查看: 8450|回复: 0
关于stm32f750的QSPI的管教配置问题
2019-6-12
发表于 2019-9-10 15:07:51 | 显示全部楼层 |阅读模式
最近我有用到stm32f750的QSPI,驱动一个flash(W25Q128),
买的demo开发版是用的W25Q64.
但是我用该程序去驱动W25Q128就是驱动不起来。
请大家帮忙找找问题。
我现在比较不确定的点是:那个QSPi的管脚复用有两个:一个是GPIO_AF9_QUADSPI,一个是GPIO_AF10_QUADSPI。
我根据管脚的不一样,怎么确定用哪个呢?
以下是我用的板子的QSPI的驱动管脚:
#define QSPI_FLASH_SIZE                   23
#define QSPI_FLASH_CS_PIN                 GPIO_PIN_6
#define QSPI_FLASH_CS_GPIO_PORT           GPIOB
#define QSPI_FLASH_CS_GPIO_CLK_ENABLE()   __GPIOB_CLK_ENABLE()
#define QSPI_FLASH_CS_GPIO_AF             GPIO_AF10_QUADSPI
#define QSPI_FLASH_CLK_PIN                 GPIO_PIN_2
#define QSPI_FLASH_CLK_GPIO_PORT           GPIOB
#define QSPI_FLASH_CLK_GPIO_ENABLE()       __GPIOB_CLK_ENABLE()
#define QSPI_FLASH_CLK_GPIO_AF             GPIO_AF9_QUADSPI
//qspi-bk1_io0
#define QSPI_FLASH_BK1_IO0_PIN             GPIO_PIN_11
#define QSPI_FLASH_BK1_IO0_PORT            GPIOD
#define QSPI_FLASH_BK1_IO0_CLK_ENABLE()    __GPIOD_CLK_ENABLE()
#define QSPI_FLASH_BK1_IO0_AF              GPIO_AF10_QUADSPI
//qspi-bk1_io1
#define QSPI_FLASH_BK1_IO1_PIN             GPIO_PIN_12
#define QSPI_FLASH_BK1_IO1_PORT            GPIOD
#define QSPI_FLASH_BK1_IO1_CLK_ENABLE()    __GPIOD_CLK_ENABLE()
#define QSPI_FLASH_BK1_IO1_AF              GPIO_AF10_QUADSPI
//qspi-bk1_io2
#define QSPI_FLASH_BK1_IO2_PIN             GPIO_PIN_2
#define QSPI_FLASH_BK1_IO2_PORT            GPIOE
#define QSPI_FLASH_BK1_IO2_CLK_ENABLE()    __GPIOE_CLK_ENABLE()
#define QSPI_FLASH_BK1_IO2_AF              GPIO_AF9_QUADSPI
//qspi-bk1_io3
#define QSPI_FLASH_BK1_IO3_PIN             GPIO_PIN_13
#define QSPI_FLASH_BK1_IO3_PORT            GPIOD
#define QSPI_FLASH_BK1_IO3_CLK_ENABLE()    __GPIOD_CLK_ENABLE()
#define QSPI_FLASH_BK1_IO3_AF              GPIO_AF9_QUADSPI
以下网上买得板子的QSPI的驱动管脚:这个复用配置是对的
#define QSPI_FLASH_SIZE                   22 //W25Q64
//qspi-bk1_io0
#define QSPI_FLASH_BK1_IO0_PIN             GPIO_PIN_8
#define QSPI_FLASH_BK1_IO0_PORT            GPIOF
#define QSPI_FLASH_BK1_IO0_CLK_ENABLE()    __GPIOF_CLK_ENABLE()
//qspi-bk1_io1
#define QSPI_FLASH_BK1_IO1_PIN             GPIO_PIN_9
#define QSPI_FLASH_BK1_IO1_PORT            GPIOF
#define QSPI_FLASH_BK1_IO1_CLK_ENABLE()    __GPIOF_CLK_ENABLE()
//qspi-bk1_io2
#define QSPI_FLASH_BK1_IO2_PIN             GPIO_PIN_7
#define QSPI_FLASH_BK1_IO2_PORT            GPIOF
#define QSPI_FLASH_BK1_IO2_CLK_ENABLE()    __GPIOF_CLK_ENABLE()
//qspi-bk1_io3
#define QSPI_FLASH_BK1_IO3_PIN             GPIO_PIN_6
#define QSPI_FLASH_BK1_IO3_PORT            GPIOF
#define QSPI_FLASH_BK1_IO3_CLK_ENABLE()    __GPIOF_CLK_ENABLE()
//以下是配置程序
void qspi_flash_init(void)
    GPIO_InitTypeDef GPIO_InitStruct;
    /* 使能 QSPI 及 GPIO 时钟 */
    QSPI_FLASH_CLK_ENABLE();
    QSPI_FLASH_CLK_GPIO_ENABLE();
    QSPI_FLASH_BK1_IO0_CLK_ENABLE();
          QSPI_FLASH_BK1_IO1_CLK_ENABLE();
          QSPI_FLASH_BK1_IO2_CLK_ENABLE();
    QSPI_FLASH_BK1_IO3_CLK_ENABLE();
    QSPI_FLASH_CS_GPIO_CLK_ENABLE();
    //设置引脚
    /*!< 配置 QSPI_FLASH 引脚: CLK */
    GPIO_InitStruct.Pin = QSPI_FLASH_CLK_PIN;
    GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
    GPIO_InitStruct.Pull = GPIO_PULLUP;
    GPIO_InitStruct.Speed = GPIO_SPEED_HIGH;
    GPIO_InitStruct.Alternate = QSPI_FLASH_CLK_GPIO_AF;
    HAL_GPIO_Init(QSPI_FLASH_CLK_GPIO_PORT, &GPIO_InitStruct);
