);
        Enc424j600Bank = (address & BANK_MASK);
unsigned char enc424j600ReadOp(unsigned char op, unsigned char address)
        unsigned char dat = 0;
//         delay_mS(5);
        dat = op | (address & ADDR_MASK);
        SPI1_ETH_SendByte(dat);
        dat = SPI1_ETH_SendByte(0xFF);
        // do dummy read if needed (for mac and mii, see datasheet page 29)
        if(address & 0x80)
        // release CS
        return dat;
void enc424j600WriteOp(unsigned char op, unsigned char address, unsigned char data)
        //        unsigned char temp = 0;
//        delay_mS(1);
        // issue write command
        // write data
        dat = data;
//        delay_mS(5);
unsigned char enc424j600Read(unsigned char address)
        // set the bank
        enc424j600SetBank(address);
        // do the read
        return enc424j600ReadOp(ENC424j600_READ_CTRL_REG, address);
void enc424j600Write(unsigned char address, unsigned char data)
        // set the bank
        // do the write
        enc424j600WriteOp(ENC424j600_WRITE_CTRL_REG, address, data);
//读写SRAM的操作指令         op 只能是读写指针指令
unsigned int enc424j600ReadSRAM_op(unsigned char op)
        unsigned int dat  = 0;
        unsigned int temp = 0;
//        delay_mS(5);
        SPI1_ETH_SendByte(op);
        temp = SPI1_ETH_SendByte(0xFF);
        dat = ((temp<<8)|dat);
        // release CS
        return dat;
void enc424j600WriteSRAM_op(unsigned char op, unsigned int data)          //write EGPRDPT etc....        三字节指令
//        delay_mS(5);
        dat = data;
        temp = (data>>8);
        SPI1_ETH_SendByte(temp);
        // release CS
//读写数据
void enc424j600ReadBuffer(u8 op, unsigned int len, unsigned char* data)
//        delay_mS(5);
        // issue read command
        while(len)
        len--;
        // read data
        *data = (unsigned char)SPI1_ETH_SendByte(0);
        data++;
void enc424j600WriteBuffer(u8 op, unsigned int len, unsigned char* data)
//        delay_mS(5);
        SPI1_ETH_SendByte(op);  //N字节指令 写通用SRAM发送寄存器
        while(len)
                len--;
                SPI1_ETH_SendByte(*data);
                data++;
//读写SRAM的操作指令
void enc424j600PhyWrite(unsigned char address, unsigned int data)
        // set the PHY register address
        enc424j600Write(MIREGADRL, address);
        enc424j600Write(MIREGADRH, 0x01);        //bit8保留位置一,区别去enc28j60
        // write the PHY data
        enc424j600Write(MIWRL, data);
        enc424j600Write(MIWRH, data>>8);
        // wait until the PHY write completes
        while(enc424j600Read(MISTATL) & MISTAT_BUSY)
                    //Del_10us(1);
                        //_nop_();
u16 enc424j600PhyRead(unsigned char address)
        u16 temp;
//        u8 dat         ;
        enc424j600Write(MIREGADRH, 0x01);        //bit8保留位置一,区别于enc28j60
        enc424j600Write(MICMDL,0x01);           //读一次MIREGADR<4:0> 指定的PHY 寄存器,并把数据复制到MIRD
        while(enc424j600Read(MISTATL) & MISTAT_BUSY)           //等待busy位变成0
                    //Del_10us(1);
                        //_nop_();
        temp = enc424j600Read(MIRDL);
        temp |= enc424j600Read(MIRDH)<<8;
        return temp;
void enc424j600clkout(unsigned char clk)
  //setup clkout: 2 is 12.5MHz:
        enc424j600Write(ECON2H, clk & 0xF);
void enc424j600Init(unsigned char* macaddr)
        // initialize I/O
        //enc28j60CSinit();
//        delay_mS(1);
    //enc28j60SetSCK();
    //enc28j60HWreset();
        // perform system reset
    SPI1_ETH_SendByte(SETETHRST);
        delay_mS(2);
        // check CLKRDY bit to see if reset is complete
        // The CLKRDY does not work. See Rev. B4 Silicon Errata point. Just wait.
