查看: 8458|回复: 8
关于步进电机模块里部分代码问题
2019-5-23
发表于 2019-10-24 20:45:25 | 显示全部楼层 |阅读模式
uchar code tab[11]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff};  //共阳数码管驱动信号0-9
uchar code time_counter[10][2]={{0xda,0x1c},{0xde,0xe4},{0xe1,0xec},{0xe5,0xd4},{0xe9,0xbc},  {0xed,0xa4},{0xf1,0x8c},{0xf5,0x74},{0xf9,0x5c},{0xfc,0x18}};
uchar num1 = 0;
uchar num2 = 8;
char k=0;
char pause=1;
bit flag1 = 0;
uchar buf[4]={0,10,0,0};   // 数码管显示缓存   这样是如何设置的
void T0_T1_init()
TMOD = 0x11;
    TH1 = time_counter[k-1][0];
TL1 = time_counter[k-1][1];
TR1 = 0;          //为什么这里不用 TR1=1
ET1= 1;
EA = 1;
void delay1m(uint x)
    uint i,j;
    for(i=0;i<x;i++)
      for(j=0;j<120;j++);
void display()    //显示函数
wei3=1;wei2=1;wei1=1;wei0=0;led = tab[buf[3]];delay1m(1);led=0xff;
    wei3=1;wei2=1;wei1=0;wei0=1;led = tab[buf[2]];delay1m(1);led=0xff;
    wei3=1;wei2=0;wei1=1;wei0=1;led = tab[buf[1]];delay1m(1);led=0xff;
wei3=0;wei2=1;wei1=1;wei0=1;led = tab[buf[0]];delay1m(1);led=0xff;
file:///C:/Users/LENOVO/AppData/Roaming/Tencent/Users/767959219/TIM/WinTemp/RichOle/6OYCV5NAF&frac34;DJG)QZ6WXUH.png
红色的是没看懂的  可以有大神详细的讲下吗??有啥联系
发表于 2019-10-25 02:20:08 | 显示全部楼层
219
219
2015-3-2
36 小时
发表于 2019-10-25 13:51:41 | 显示全部楼层
你这个代码不全,不好解释
2019-5-23
 楼主| 发表于 2019-10-25 22:16:07 | 显示全部楼层
崇文尚武 发表于 2019-10-25 13:51
你这个代码不全,不好解释
void main()
        T0_T1_init();
        buf[1] = 10;
        a=b=c=d=0;
                display();
                if(s1 == 0)
                        delay1m(3);
                        if(s1 == 0)
                                flag1 = 0;
                                buf[0] = 0;
                //                haha = 0x00;
                        while(!s1) display();
                if(s2 == 0 )
                        delay1m(3);
                        if(s2 == 0)
                                flag1 = 1;
                                buf[0] = 1;
                //                haha = 0x00;
                        while(!s2) display();
                if(s3 == 0)
                        delay1m(3);
                        if(s3 == 0)
                                k++;
                                TR1=1;
                                if(k > 10 )
                                        k = 1;
                                buf[2]= k/10;
                                buf[3]= k%10;
                        while(!s3) display();
                if(s4 == 0)
                        delay1m(3);
                        if(s4 == 0)
                                k--;
                                TR1=1;
                                if(k <= 0)
                                        k = 10;
                                buf[2]= k/10;
                                buf[3]= k%10;
                        while(!s4) display();
                if(s5==0)
                        delay1m(3);
                        if(s5==0)
                                if(TR1==1)
                                        pause=k;
                                        k=0;
                                        TR1=0;
                                        a=b=c=d=0;
                                else if(TR1==0)
                                        k=pause;
                                        TR1=1;
                                buf[2]= k/10;
                                buf[3]= k%10;
                                while(!s5) display();
void time1_interrupt()interrupt 3
        static num1 = 0;
        static num2 = 0;
        if(flag1 == 0)
                switch(num1)
                        case 0:a = 1;b = 0;c = 0;d = 0;break;
                        case 1:a = 1;b = 1;c = 0;d = 0;break;
                        case 2:a = 0;b = 1;c = 0;d = 0;break;
                        case 3:a = 0;b = 1;c = 1;d = 0;break;
                        case 4:a = 0;b = 0;c = 1;d = 0;break;
                        case 5:a = 0;b = 0;c = 1;d = 1;break;
                        case 6:a = 0;b = 0;c = 0;d = 1;break;
                        case 7:a = 1;b = 0;c = 0;d = 1;break;
                num1++;
                if(num1 == 8)num1 = 0;
                switch(num2)
                        case 0:a = 1;b = 0;c = 0;d = 1;break;
                        case 1:a = 0;b = 0;c = 0;d = 1;break;
