查看: 8707|回复: 4
Linux 内核编译报错,但是缺少的库又装不上!
83
167
167
2019-7-11
42 小时
发表于 2020-1-16 13:33:13 | 显示全部楼层 |阅读模式
3金钱
  1.   CHK     include/config/kernel.release
  2.   CHK     include/generated/uapi/linux/version.h
  3.   CHK     include/generated/utsrelease.h
  4. make[1]: 'include/generated/mach-types.h' is up to date.
  5.   CHK     include/generated/bounds.h
  6.   CHK     include/generated/asm-offsets.h
  7.   CALL    scripts/checksyscalls.sh
  8.   CHK     include/generated/compile.h
  9.   Building modules, stage 2.
  10.   Kernel: arch/arm/boot/Image is ready
  11.   LZO     arch/arm/boot/compressed/piggy.lzo
  12. /bin/sh: 1: lzop: not found
  13.   CC      arch/arm/boot/compressed/decompress.o
  14.   CC      arch/arm/boot/compressed/string.o
  15. arch/arm/boot/compressed/Makefile:180: recipe for target 'arch/arm/boot/compressed/piggy.lzo' failed
  16. make[2]: *** [arch/arm/boot/compressed/piggy.lzo] Error 1
  17. make[2]: *** Waiting for unfinished jobs....
  18.   MODPOST 17 modules
  19. make[2]: *** wait: No child processes.  Stop.
  20. arch/arm/boot/Makefile:52: recipe for target 'arch/arm/boot/compressed/vmlinux' failed
  21. make[1]: *** [arch/arm/boot/compressed/vmlinux] Error 2
  22. arch/arm/Makefile:316: recipe for target 'zImage' failed
  23. make: *** [zImage] Error 2
  24. make: *** Waiting for unfinished jobs....
sudo apt-get install lzop 搞定了
83
167
167
2019-7-11
42 小时
 楼主| 发表于 2020-1-16 13:33:14 | 显示全部楼层
搞定了
83
167
167
2019-7-11
42 小时
 楼主| 发表于 2020-1-16 13:34:16 | 显示全部楼层
原因:缺少工具lzo,lzop
解决:
1、lzo安装
        1)、wget http://www.oberhumer.com/opensource/lzo/download/lzo-2.06.tar.gz
        2)、 sudo su
                tar xzvf lzo-2.06.tar.gz
        3)、cd lzo-2.06
            ./configure --enable-shared
        4)、make
              make install
2、lzop安装:
        1)、wget 'http://www.lzop.org/download/lzop-1.03.tar.gz'
        2)、tar xzvf lzop-1.03.tar.gz
        3)、cd lzop-1.03
            ./configure
            ii)若出现configure: error: cannot compute sizeof (size_t)
                        See `config.log' for more details
            这个问题的原因是linux在查找动态链接库时,忽视了/usr/local/lib中一系列*.so,将其添加到配置文件中,就可以解决。
83
167
167
2019-7-11
42 小时
 楼主| 发表于 2020-1-16 13:39:45 | 显示全部楼层
如果第一个库不安装,第二个也会报错:
configure: error: LZO header files not found. Please check your installation or set the environment variable `CPPFLAGS'.
83
167
167
2019-7-11
42 小时
 楼主| 发表于 2020-1-16 17:26:30 | 显示全部楼层
GMT+8, 2026-10-31 04:00