        /*!< 配置 QSPI_FLASH 引脚: IO0 */
    GPIO_InitStruct.Pin = QSPI_FLASH_BK1_IO0_PIN;
    GPIO_InitStruct.Alternate = QSPI_FLASH_BK1_IO0_AF;
    HAL_GPIO_Init(QSPI_FLASH_BK1_IO0_PORT, &GPIO_InitStruct);
        /*!< 配置 QSPI_FLASH 引脚: IO1 */
    GPIO_InitStruct.Pin = QSPI_FLASH_BK1_IO1_PIN;
    GPIO_InitStruct.Alternate = QSPI_FLASH_BK1_IO1_AF;
    HAL_GPIO_Init(QSPI_FLASH_BK1_IO1_PORT, &GPIO_InitStruct);
        /*!< 配置 QSPI_FLASH 引脚: IO2 */
    GPIO_InitStruct.Pin = QSPI_FLASH_BK1_IO2_PIN;
    GPIO_InitStruct.Alternate = QSPI_FLASH_BK1_IO2_AF;
    HAL_GPIO_Init(QSPI_FLASH_BK1_IO2_PORT, &GPIO_InitStruct);
        /*!< 配置 QSPI_FLASH 引脚: IO3 */
    GPIO_InitStruct.Pin = QSPI_FLASH_BK1_IO3_PIN;
    GPIO_InitStruct.Alternate = QSPI_FLASH_BK1_IO3_AF;
    HAL_GPIO_Init(QSPI_FLASH_BK1_IO3_PORT, &GPIO_InitStruct);
        /*!< 配置 SPI_FLASH_SPI 引脚: NCS */
    GPIO_InitStruct.Pin = QSPI_FLASH_CS_PIN;
    GPIO_InitStruct.Alternate = QSPI_FLASH_CS_GPIO_AF;
    HAL_GPIO_Init(QSPI_FLASH_CS_GPIO_PORT, &GPIO_InitStruct);
    /* QSPI_FLASH 模式配置 */
    QSPI_Handler.Instance = QUADSPI;
        /*二分频,时钟为216/(1+1)=108MHz */
    QSPI_Handler.Init.ClockPrescaler = 1;
        /*FIFO 阈值为 4 个字节*/
    QSPI_Handler.Init.FifoThreshold = 4;
        /*采样移位半个周期*/
    QSPI_Handler.Init.SampleShifting = QSPI_SAMPLE_SHIFTING_HALFCYCLE;
        /*Flash大小为16M字节,2^24,所以取权值24-1=23*/
    QSPI_Handler.Init.FlashSize = QSPI_FLASH_SIZE;
        /*片选高电平保持时间,至少50ns,对应周期数6*9.2ns =55.2ns*/
    QSPI_Handler.Init.ChipSelectHighTime = QSPI_CS_HIGH_TIME_6_CYCLE;
        /*时钟模式选择模式0,nCS为高电平(片选释放)时,CLK必须保持低电平*/
    QSPI_Handler.Init.ClockMode = QSPI_CLOCK_MODE_0;
        /*根据硬件连接选择第一片Flash*/
        QSPI_Handler.Init.FlashID = QSPI_FLASH_ID_1;
    HAL_QSPI_Init(&QSPI_Handler);
    /*初始化QSPI接口*/
        BSP_QSPI_Init();
uint8_t BSP_QSPI_Init(void)
        QSPI_CommandTypeDef s_command;
        uint8_t value = W25Q128FV_FSR_QE;
        /* QSPI存储器复位 */
        if (QSPI_ResetMemory() != QSPI_OK)
                return QSPI_NOT_SUPPORTED;
        /* 使能写操作 */
        if (QSPI_WriteEnable() != QSPI_OK)
                return QSPI_ERROR;
        /* 设置四路使能的状态寄存器,使能四通道IO2和IO3引脚 */
        s_command.InstructionMode   = QSPI_INSTRUCTION_1_LINE;
        s_command.Instruction       = WRITE_STATUS_REG2_CMD;
        s_command.AddressMode       = QSPI_ADDRESS_NONE;
        s_command.AlternateByteMode = QSPI_ALTERNATE_BYTES_NONE;
        s_command.DataMode          = QSPI_DATA_1_LINE;
        s_command.DummyCycles       = 0;
        s_command.NbData            = 1;
        s_command.DdrMode           = QSPI_DDR_MODE_DISABLE;
        s_command.DdrHoldHalfCycle  = QSPI_DDR_HHC_ANALOG_DELAY;
        s_command.SIOOMode          = QSPI_SIOO_INST_EVERY_CMD;
        /* 配置命令 */
        if (HAL_QSPI_Command(&QSPI_Handler, &s_command, HAL_QPSI_TIMEOUT_DEFAULT_VALUE) != HAL_OK)
                return QSPI_ERROR;
        /* 传输数据 */
        if (HAL_QSPI_Transmit(&QSPI_Handler, &value, HAL_QPSI_TIMEOUT_DEFAULT_VALUE) != HAL_OK)
                return QSPI_ERROR;
        /* 自动轮询模式等待存储器就绪 */
        if (QSPI_AutoPollingMemReady(W25Q128FV_SUBSECTOR_ERASE_MAX_TIME) != QSPI_OK)
                return QSPI_ERROR;
        return QSPI_OK;
请大神解读;并指出错误;
GMT+8, 2026-10-31 04:39