                        case 2:a = 0;b = 0;c = 1;d = 1;break;
                        case 3:a = 0;b = 0;c = 1;d = 0;break;
                        case 4:a = 0;b = 1;c = 1;d = 0;break;
                        case 5:a = 0;b = 1;c = 0;d = 0;break;
                        case 6:a = 1;b = 1;c = 0;d = 0;break;
                        case 7:a = 1;b = 0;c = 0;d = 0;break;
                num2++;
                if(num2 == 8)num2 = 0;
2019-5-23
 楼主| 发表于 2019-10-25 22:20:55 | 显示全部楼层
其余代码如下
#include<reg51.h>
#define uchar unsigned char
#define uint unsigned int
#define led P0
#define haha P2
sbit s1 = P1^0;
sbit s2 = P1^1;
sbit s3 = P3^0;
sbit s4 = P3^1;
sbit s5 = P3^2;
sbit wei3 = P2^3;sbit wei2 = P2^2;sbit wei1 = P2^1;sbit wei0 = P2^0;
sbit a = P2^7;sbit b = P2^6;sbit c = P2^5;sbit d = P2^4;
void main()
        T0_T1_init();
        buf[1] = 10;
        a=b=c=d=0;
                display();
                if(s1 == 0)
                        delay1m(3);
                        if(s1 == 0)
                                flag1 = 0;
                                buf[0] = 0;
                //                haha = 0x00;
                if(s2 == 0 )
                        delay1m(3);
                        if(s2 == 0)
                                flag1 = 1;
                                buf[0] = 1;
                //                haha = 0x00;
                if(s3 == 0)
                        delay1m(3);
                        if(s3 == 0)
                                k++;
                                TR1=1;
                                if(k > 10 )
                                        k = 1;
                                buf[2]= k/10;
                                buf[3]= k%10;
                if(s4 == 0)
                        delay1m(3);
                        if(s4 == 0)
                                k--;
                                TR1=1;
                                if(k <= 0)
                                        k = 10;
                                buf[2]= k/10;
                                buf[3]= k%10;
                if(s5==0)
                        delay1m(3);
                        if(s5==0)
                                if(TR1==1)
                                        pause=k;
                                        k=0;
                                        TR1=0;
                                        a=b=c=d=0;
                                else if(TR1==0)
                                        k=pause;
                                        TR1=1;
                                buf[2]= k/10;
                                buf[3]= k%10;
        static num1 = 0;
        static num2 = 0;
        if(flag1 == 0)
                switch(num1)
                num1++;
                switch(num2)
                num2++;
以上是其余代码
2019-5-23
 楼主| 发表于 2019-10-26 13:11:06 | 显示全部楼层
#include<reg51.h>
#define led P0
#define haha P2
sbit s1 = P1^0;
sbit s2 = P1^1;
sbit s3 = P3^0;
sbit s4 = P3^1;
sbit s5 = P3^2;
void main()
        T0_T1_init();
        buf[1] = 10;
        a=b=c=d=0;
                display();
                if(s1 == 0)
                        delay1m(3);
                        if(s1 == 0)
                                flag1 = 0;
                                buf[0] = 0;
                //                haha = 0x00;
                if(s2 == 0 )
                        delay1m(3);
                        if(s2 == 0)
                                flag1 = 1;
                                buf[0] = 1;
                //                haha = 0x00;
                if(s3 == 0)
                        delay1m(3);
                        if(s3 == 0)
                                k++;
                                TR1=1;
                                if(k > 10 )
                                        k = 1;
                                buf[2]= k/10;
                                buf[3]= k%10;
                if(s4 == 0)
                        delay1m(3);
                        if(s4 == 0)
                                k--;
                                TR1=1;
                                if(k <= 0)
                                        k = 10;
                                buf[2]= k/10;
                                buf[3]= k%10;