        //while(!(enc28j60Read(ESTAT) & ESTAT_CLKRDY));
        // do bank 0 stuff
        // initialize receive buffer
        // 16-bit transfers, must write low byte first
        // set receive buffer start address
        NextPacketPtr = RXSTART_INIT;                  //接收指针初始化
        // Rx FIFO start
        enc424j600Write(ERXSTL, RXSTART_INIT&0xFF);    //接收缓冲区FIFO起始地址
        enc424j600Write(ERXSTH, RXSTART_INIT>>8);
        //RX 尾指针
        enc424j600Write(ERXTAILL, 0xFE);           //
        enc424j600Write(ERXTAILH, 0x5F);
        enc424j600Write(ECON2L,0x0F);
        enc424j600Write(ECON2H,0xDD);           //禁止         时钟输出
        // do bank 1 stuff, packet filter:
        // For broadcast packets we allow only ARP packtets
        // All other packets should be unicast only for our mac (MAADR)
        // The pattern to match on is therefore
        // Type     ETH.DST
        // ARP      BROADCAST
        // 06 08 -- ff ff ff ff ff ff -> ip checksum for theses bytes=f7f9
        // in binary these poitions are:11 0000 0011 1111
        // This is hex 303F->EPMM0=0x3f,EPMM1=0x30
                                //UCEN接受目标地址与本地MAC 地址匹配的数据包,丢弃具有无效CRC 的数据包
    enc424j600Write(ERXFCONL,ERXFCONL_UCEN|ERXFCONL_CRCEN|ERXFCONL_RUNTEN|ERXFCONL_NOTEMEEN|ERXFCONL_MCEN);
        enc424j600Write(ERXFCONH, 0x00);//ERXFCONH_PMEN0);
//        接受具有NOTPM 定义的校验和匹配的所有数据包(1)NOTPM 0 = 成功的模式匹配要求模式匹配校验和匹配
//        enc28j60Write(EPMM1L, 0x3f);
//        enc28j60Write(EPMM1H, 0x30);
//        enc28j60Write(EPMCSL, 0xf9);
//        enc28j60Write(EPMCSH, 0xf7);
//        USART_SendData(USART1,(u8)(enc28j60Read(EPMCSH)));
                // DO HERE TO CONTINUE 110929
        // do bank 2 stuff
        // enable MAC receive
        enc424j600Write(MACON1L, 0x0D);            //MAC 或MII 寄存器,必须先写低字节再写髙字节         !!!!!不支持位操作
        enc424j600Write(MACON1H, 0x00);
        // bring MAC out of reset
        // enable automatic padding to 60bytes and CRC operations
//        enc28j60WriteOp(ENC28J60_BIT_FIELD_SET, MACON2L, MACON2L_PADCFG0|MACON2L_TXCRCEN|MACON2L_FULDPX);
    enc424j600Write(MACON2L,0xB3);
        //101 = MAC自动检测具有8100h 类型字段的VLAN 协议帧,并自动填充到64 字节长。 如果不是VLAN
//帧,则填充至60 字节长。 填充后还要追加一个有效的CRC。        不管PADCFG位如何,MAC都会在发送帧的末尾追加一个有效的CRC。 如果PADCFG位指定要追加有效的CRC
        enc424j600Write(MACON2H,0x00);
        //        使能MAC 插入(TXMAC = 1)使能自动填充(PADCFG<2:0> = 101)使能CRC 生成(TXCRCEN = 1)
        //MACON2L_FULDPX=1 MAC 工作在全双工模式下。 要确保正确操作, PHY 也必须设置为全双工模式。
        // MACON2L_TXCRCEN=1不管PADCFG位如何,MAC都会在发送帧的末尾追加一个有效的CRC。 如果PADCFG位指定要追
    //加有效的CRC,则必须将TXCRCEN 置1。
        //        MACON2L_PADCFG0=1用0 填充所有短帧至60 字节长,并追加一个有效的CRC
        // set inter-frame gap (non-back-to-back)
        enc424j600Write(MAIPGL, 0x12);   // 非背对背包间间隔延时控制位
        enc424j600Write(MAIPGH, 0x0C);
  //         USART_SendData(USART1,(u8)(enc28j60Read(MAIPGH)));
        // set inter-frame gap (back-to-back)
        enc424j600Write(MABBIPGL, 0x15);
        enc424j600Write(MABBIPGH, 0x00);
        //        当FULDPX (MACON2<0>) = 1 时:
//在背对背序列中,从前一次发送结束到下一次发送开始之间有半字节时间的延时。 应使用整数倍的半字
//节时间减3 对该寄存器的值进行编程。建议将该值设置为15h,表示IEEE 规定的最小包间间隔(IPG)
