查看: 5633|回复: 2
蓝牙接收程序——如何修改逻辑可以使串口收到的3个不同数据链分行显示出来,且循坏不断?
2019-1-4
发表于 2019-12-2 16:32:57 | 显示全部楼层 |阅读模式
13金钱
蓝牙接收程序——如何修改逻辑可以使串口收到的3个不同数据链分行显示出来,且循坏不断?现在根据原子哥的例程更改的,可以显示三行数据,但是每行数据都是一个数据链,且循环会截止。下面是修改的程序:求指导。
void HC05_Role_Show(void)
        if(HC05_Get_Role()==1)LCD_ShowString(30,140,200,16,16,"ROLE:Master");        //主机
        else LCD_ShowString(30,140,200,16,16,"ROLE:Slave ");                                         //从机
//显示ATK-HC05模块的连接状态
void HC05_Sta_Show(void)
        if(HC05_LED)LCD_ShowString(120,140,120,16,16,"STA:Connected ");                        //连接成功
        else LCD_ShowString(120,140,120,16,16,"STAisconnect");                                 //未连接
int main(void)
        u8 t;
        u8 n;
        u8 temp=0;
        u8 key;
        u8 reclen=0;
        delay_init();                     //延时函数初始化
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);        //设置NVIC中断分组2:2位抢占优先级,2位响应优先级
        uart_init(115200);                 //串口初始化为9600
        LED_Init();                                //初始化与LED连接的硬件接口
        KEY_Init();                                //初始化按键
  LCD_Init();                                //初始化LCD
  usmart_dev.init(72);         //初始化USMART
        POINT_COLOR=RED;
        //LCD_ShowString(30,30,200,16,16,"ALIENTEK STM32F1 ^_^");
        //LCD_ShowString(30,50,200,16,16,"HC05 BLUETOOTH COM TEST");
        //LCD_ShowString(30,70,200,16,16,"ATOM@ALIENTEK");
        delay_ms(1000);                        //等待蓝牙模块上电稳定
        while(HC05_Init())                 //初始化ATK-HC05模块
                LCD_ShowString(30,90,200,16,16,"ATK-HC05 Error!");
                delay_ms(500);
                LCD_ShowString(30,90,200,16,16,"lease Check!!!");
                delay_ms(100);
        //LCD_ShowString(30,90,210,16,16,"KEY1:ROLE KEY0:SEND/STOP");
        //LCD_ShowString(30,110,200,16,16,"ATK-HC05 Standby!");
  //        LCD_ShowString(30,160,200,16,16,"Send:");
        LCD_ShowString(30,180,200,16,16,"Receive:");
        POINT_COLOR=BLUE;
        HC05_Role_Show();
        delay_ms(100);
        USART3_RX_STA=0;
        //n=0;
                key=KEY_Scan(0);
                if(key==KEY1_PRES)                                                //切换模块主从设置
                           key=HC05_Get_Role();
                        if(key!=0XFF)
                                key=!key;                                          //状态取反
                                if(key==0)HC05_Set_Cmd("AT+ROLE=0");
                                else HC05_Set_Cmd("AT+ROLE=1");
                                HC05_Role_Show();
                                HC05_Set_Cmd("AT+RESET");        //复位ATK-HC05模块
                                delay_ms(200);
                /*else if(key==KEY0_PRES)
                        sendmask=!sendmask;                                //发送/停止发送
                        if(sendmask==0)LCD_Fill(30+40,160,240,160+16,WHITE);//清除显示
                }else delay_ms(10);
                if(t==50)
                        if(sendmask)                                        //定时发送
                                sprintf((char*)sendbuf,"ALIENTEK HC05 %d\r\n",sendcnt);
                                  LCD_ShowString(30+40,160,200,16,16,sendbuf);        //显示发送数据
                                u3_printf("ALIENTEK HC05 %d\r\n",sendcnt);                //发送到蓝牙模块
                                sendcnt++;
                                if(sendcnt>99)sendcnt=0;
                        HC05_Sta_Show();
                        t=0;
                        LED0=!LED0;
       for(n=0;n<4;n++)
                if(USART3_RX_STA&0X8000)                        //接收到一次数据了
                        LCD_Fill(30,200,240,320,WHITE);        //清除显示
                        reclen=USART3_RX_STA&0X7FFF;        //得到数据长度
                          /*USART3_RX_BUF[reclen]=0;                 //加入结束符
                        if(reclen==9||reclen==8)                 //控制DS1检测
                                if(strcmp((const char*)USART3_RX_BUF,"+LED1 ON")==0)LED1=0;        //打开LED1
                                if(strcmp((const char*)USART3_RX_BUF,"+LED1 OFF")==0)LED1=1;//关闭LED1
                        if(temp==1)
                        LCD_ShowString(30,200,209,119,16,USART3_RX_BUF);//显示接收到的数据
                        }else if(temp==2)
                        LCD_ShowString(30,230,209,119,16,USART3_RX_BUF);//显示接收到的数据
                        }else if(temp==3)
                        LCD_ShowString(30,260,209,119,16,USART3_RX_BUF);//显示接收到的数据
                        temp=temp+1;
                        if(temp==3)
                        USART3_RX_STA=0;
                t++;
1114
1656
1656
2019-8-15
102 小时
发表于 2019-12-2 18:36:06 | 显示全部楼层
成功没有捷径
2019-1-4
 楼主| 发表于 2019-12-4 09:18:16 | 显示全部楼层
来个高手解惑啊
GMT+8, 2026-11-24 03:22
