查看: 7993|回复: 4
I.MX 6ULL AD采集驱动检测没有IRQ
92
92
2019-3-23
26 小时
发表于 2019-12-27 08:35:58 | 显示全部楼层 |阅读模式
3金钱
使用I.MX6ULL主芯片,硬件使用ECSPI4连接一个AD7173,在dts文件中配置如下:
                pinctrl_ecspi4: ecspi4grp {
                        fsl,pins = <
                                MX6UL_PAD_ENET2_TX_CLK__ECSPI4_MISO         0x100b1
                                MX6UL_PAD_ENET2_TX_EN__ECSPI4_MOSI                0x100b1
                                MX6UL_PAD_ENET2_TX_DATA1__ECSPI4_SCLK         0x100b1
                pinctrl_ecspi4_cs: ecspi4cs {
                        fsl,pins = <
                                MX6UL_PAD_ENET2_TX_EN__GPIO2_IO13  0x80000000
&ecspi4 {
        compatible = "fsl,imx6ul-ecspi";
        fsl,spi-num-chipselects = <1>;
        cs-gpios = <&gpio2 13 0>;
        pinctrl-names = "default";
        pinctrl-0 = <&pinctrl_ecspi4 &pinctrl_ecspi4_cs>;
        status = "okay";
        ad7173:ad7173@0 {
                compatible = "adi,ad7173";
                reg = <0x0>;
                #address-cells = <1>;
                #size-cells = <1>;
                spi-cpol;
                spi-cpha;
                spi-max-frequency = <20000000>;
                adi,channels {
                        #address-cells = <2>;
                        #size-cells = <0>;
                        channel@0,1 {
                                reg = <0 1>;
                                adi,bipolar;
                        channel@2,3 {
                                reg = <2 3>;
                                adi,bipolar;
AD7173的驱动
static const struct of_device_id ad7173_of_match[] = {
{ .compatible = "adi,ad7173" },
{.compatible = "adi,ad7173-8" },
static const struct spi_device_id ad7173_id_table[] = {
        { "ad7172-2", ID_AD7172_2 },
        { "ad7173-8", ID_AD7173_8 },
        { "ad7175-2", ID_AD7175_2 },
        { "ad7176-2", ID_AD7176_2 },
MODULE_DEVICE_TABLE(spi, ad7173_id_table);
static struct spi_driver ad7173_driver = {
        .driver = {
                .name        = "ad7173",
                .owner        = THIS_MODULE,
                .of_match_table = ad7173_of_match,
        .probe                = ad7173_probe,
        .remove                = ad7173_remove,
        .id_table        = ad7173_id_table,
module_spi_driver(ad7173_driver);
系统启动后可以检测到设备,但是驱动程序在probe函数中报错,
static int ad7173_probe(struct spi_device *spi)
        const struct spi_device_id *id;
        struct ad7173_state *st;
        struct iio_dev *indio_dev;
        int ret;
        printk(KERN_ALERT "ad7173_probe start\n");
        if (!spi->irq) {
                dev_err(&spi->dev, "No IRQ specified\n");
                return -ENODEV;
        indio_dev = devm_iio_device_alloc(&spi->dev, sizeof(*st));
        if (indio_dev == NULL){
                printk(KERN_ALERT "indio_dev is null\n");
                return -ENOMEM;
        st = iio_priv(indio_dev);
        id = spi_get_device_id(spi);
        st->info = &ad7173_device_info[id->driver_data];
        ad_sd_init(&st->sd, indio_dev, spi, &ad7173_sigma_delta_info);
        st->sd.num_slots = st->info->num_configs;
        spi_set_drvdata(spi, indio_dev);
        indio_dev->dev.parent = &spi->dev;
        indio_dev->name = spi_get_device_id(spi)->name;
        indio_dev->modes = INDIO_DIRECT_MODE;
        indio_dev->info = &ad7173_info;
        ret = ad7173_of_parse_channel_config(indio_dev, spi->dev.of_node);
        if (ret){
                dev_err(&spi->dev, "ad7173_of_parse_channel_config  failed\n");
                return ret;
        ret = ad_sd_setup_buffer_and_trigger(indio_dev);
        if (ret){
                dev_err(&spi->dev, "ad_sd_setup_buffer_and_trigger  failed\n");
                goto error_disable_reg;
        ret = ad7173_setup(indio_dev);
        if (ret){
                dev_err(&spi->dev, "ad7173_setup  failed\n");
                goto error_remove_trigger;
        ret = iio_device_register(indio_dev);
        if (ret){
                dev_err(&spi->dev, "iio_device_register  failed\n");
        return ad7173_gpio_init(st);
error_remove_trigger:
        ad_sd_cleanup_buffer_and_trigger(indio_dev);
error_disable_reg:
        return ret;
内核打印
<1>ad7173_probe start
<3>ad7173 spi3.0: No IRQ specified
请问这是我dts文件配置的问题还是驱动程序的问题?
95
553
3681
3681
2016-1-7
591 小时
发表于 2019-12-27 20:23:58 | 显示全部楼层
帮顶。
88
7369
14980
14980
2013-11-13
1823 小时
发表于 2019-12-28 16:43:29 | 显示全部楼层
看样子是设备树里面指定中断信息
92
92
2019-3-23
26 小时
 楼主| 发表于 2019-12-29 14:58:40 | 显示全部楼层
zuozhongkai 发表于 2019-12-28 16:43
看样子是设备树里面指定中断信息
是的,我也觉得是这样,不太会写,有什么可以参考的吗?
888
2397
2397
2019-9-25
398 小时
发表于 2019-12-31 22:35:31 | 显示全部楼层
GMT+8, 2026-10-31 02:47
