查看: 3819|回复: 2
输入scons --target=mdk5乱码
74
290
290
2019-9-4
52 小时
发表于 2019-10-18 19:19:38 | 显示全部楼层 |阅读模式
> scons --target=mdk5
scons: Reading SConscript files ...
UnicodeEncodeError: 'ascii' codec can't encode characters in position 3-4: ordinal not in range(128):
  File "C:\Users\shipors\Desktop\LidarCar\rt-thread\bsp\LidarCarBSP\SConstruct", line 32:
    Export('RTT_ROOT')
  File "D:\BaiduNetdiskDownload\env\tools\ConEmu\ConEmu\..\..\..\tools\Python27\Lib\site-packages\scons\SCons\Script\SConscript.py", line 666:
    env = self.factory()
  File "D:\BaiduNetdiskDownload\env\tools\ConEmu\ConEmu\..\..\..\tools\Python27\Lib\site-packages\scons\SCons\Script\SConscript.py", line 646:
    default_env = SCons.Defaults.DefaultEnvironment()
  File "D:\BaiduNetdiskDownload\env\tools\ConEmu\ConEmu\..\..\..\tools\Python27\Lib\site-packages\scons\SCons\Defaults.py", line 88:
    _default_env = SCons.Environment.Environment(*args, **kw)
  File "D:\BaiduNetdiskDownload\env\tools\ConEmu\ConEmu\..\..\..\tools\Python27\Lib\site-packages\scons\SCons\Environment.py", line 982:
    apply_tools(self, tools, toolpath)
  File "D:\BaiduNetdiskDownload\env\tools\ConEmu\ConEmu\..\..\..\tools\Python27\Lib\site-packages\scons\SCons\Environment.py", line 107:
    env.Tool(tool)
  File "D:\BaiduNetdiskDownload\env\tools\ConEmu\ConEmu\..\..\..\tools\Python27\Lib\site-packages\scons\SCons\Environment.py", line 1789:
    tool(self)
  File "D:\BaiduNetdiskDownload\env\tools\ConEmu\ConEmu\..\..\..\tools\Python27\Lib\site-packages\scons\SCons\Tool\__init__.py", line 296:
    self.generate(env, *args, **kw)
  File "D:\BaiduNetdiskDownload\env\tools\ConEmu\ConEmu\..\..\..\tools\Python27\Lib\site-packages\scons\SCons\Tool\default.py", line 40:
    for t in SCons.Tool.tool_list(env['PLATFORM'], env):
  File "D:\BaiduNetdiskDownload\env\tools\ConEmu\ConEmu\..\..\..\tools\Python27\Lib\site-packages\scons\SCons\Tool\__init__.py", line 1266:
    c_compiler = FindTool(c_compilers, env) or c_compilers[0]
  File "D:\BaiduNetdiskDownload\env\tools\ConEmu\ConEmu\..\..\..\tools\Python27\Lib\site-packages\scons\SCons\Tool\__init__.py", line 1169:
    if t.exists(env):
  File "D:\BaiduNetdiskDownload\env\tools\ConEmu\ConEmu\..\..\..\tools\Python27\Lib\site-packages\scons\SCons\Tool\msvc.py", line 296:
    return msvc_exists(env)
  File "D:\BaiduNetdiskDownload\env\tools\ConEmu\ConEmu\..\..\..\tools\Python27\Lib\site-packages\scons\SCons\Tool\MSCommon\vc.py", line 772:
    vcs = cached_get_installed_vcs(env)
  File "D:\BaiduNetdiskDownload\env\tools\ConEmu\ConEmu\..\..\..\tools\Python27\Lib\site-packages\scons\SCons\Tool\MSCommon\vc.py", line 537:
    ret = get_installed_vcs(env)
  File "D:\BaiduNetdiskDownload\env\tools\ConEmu\ConEmu\..\..\..\tools\Python27\Lib\site-packages\scons\SCons\Tool\MSCommon\vc.py", line 548:
    VC_DIR = find_vc_pdir(ver)
  File "D:\BaiduNetdiskDownload\env\tools\ConEmu\ConEmu\..\..\..\tools\Python27\Lib\site-packages\scons\SCons\Tool\MSCommon\vc.py", line 377:
    debug('find_vc_dir(): found VC in registry: {}'.format(comps))
你在你这个BSP的SConstruct文件中加个, DefaultEnvironment(tools=[]) 在env = Environment(tools = ['mingw'],
74
290
290
2019-9-4
52 小时
 楼主| 发表于 2019-10-18 19:19:39 | 显示全部楼层
发表于 2019-10-19 02:15:52 | 显示全部楼层
GMT+8, 2026-11-4 03:08