//时间为0.96 μs (速度为100 Mb/s 时)或9.6 μs (速度为10 Mb/s 时)。
        // Set the maximum packet size which the controller will accept
        // Do not send packets longer than MAX_FRAMELEN:
        enc424j600Write(MAMXFLL, MAX_FRAMELEN&0xFF);
        enc424j600Write(MAMXFLH, MAX_FRAMELEN>>8);
        // do bank 3 stuff
        // write MAC address
        // NOTE: MAC address in ENC28J60 is byte-backward
        enc424j600Write(MAADR1L, macaddr[0]);
        enc424j600Write(MAADR1H, macaddr[1]);
        enc424j600Write(MAADR2L, macaddr[2]);
        enc424j600Write(MAADR2H, macaddr[3]);
        enc424j600Write(MAADR3L, macaddr[4]);
        enc424j600Write(MAADR3H, macaddr[5]);
        enc424j600Write(ECON1H,0x06);
        enc424j600Write(EIDLEDH,0x67);        //设置灯的闪烁方式
//        显示双工模式状态,当有链路且PHY 为全双工模式(即PHYDPX(ESTAT<10> 为1)时,引脚驱动为高电平
//0110 = 显示发送和接收事件;正在发送或接收数据包时,引脚驱动为高电平
        enc424j600PhyWrite(PHCON1, PHCON1_PDPXMD|PHCON1_SPD100);          //  当MACON3.FULDPX=l和PHCONI.PDPXMD=l时,ENC28J60工作在全双工模式下。
        enc424j600PhyWrite(PHANA, 0x05E1); //
   // no loopback of transmitted frames
//        enc28j60PhyWrite(PHCON2, PHCON2_HDLDIS);        //
/*        ETHERNET_Rx_Buffer[0] =  enc28j60PhyRead(PHCON2);
        ETHERNET_Rx_Buffer[1] =  (enc28j60PhyRead(PHCON2)>>8);
        USART_SendData(USART1,(u8)ETHERNET_Rx_Buffer[0]);
        USART_SendData(USART1,(u8)ETHERNET_Rx_Buffer[1]);         */
        // switch to bank 0
        enc424j600SetBank(ECON1L);
        // enable interrutps
        enc424j600WriteOp(ENC424j600_BIT_FIELD_SET, EIEL, EIEL_PKTIE);
        //INT 引脚由INT 状态位(ESTAT<15>)控制
        //ESTAT<15>  1 = EIR 的其中一位被置1且由EIE寄存器允许相应中断。 如果INTIE(EIE<15>)被置1,则INT引脚也被驱动为低电平。
        enc424j600WriteOp(ENC424j600_BIT_FIELD_SET, EIEH, EIEH_INTIE);
        // enable packet reception
        enc424j600WriteOp(ENC424j600_BIT_FIELD_SET, ECON1L, ECON1L_RXEN);         //1 = 通过当前接收过滤器配置的数据包被写入接收缓冲区
unsigned char enc424j600getrev(void)
        return(enc424j600Read(EIDLEDL));
void enc424j600PacketSend(unsigned int len, unsigned char* packet)
    enc424j600WriteSRAM_op(WGPWRPT,TXSTART_INIT);
    enc424j600Write(ETXLENL, len&0xFF);
        enc424j600Write(ETXLENH, len>>8);
        enc424j600WriteBuffer(W_EGPDATA,len, packet);
    enc424j600WriteOp(ENC424j600_BIT_FIELD_SET, ECON1L, ECON1L_TXRTS);          //使能发送
  //   USART_SendData(USART1,(u8)enc28j60Read(ETXWIREL));         //统计实际发送的字节数
//         USART_SendData(USART1,(u8)enc28j60Read(ETXWIREH));
    // Reset the transmit logic problem. See Rev. B4 Silicon Errata point 12.
        if( (enc424j600Read(EIRL) & EIEL_TXABTIE) )                 //1 = 因错误而中止数据包发送。 读取ETXSTAT 寄存器来确定原因。 TXRTS(ECON1<1>)已由硬件清0
        enc424j600WriteOp(ENC424j600_BIT_FIELD_CLR, ECON1L, ECON1L_TXRTS);        //终止发送
// Gets a packet from the network receive buffer, if one is available.
// The packet will by headed by an ethernet header.
//      maxlen  The maximum acceptable length of a retrieved packet.
//      packet  Pointer where packet data should be stored.
// Returns: Packet length in bytes if a packet was retrieved, zero otherwise.
