查看: 7835|回复: 9
交叉编译的应用程序在板子上无法运行
37
37
2019-10-29
发表于 2019-11-21 17:20:16 | 显示全部楼层 |阅读模式
我编译了个测试文件,手动拷贝到SD卡的文件系统的lib目录下,系统启动之后我在终端执行这个bin文件,可是没有任何打印(只要执行就是有打印的)
感觉就像没有执行一样
文件格式如下
代码如下
  1. #include<stdio.h>
  2. #include<linux/types.h>
  3. #include<fcntl.h>
  4. #include<unistd.h>
  5. #include<stdlib.h>
  6. #include<sys/types.h>
  7. #include<sys/ioctl.h>
  8. #include<string.h>
  9. #include<linux/i2c.h>
  10. #include<linux/i2c-dev.h>
  11. #define MAX_BYTES            2
  12. #define DEFAULT_I2C_BUS      "/dev/i2c-0"
  13. int
  14. i2c_write(int fd,
  15.                  unsigned int addr,
  16.                  unsigned int offset,
  17.                  unsigned char *buf,
  18.                  unsigned int len)
  19. {
  20.         struct i2c_rdwr_ioctl_data msg_rdwr;
  21.         struct i2c_msg i2cmsg;
  22.         int i;
  23.         char _buf[MAX_BYTES+1];
  24.         if(len>MAX_BYTES)
  25.         {
  26.                 return -1;
  27.         }
  28.         if(offset+len>256)
  29.         {
  30.                 return -1;
  31.         }
  32.         _buf[0]=offset;
  33.         for(i=0;i<len;i++)
  34.         {
  35.             _buf[1+i]=buf[i];
  36.             printf("----_writedata:%x------\n",_buf[1+i]);
  37.         }
  38.         msg_rdwr.msgs = &i2cmsg;
  39.         msg_rdwr.nmsgs = 1;
  40.         i2cmsg.addr  = addr;
  41.         i2cmsg.flags = 0;
  42.         i2cmsg.len   = 1+len;
  43.         i2cmsg.buf   = _buf;
  44.         if((i=ioctl(fd,I2C_RDWR,&msg_rdwr))<0){
  45.                 perror("i2c_write ioctl() error");
  46.                 fprintf(stderr,"ioctl returned %d\n",i);
  47.                 return -1;
  48.         }
  49.         return 0;
  50. }
  51. int
  52. i2c_read(int fd,
  53.                         unsigned int addr,
  54.                         unsigned int offset,
  55.                         unsigned char *buf,
  56.                         unsigned int len)
  57. {
  58.         struct i2c_rdwr_ioctl_data msg_rdwr;
  59.         struct i2c_msg i2cmsg;
  60.         int i;
  61.         if(len>MAX_BYTES)
  62.         {
  63.                 return -1;
  64.         }
  65.         if(i2c_write(fd,addr,offset,NULL,0)<0)
  66.         {
  67.         printf("error! line: %d\n", __LINE__);
  68.             return -1;
  69.         }
  70.
  71.         msg_rdwr.msgs = &i2cmsg;
  72.         msg_rdwr.nmsgs = 1;
  73.
  74.         i2cmsg.addr  = addr;
  75.         i2cmsg.flags = I2C_M_RD;
  76.         i2cmsg.len   = len;
  77.         i2cmsg.buf   = buf;
  78.         if((i=ioctl(fd,I2C_RDWR,&msg_rdwr))<0){
  79.             perror("ioctl()");
  80.         printf("error! line: %d\n", __LINE__);
  81.             fprintf(stderr,"ioctl returned %d\n",i);
  82.             return -1;
  83.         }
  84.         return 0;
  85. }
  86. int main(int argc, char** argv)
  87. {
  88.         printf("----camera test start---------\n");
  89.
  90.     if(argc != 2){
  91.         printf("Error Usage!\r\n");
  92.         return -1;
  93.     }
  94.     char * filename = argv[1];
  95.
  96.         int fd =open(filename, O_RDWR);
  97.         if (fd< 0)
  98.         {
  99.                 printf("open filename failed\n");
  100.                 return -1;
  101.         }
  102.         unsigned int addr = 0x21;
  103.     unsigned int addr2 = 0x42;
  104.         unsigned int offset = 0;
  105.         unsigned char writebuf[2]={0x26,0x52};
  106.         unsigned char readbuf[2];
  107.         unsigned int len = 1;
  108.
  109.         i2c_read(fd,addr,offset,readbuf,len);
  110.     printf("read i2cdevice:%s addr: %x data is:%x-----\n",filename,
  111.                 addr,
  112.                 readbuf[0]);
  113.         i2c_read(fd,addr2,offset,readbuf,len);
  114.     printf("read i2cdevice:%s addr: %x data is:%x-----\n",filename,
  115.                 addr2,
  116.                 readbuf[0]);
  117.         memset(readbuf,0,sizeof(readbuf));
  118.         //i2c_write(fd,addr,offset,writebuf,len);
  119.
  120.         //i2c_read(fd,addr,offset,readbuf,len);
  121.
  122.         printf("----end---------\n");
  123.         close(fd);
  124.         return 0;
  125. }
解决了,原因是权限错误。 在编译好执行文件后再chmod 777 改变执行文件的权限就可以在目标板上运行了。
37
37
2019-10-29
 楼主| 发表于 2019-11-21 17:20:17 | 显示全部楼层
解决了,原因是权限错误。
1114
1656
1656
2019-8-15
102 小时
发表于 2019-11-21 19:36:53 | 显示全部楼层
成功没有捷径
876
4090
4090
2015-11-14
551 小时
发表于 2019-11-21 23:12:22 | 显示全部楼层
888
2397
2397
2019-9-25
398 小时
发表于 2019-11-22 09:56:20 | 显示全部楼层
你是说拷贝到文件系统以后手动执行没有反应还是设置了自动运行没反应?
37
37
2019-10-29
 楼主| 发表于 2019-11-22 10:29:53 | 显示全部楼层
是手动执行的没有反应
40
40
2019-10-19
10 小时
发表于 2019-11-22 10:44:40 | 显示全部楼层
没有正常执行,你第一句打印都没显示出来,做两件事,1.编译一个hello world确定编译链没问题 2.使用dmeg命令,看是不是打印了没显示出来
37
37
2019-10-29
 楼主| 发表于 2019-11-22 11:37:02 | 显示全部楼层
jun1172 发表于 2019-11-22 10:44
没有正常执行,你第一句打印都没显示出来,做两件事,1.编译一个hello world确定编译链没问题 2.使用dmeg命 ...
谢谢,是编译好的文件权限问题。好奇怪,不知道怎么解释。
1114
1656
1656
2019-8-15
102 小时
发表于 2019-11-22 12:36:47 | 显示全部楼层
236
1128
1128
2019-5-6
130 小时
发表于 2019-11-24 07:06:33 | 显示全部楼层
感谢楼主分享
一步一个脚印
GMT+8, 2026-10-31 03:47
