查看: 10175|回复: 6
[ALTERA] 正点原子 FPGA 红外程序求助
2019-12-20
发表于 2020-1-10 08:58:19 | 显示全部楼层 |阅读模式
2金钱
在红外接收实验里的红外驱动中time_cnt寄存器的没有看懂
//对红外的各个状态进行计数
always @(posedge div_clk or negedge sys_rst_n) begin
    if(!sys_rst_n)
        time_cnt <= 8'b0;
    else if(time_cnt_clr)
        time_cnt <= 8'b0;
        time_cnt <= time_cnt + 8'b1;
end
        always @(posedge div_clk or negedge sys_rst_n ) begin
    if (!sys_rst_n) begin
        time_cnt_clr <= 1'b0; //计数器清零信号
        time_done <= 1'b0;    //计时完成信号
        error_en <= 1'b0;     //错误信号
        judge_flag <= 1'b0;   //检测出的标志信号 0:同步码高电平(空闲信号)  1:重复码
        data_en <= 1'b0;      ////数据有效信号
        data <= 8'd0;
        repeat_en <= 1'b0;    //重复码有效信号
        data_cnt <= 6'd0;     //对接收的数据进行计数
        data_temp <= 32'd0;   //暂存收到的控制码和控制反码
    end
    else begin
        time_done <= 1'b0;
        error_en <= 1'b0;
        repeat_en <= 1'b0;
        data_en <= 1'b0;
        case(cur_state)
            st_idle           : begin   //空闲状态
                time_cnt_clr <= 1'b1;
                if(remote_in_d0 == 1'b0)
            end
            st_start_low_9ms  : begin    //监测同步码低电平   //9ms/0.125ms = 72
                if(pos_remote_in) begin
                    time_cnt_clr <= 1'b1;        问题:当time_cnt_clr <= 1'b1时 time_cnt <= 8'b0,下一行的  if(time_cnt >= 69 && time_cnt <= 75) 就不能满足了   实在想不通
                        time_done <= 1'b1;
                        error_en <= 1'b1;
                end
            end
            st_start_judge : begin     //判断重复码和同步码高电平(空闲信号)
                if(neg_remote_in) begin
                    //重复码高电平2.25ms 2.25/0.125 = 18
                    if(time_cnt >= 15 && time_cnt <= 20) begin
                        time_done <= 1'b1;
                        judge_flag <= 1'b1;
                    end
                    //同步码高电平4.5ms 4.5/0.125 = 36
                    else if(time_cnt >= 33 && time_cnt <= 38) begin
                        time_done <= 1'b1;
                        judge_flag <= 1'b0;
                    end
                        error_en <= 1'b1;
                end
            end
            st_rec_data : begin          //接收数据
                    if(data_cnt == 6'd32) begin
                        data_en <= 1'b1;
                        data_cnt <= 6'd0;
                        data_temp <= 16'd0;
                        if(data_temp[7:0] == ~data_temp[15:8])    //校验控制码和控制反码
                            data <= data_temp[7:0];
                    end
                end
                else if(neg_remote_in) begin
                    data_cnt <= data_cnt + 1'b1;
                    //解析控制码和控制反码
                    if(data_cnt >= 6'd16 && data_cnt <= 6'd31) begin
                        if(time_cnt >= 2 && time_cnt <= 6) begin  //0.565/0.125 = 4.52
                            data_temp <= {1'b0,data_temp[15:1]};  //逻辑“0”
                        end
                        else if(time_cnt >= 10 && time_cnt <= 15) //1.69/0.125 = 13.52
                            data_temp <= {1'b1,data_temp[15:1]};  //逻辑“1”
                    end
                end
            end
            st_repeat_code : begin        //重复码
                    repeat_en <= 1'b1;
                end
            end
            default : ;
        endcase
    end
两个always是并行的,begin-end里的非阻塞赋值也是并行的,在这个时钟周期里赋值给time_cnt_clr的时候,同时也判断了 time_cnt的值,第一个always也已经判断完此时time_cnt_clr!=1而执行 time_cnt
1103
1103
2018-8-10
151 小时
发表于 2020-1-10 08:58:20 | 显示全部楼层
希庆 发表于 2020-1-10 11:35
1.下一个时钟周期time_cnt_clr才变为1?   什么意思  “time_cnt_clr
两个always是并行的,begin-end里的非阻塞赋值也是并行的,在这个时钟周期里赋值给time_cnt_clr的时候,同时也判断了 time_cnt的值,第一个always也已经判断完此时time_cnt_clr!=1而执行 time_cnt <= time_cnt + 8'b1;了
2019-12-20
 楼主| 发表于 2020-1-10 09:27:26 | 显示全部楼层
顶一下
1103
1103
2018-8-10
151 小时
发表于 2020-1-10 10:43:53 | 显示全部楼层
2019-12-20
 楼主| 发表于 2020-1-10 11:35:36 | 显示全部楼层
kkkkklsq 发表于 2020-1-10 10:43
下一个时钟周期time_cnt_clr才变为1,第一个always里才会把time_cnt清0
1.下一个时钟周期time_cnt_clr才变为1?   什么意思  “time_cnt_clr <= 1'b1;” 已经给time_cnt_clr赋值了2.下一个语句“if(time_cnt >= 69 && time_cnt <= 75) ” 和 第一个always里的“time_cnt <= 8'b0”  不是处在同一个时钟周期的吗?
2019-5-23
发表于 2020-1-10 19:41:50 | 显示全部楼层
我认为还是要先理解原理,程序可以自己写
2020-1-12
发表于 2020-1-12 14:10:54 | 显示全部楼层
GMT+8, 2026-10-22 15:31
