查看: 6835|回复: 5
STC89C52做的频率计,测量结果不对,求助!!
2019-5-7
发表于 2019-5-15 10:59:38 | 显示全部楼层 |阅读模式
这个里面我用了两块板子,一块作为信号发生部分,一块作为检测部分。
信号发生部分代码如下:
#include <reg52.h>
sbit out = P2^7;
sbit led5 = P1^4;
sbit led6 = P1^5;
sbit led7 = P1^6;
sbit key1 = P3^3;
sbit key2 = P3^4;
sbit led_s1 = P1^0;
sbit led_s2 = P1^1;
sbit led_s3 = P1^2;
sbit led_s4 = P1^3;
unsigned int cnt = 0;
unsigned int ctl_freq = 100;
//共阳极数码管真值表
unsigned char code buf[10] = {
                0xc0,0xf9,0xa4,0xb0,0x99,
                0x92,0x82,0xf8,0x80,0x90
void delay_10ms(void)   //误差 -0.000000000023us
    unsigned char a,b;
    for(b=249;b>0;b--)
        for(a=17;a>0;a--);
void delay_100us(void)   //误差 -0.217013888889us
    unsigned char a,b;
        for(b=1;b>0;b--)
        for(a=43;a>0;a--);
名称:数码管显示函数
功能:显示获取的温湿度值
参数:
    @ temp: 高两位显示的值
    @ humi: 低两位显示的值
void show(unsigned int y)
    char one = y%10;
    char ten = y/10%10;
    char hun = y/100%10;
    char ths = y/1000%10;
        led_s1 = 0;
    led_s2 = 1;
    led_s3 = 1;
    led_s4 = 1;
    P0 = buf[one];
    delay_100us();
    P0 = 0xff;
    led_s1 = 1;
    led_s2 = 0;
    led_s3 = 1;
    led_s4 = 1;
    P0 = buf[ten];
     delay_100us();
    P0 = 0xff;
    led_s1 = 1;
    led_s2 = 1;
    led_s3 = 0;
    led_s4 = 1;
    P0 = buf[hun];
    delay_100us();
    P0 = 0xff;
    led_s1 = 1;
    led_s2 = 1;
    led_s3 = 1;
    led_s4 = 0;
    P0 = buf[ths];
    delay_100us();
    P0 = 0xff;
int main(void)
    TMOD = 0x01;
    TH0  = 0xff;
    TL0  = 0xfb;
    TR0 = 1;
    ET0 = 1;
        EA  = 1;
                show(ctl_freq);
                if(0 == key1)
                        delay_10ms();
                        if(0 == key1)
                                while(!key1);
                                if(ctl_freq<1000)
                                        ctl_freq++;
                if(0 == key2)
                        delay_10ms();
                        if(0 == key2)
                                while(!key2);
                                if(ctl_freq>1)
                                        ctl_freq--;
  //5us触发
void timer_interrupt1(void) interrupt 1
        cnt++;
        TH0  = 0xff;
       TL0  = 0xfb;
        if(cnt >= ctl_freq)
                out = ~out;
                cnt = 0;
ctl_freq初值为100,即500us的高电平,500us的低电平,两者相互转换。周期为1ms,频率为1000Hz,但是用示波器测出来频率为150Hz,这是第一个问题。
检测部分主函数代码如下:
void  main()
        timer0_init();
        timer1_init();
    delay(10);                 //延时
    lcd_init();                //初始化LCD
    show_lcd();
                 if(cnt_timer == 50)
                TR1 = 0;
                        ET1 = 0;
                        TR0 = 0;
                        ET0 = 0;
                freq = (cnt_x*65536+TL1+TH1*256);
                TL1 = 0;
                TH1 = 0;
                cnt_timer = 0;
                cnt_x = 0;
                        del_data();
                        show_lcd();
                        TR1 = 1;
                        ET1 = 1;
                        TR0 = 1;
                        ET0 = 1;
定时器中断代码如下:
void timer_interrupt1(void) interrupt 3
        cnt_x++;
        TL1 = 0x00;
        TH1 = 0x00;
void timer_interrupt0(void) interrupt 1
        cnt_timer++;
        TL0 = 0xb8;
        TH0 = 0x00;
此时检测部分测出来的频率为533Hz,与计算的结果和示波器的结果都不一样。
54
164
164
2019-5-4
43 小时
发表于 2019-5-17 08:26:59 | 显示全部楼层
你的这个程序都没注释,别人来看你的程序浪费很多时间的,因为你写的不规范,特别是定时器中断,两个interrup 1的中断标号,基本功没有
54
164
164
2019-5-4
43 小时
发表于 2019-5-17 08:30:54 | 显示全部楼层
另外还有要记住的是,小的定时中断,那么必须先关闭定时器,等相关的确认OK再开启,即:\
void Timer0_Interrupt (void) interrupt 1 //5US中断
   EA= 0;//先关闭,防止中断再一次开启
   TH0= XX;
   TL0 = XX;//如果是自动重装的,则根据情况,一般不用再加
   相关的语句,而且不要多;
   EA = 1
2019-5-7
 楼主| 发表于 2019-5-17 11:16:47 | 显示全部楼层
gujp0575 发表于 2019-5-17 08:26
你的这个程序都没注释,别人来看你的程序浪费很多时间的,因为你写的不规范,特别是定时器中断,两个interr ...
代码是两个,一个是波形发生端,一个是检测端,都用到了定时器0,注释的话确实写的很少,感谢提醒。
2019-5-7
 楼主| 发表于 2019-5-17 11:17:12 | 显示全部楼层
void Timer0_Inte ...
感谢感谢,我试一试
2019-5-29
发表于 2019-5-29 15:28:17 | 显示全部楼层
我最近也在做这个 可以提供一些程序参考一下嘛 学校的课题设计
GMT+8, 2026-11-14 09:23