unsigned int enc424j600PacketReceive(unsigned int maxlen, unsigned char* packet)
        unsigned char rxdata[6];
        unsigned int len;
        u16 newRXTail;
    if (!(enc424j600Read(EIRL) & EIRL_PKTIF))
        return (0);
    // Set the RX Read Pointer to the beginning of the next unprocessed packet
    enc424j600WriteSRAM_op(WRXRDPT,NextPacketPtr);
        enc424j600ReadBuffer(R_ERXDATA,2, rxdata);
        NextPacketPtr  =  rxdata[1];
        NextPacketPtr  =  NextPacketPtr<<8;
        NextPacketPtr  |=  rxdata[0];         //下一数据包指针的首地址
        enc424j600ReadBuffer(R_ERXDATA,6, rxdata);
        len  =  rxdata[1];
        len  =  len<<8;
        len  |=  rxdata[0];         //数据包长度
        len-=4;
    if ((rxdata[2] & 0x80)==0)
                // invalid
                len=0;
         if (len>maxlen-1)
                  len=maxlen-1;
        enc424j600ReadBuffer(R_ERXDATA,len,packet);
    newRXTail = NextPacketPtr - 2;
    //Special situation if nextPacketPointer is exactly RXSTART
    if (NextPacketPtr == RXSTART_INIT)
        newRXTail = 0x5FFE - 2;
    //Packet decrement
    enc424j600Write(ECON1H, ECON1H_PKTDEC);
    //Write new RX tail
    enc424j600Write(ERXTAILL, newRXTail);           //
        enc424j600Write(ERXTAILH, newRXTail>>8);
    return len;
68
237
237
2016-6-22
50 小时
发表于 2019-2-23 18:16:46 | 显示全部楼层
回帖奖励 +2 金钱
你得把你得原理图展出来,不知道你用的什么开发板啊。
214
214
2017-2-16
69 小时
 楼主| 发表于 2019-2-25 09:36:39 | 显示全部楼层
自己画的板子,硬件没有问题的
168
286
286
2018-12-31
12 小时
发表于 2019-2-25 11:50:15 | 显示全部楼层
214
214
2017-2-16
69 小时
 楼主| 发表于 2019-2-26 15:47:38 | 显示全部楼层
求助求助,很急
2019-2-25
发表于 2019-2-27 10:56:36 | 显示全部楼层
我用示波器看了下,我用的芯片是STM32H743+enc424j600我的也不行写通过示波器查看的MOSI线上的数据是对的,但是MISO读取的时候就不对
判断条件根据STM32H743的HAL库做了相应修改,但是读不到数据,显示读取错误。
214
214
2017-2-16
69 小时
 楼主| 发表于 2019-2-27 16:29:17 | 显示全部楼层
兆鹏 发表于 2019-2-27 10:56
我用示波器看了下,我用的芯片是STM32H743+enc424j600我的也不行写通过示波器查看的MOSI线上的数据是对的, ...
我的SPI通信是通的,可以写入并且正常读出来,应该是配置文件不对,ping不通
214
214
2017-2-16
69 小时
 楼主| 发表于 2019-2-28 09:35:05 | 显示全部楼层
已解决,配置自动插入MAC源地址,导致ping不通,取消该寄存器的配置即可
2019-2-25
发表于 2019-2-28 15:41:55 | 显示全部楼层
修改了SPI引脚配置及SPI_HandleTypeDef SPI1_Handle;
     u8 byte1 = 0;
     HAL_StatusTypeDef status = HAL_SPI_TransmitReceive(&SPI1_Handle,&byte,&byte1,1,HAL_MAX_DELAY);
    return byte1;
后我的读写SPI寄存器验证过,都正常。但是发现enc424j600Init()函数关于PHY引脚的修改函数还是不行,我是通过写前读,写后读来验证的,发现始终返回的0x1000,不论PHY如何修改,请问是怎末回事?
注:(我所使用的为STM32H743+ENC424J600)
2019-2-25
发表于 2019-2-28 16:53:08 | 显示全部楼层
在配置ECON2H的时候ECON2H=0xDD, ECON2<13>(TXMAC=0)本身不就是设置的0,不自动插入源地址。怎么会配置自动插入MAC源地址,导致ping不通呢?
214
214
2017-2-16
69 小时
 楼主| 发表于 2019-3-4 14:08:23 | 显示全部楼层
读函数不正确,按照原子哥提供的代码对应修改即可
92
92
2018-12-16
28 小时
发表于 2020-3-8 19:24:47 | 显示全部楼层
楼主能把这份驱动分享给我吗923155082@qq.com,谢谢
153
153
2020-3-7
25 小时
发表于 2021-7-10 17:32:05 | 显示全部楼层
楼主,这两个是控制哪两个引脚的啊
153
153
2020-3-7
25 小时
发表于 2021-8-25 11:39:11 | 显示全部楼层
楼主还在吗?我现在也在用这个芯片,有些问题需要请教
153
153
2020-3-7
25 小时
发表于 2021-9-1 15:52:53 | 显示全部楼层
楼主,我也是按照你这个驱动程序,也是ping不通,可以指教一下吗
153
153
2020-3-7
25 小时
发表于 2021-9-2 15:59:38 | 显示全部楼层
楼主,怎么我按照你的这样写还是PING不通呢,能留个联系方式指导一下吗
GMT+8, 2026-11-4 02:51