                if(s5==0)
                        delay1m(3);
                        if(s5==0)
                                if(TR1==1)
                                        pause=k;
                                        k=0;
                                        TR1=0;
                                        a=b=c=d=0;
                                else if(TR1==0)
                                        k=pause;
                                        TR1=1;
                                buf[2]= k/10;
                                buf[3]= k%10;
        static num1 = 0;
        static num2 = 0;
        if(flag1 == 0)
                switch(num1)
                num1++;
                switch(num2)
                num2++;
2019-5-23
 楼主| 发表于 2019-10-26 13:15:05 | 显示全部楼层
你这个代码不全,不好解释
#include<reg51.h>
#define led P0
#define haha P2
sbit s1 = P1^0;
sbit s2 = P1^1;
sbit s3 = P3^0;
sbit s4 = P3^1;
sbit s5 = P3^2;
void main()
        T0_T1_init();
        buf[1] = 10;
        a=b=c=d=0;
                display();
                if(s1 == 0)
                        delay1m(3);
                        if(s1 == 0)
                                flag1 = 0;
                                buf[0] = 0;
                //                haha = 0x00;
                if(s2 == 0 )
                        delay1m(3);
                        if(s2 == 0)
                                flag1 = 1;
                                buf[0] = 1;
                //                haha = 0x00;
                if(s3 == 0)
                        delay1m(3);
                        if(s3 == 0)
                                k++;
                                TR1=1;
                                if(k > 10 )
                                        k = 1;
                                buf[2]= k/10;
                                buf[3]= k%10;
                if(s4 == 0)
                        delay1m(3);
                        if(s4 == 0)
                                k--;
                                TR1=1;
                                if(k <= 0)
                                        k = 10;
                                buf[2]= k/10;
                                buf[3]= k%10;
                if(s5==0)
                        delay1m(3);
                        if(s5==0)
                                if(TR1==1)
                                        pause=k;
                                        k=0;
                                        TR1=0;
                                        a=b=c=d=0;
                                else if(TR1==0)
                                        k=pause;
                                        TR1=1;
                                buf[2]= k/10;
                                buf[3]= k%10;
        static num1 = 0;
        static num2 = 0;
        if(flag1 == 0)
                switch(num1)
                num1++;
                switch(num2)
                num2++;
47
680
680
2019-5-18
101 小时
发表于 2019-10-30 21:43:35 | 显示全部楼层
  1. uchar code tab[11]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff};  //共阳数码管驱动信号0-9
这个是数码管要显示的数据,以第一个0xC0解释:一个数码管由八个段组成,即a、b、c、d、e、f、g、h。0xc0二进制为:1100 0000(hgfedcba)
47
680
680
2019-5-18
101 小时
发表于 2019-10-31 08:57:09 | 显示全部楼层
  1. uchar code time_counter[10][2]={{0xda,0x1c},{0xde,0xe4},{0xe1,0xec},{0xe5,0xd4},{0xe9,0xbc},  {0xed,0xa4},{0xf1,0x8c},{0xf5,0x74},{0xf9,0x5c},{0xfc,0x18}};
这个数组是定时器0装载值,达成定时目的,在—》这段代码中装载
  1. TH1 = time_counter[k-1][0];
  2. TL1 = time_counter[k-1][1];
  3. TR1 = 0;          //为什么这里不用 TR1=1
如:第一个数组{0xda,0x1c},合起来就是十六进制(da1c)H = (55836)D  若晶振是12MHZ那么这个定时器装载值9.7ms(65536-55836=9700)。第二个是约8.5ms,其他自己算。一开始TR1 = 0,应该是程序刚烧录后的状态是步进电机不转。
  1. uchar buf[4]={0,10,0,0};   // 数码管显示缓存   这样是如何设置的
这个好比一个数组,它与这个数码管表配合使用
如led = tab[buf[3]];这个其实就是实现led = tab[0];另外三个一样含义。
  1. void display()    //显示函数
  2. {
  3. wei3=1;wei2=1;wei1=1;wei0=0;led = tab[buf[3]];delay1m(1);led=0xff;
  4.     wei3=1;wei2=1;wei1=0;wei0=1;led = tab[buf[2]];delay1m(1);led=0xff;
  5.     wei3=1;wei2=0;wei1=1;wei0=1;led = tab[buf[1]];delay1m(1);led=0xff;
  6. wei3=0;wei2=1;wei1=1;wei0=1;led = tab[buf[0]];delay1m(1);led=0xff;
  7. }
这个函数,wei3,wei2,wei1,wei0是控制数码管位选的吧,按理说8个数码管三个位就够用了。为啥有四个位呢?
GMT+8, 2026-11-14 09:15
