查看: 7438|回复: 1
[ALTERA] 使用Quartus II 的浮点运算IP核,实现对一个未知二进制数除5
40
136
136
2016-11-1
24 小时
发表于 2019-8-27 10:33:07 | 显示全部楼层 |阅读模式
附上代码,已经仿真验证,可以实现,请问还有其它更简单的方法吗?
-- use Division  IP  core achieve /5
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity Division_ip is
port (
   Clk_i       :  in std_logic;
   Rst_i       :  in std_logic;
   DivisionA_i      :  in std_logic_vector(17 downto 0);
   DivisionC_o          : out std_logic_vector(17 downto 0)
end Division_ip;
architecture arch_Division_ip of Division_ip is
component M_Division port (
   clock       : IN  STD_LOGIC      ;
   dataa       : IN  STD_LOGIC_VECTOR (31 DOWNTO 0) ;
   datab       : IN  STD_LOGIC_VECTOR (31 DOWNTO 0) ;
   result       : OUT  STD_LOGIC_VECTOR (31 DOWNTO 0)
end component;
constant DivisionB_c     : std_logic_vector(31 downto 0) := b"0100_0000_1010_0000_0000_0000_0000_0000";
signal zero      : std_logic_vector(31 downto 0) := b"0000_0000_0000_0000_0000_0000_0000_0000";
shared variable  i     : integer range 0 to 17;
signal  j       : integer range 0 to 256;
signal Dataa_s      : std_logic_vector(31 downto 0);
signal DivisionA_s     : bit_vector(17 downto 0);
signal  DivisionD_s     : bit_vector(31 downto 0);
signal DivisionC_s     : std_logic_vector(23 downto 0);
signal result_s     : std_logic_vector(31 downto 0);
begin
DivisionA_s <= to_bitvector(DivisionA_i);
process (Rst_i, Clk_i) begin
   IF (Rst_i = '0') then
    i := 17;
    Dataa_s <= (others => '0');
   elsif rising_edge (Clk_i) then
    if (DivisionA_i(i) = '1') then
     Dataa_s(22 downto 5 ) <=to_stdlogicvector( DivisionA_s SLL (18-i));
     Dataa_s(30 downto 23) <= conv_std_logic_vector(i+127,8);
     i := i - 1;
    end if;
   end if;
end process;
   if (Rst_i = '0') then
    DivisionC_s <= (others => '0');
    DivisionC_s <= to_stdlogicvector( ('1' & DivisionD_s(22 downto 0)) SRL (150 - j));
   end if;
end process;
j <= conv_integer(result_s(30 downto 23));
DivisionD_s <= to_bitvector(result_s);
U_M_Division_0 : M_Division port map (
   clock       => Clk_i        ,
   dataa       => Dataa_s        ,
   datab       => DivisionB_c       ,
   result       => result_s
DivisionC_o <= DivisionC_s(17 downto 0);
end arch_Division_ip;
40
136
136
2016-11-1
24 小时
 楼主| 发表于 2019-8-27 15:46:28 | 显示全部楼层
自己顶一下
GMT+8, 2026-10-25 05:31
