查看: 18525|回复: 13
字符设备驱动编译出现error:code model kernel does not support PIC mode
57
57
2015-4-13
11 小时
发表于 2019-11-13 08:38:46 | 显示全部楼层 |阅读模式
Deal all,字符设备驱动make -j32出现 error:code model kernel does not support PIC mode.
环境:Ubuntu 18.04
arm-linux-guneabihf-gcc:  version 4.9.4(Linaro GCC 4.9-2017.01)
内核源码:正点原子修改后的:linux-imx-4.1.15-2.1.0-g49efdaa-v1.0.tar.bz2
前提:内核源码编译内核成功:Kernel: arch/arm/boot/zImage is ready
字符设备驱动源码:拷贝例程源码\2、Linux驱动例程\1_chrdevbase,
并修改VScode工程中自己的源码路径和Makefile路径
            "includePath": [
                "${workspaceFolder}/**",
                "/home/wjj/Documents/opendev/linux-imx-4.1.15-alpha/include",
                "/home/wjj/Documents/opendev/linux-imx-4.1.15-alpha/arch/arm/include",
                "/home/wjj/Documents/opendev/linux-imx-4.1.15-alpha/arch/arm/include/generated/"
KERNELDIR := /home/wjj/Documents/opendev/linux-imx-4.1.15-alpha
在1_chrdevbase目录下make -j32,出现下述错误。
make -C /home/wjj/Documents/opendev/linux-imx-4.1.15-alpha M=/home/wjj/Documents/opendev/LinuxDrivers/1_chrdevbase modules
make[1]: Entering directory '/home/wjj/Documents/opendev/linux-imx-4.1.15-alpha'
  CC [M]  /home/wjj/Documents/opendev/LinuxDrivers/1_chrdevbase/chrdevbase.o
cc1: error: code model kernel does not support PIC mode
scripts/Makefile.build:264: recipe for target '/home/wjj/Documents/opendev/LinuxDrivers/1_chrdevbase/chrdevbase.o' failed
make[2]: *** [/home/wjj/Documents/opendev/LinuxDrivers/1_chrdevbase/chrdevbase.o] Error 1
Makefile:1384: recipe for target '_module_/home/wjj/Documents/opendev/LinuxDrivers/1_chrdevbase' failed
make[1]: *** [_module_/home/wjj/Documents/opendev/LinuxDrivers/1_chrdevbase] Error 2
make[1]: Leaving directory '/home/wjj/Documents/opendev/linux-imx-4.1.15-alpha'
Makefile:9: recipe for target 'kernel_modules' failed
make: *** [kernel_modules] Error 2
尝试解决:参考https://blog.csdn.net/jasonLee_lijiaqi/article/details/84651138中在内核源码的顶层Makefile做如下修改:在KBUILD_CFLAGS尾部添加 -fno-pie
添加后出现了更多的error:
evbase.c:2:
./arch/x86/include/asm/arch_hweight.h: In function ‘__arch_hweight64’:
./arch/x86/include/asm/arch_hweight.h:53:42: error: expected ‘:’ or ‘)’ before ‘POPCNT64’
  asm (ALTERNATIVE("call __sw_hweight64", POPCNT64, X86_FEATURE_POPCNT)
error: unknown type name ‘atomic64_t’; did you mean ‘atomic_t’?
static inline void atomic64_set(atomic64_t *v, long i)
请教论坛大神,这类问题接下来要如何解决?
Linux源码Makefile添加-fno-pie后再重新编译内核吗?
问题解决:https://e2e.ti.com/support/processors/f/791/t/737467 需要使用make ARCH=arm CROSS_COMPILE = arm-linux-gnueabihf-gcc 按照手册中直接输入make -j32编译可能有问题。
57
57
2015-4-13
11 小时
 楼主| 发表于 2019-11-13 08:38:47 | 显示全部楼层
64
64
2017-4-22
14 小时
发表于 2019-11-25 11:35:09 | 显示全部楼层
你好,楼主我跟你遇到了同样的问题,那个PIC mode的解决办法与你提到的解决方法一样,解决该问题后编译也是出现了更多的error提示,尝试用make ARCH=arm  CROSS_COMPLIE = arm-linux-gnueabihf-  编译还是没有解决该问题啊,提示没有编译目标,你的问题解决了吗?请教一下是怎么解决的呢?万分感谢!
64
64
2017-4-22
14 小时
发表于 2019-11-25 12:52:33 | 显示全部楼层
TIM图片20191125113714.png 对上面问题的图片补充,添加make ARCH=arm  CROSS_COMPLIE = arm-linux-gnueabihf-  编译报错“空变量名,停止”
57
57
2015-4-13
11 小时
 楼主| 发表于 2019-11-25 13:12:33 | 显示全部楼层
xiaoshuai5588 发表于 2019-11-25 12:52
对上面问题的图片补充,添加make ARCH=arm  CROSS_COMPLIE = arm-linux-gnueabihf-  编译报错“空变量名, ...
编译的时候:输入如下命令
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf-
23
136
136
2019-10-29
25 小时
发表于 2019-11-26 10:02:06 | 显示全部楼层
我编译驱动时也出现过问题,弄了很久,现在没有问题了,你可以试试
export ARCH=arm
export CROSS_COMPILE=arm-linux-gnueabihf-
然后再make
888
2397
2397
2019-9-25
398 小时
发表于 2019-11-29 23:47:38 | 显示全部楼层
像教程那样在Makefile下配置,指定 ARCH=arm ,编译器为arm-linux-gnueabihf-了以后再直接make就好了。应该是你的源码根目录下的Makefile没指定,系统会默认调用别的编译器才导致的错误
65
436
436
2016-6-20
121 小时
发表于 2019-12-9 21:50:43 | 显示全部楼层
不应该有空格就对了
2020-3-6
发表于 2020-3-6 13:55:59 | 显示全部楼层
export ARCH=arm
export CROSS_COMPI ...
可以:
2020-11-8
发表于 2020-11-8 12:27:40 | 显示全部楼层
export ARCH=arm
有效!!!!!!!!
53
53
2022-6-5
发表于 2022-6-7 17:16:36 | 显示全部楼层
2022_6_7 我也遇到了这个问题
总结一下有两种解决方案:
第一种:像5楼说的那样,在make时指定编译器,注意等号两侧不要有空格。即执行 “make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf-”
第二种:7楼的方法,直接修改内核源码第252、253行,改为
ARCH                ?= arm
CROSS_COMPILE        ?= arm-linux-gnueabihf-
然后直接执行“make”
根本原因正如7楼所言,内核源码根目录下的Makefile没指定,系统会默认调用别的编译器才导致的错误
2016-4-9
发表于 2022-6-14 20:37:10 | 显示全部楼层
地理课代表 发表于 2022-6-7 17:16
2022_6_7 我也遇到了这个问题
总结一下有两种解决方案:
第一种:像5楼说的那样,在make时指定编译器,注 ...
由于偷懒,直接复制了资料里边的源码进行编译,出现了同样的情况,看了这篇帖子后,执行 “make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf-”就可以编译成功了
2023-8-28
发表于 2023-8-29 17:57:11 | 显示全部楼层
export ARCH=arm
可以了 感谢
127
757
757
2020-5-11
71 小时
发表于 2025-2-14 20:10:49 | 显示全部楼层
所以导致这个的问题是:原来的ubuntu系统中存在另外的编译器,编译器设置的时候设置不到位,系统默认调用了不适配的编译器吗
GMT+8, 2026-10-31 02:21
