查看: 5347|回复: 1
stm32f030c8t6 读w25q80的ID不对 老是0XFFFF 求助 使用的SPI1 PA4片选 PA5clk PA6 MISO PA7 MOSI
95
490
490
2019-12-6
153 小时
发表于 2020-2-27 17:46:01 | 显示全部楼层 |阅读模式
SPI.C文件
#include "spi.h"
#include "delay.h"
void SPI1_Init(void)
        SPI_InitTypeDef  SPI_InitStructure;
          /* Enable the SPI periph */
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE); // 使SPI1总线时钟
          /* Enable SCK, MOSI, MISO GPIO clocks */
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE); //使能GPIOA时钟
        /* Configure SPI1 pins: NSS, SCK, MISO and MOSI */
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7; //PA5,PA6,PA7
        GPIO_InitStructure.GPIO_Speed =GPIO_Speed_Level_3; //高速
        GPIO_InitStructure.GPIO_Mode =GPIO_Mode_AF;     //复用模式
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;  // 推挽输出
        GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_UP;   //上拉
                //PA5,6,7管脚复用复用
        GPIO_PinAFConfig(GPIOA, GPIO_PinSource5, GPIO_AF_0 );  // PA5时钟
        GPIO_PinAFConfig(GPIOA, GPIO_PinSource7, GPIO_AF_0 ); //PA7 SPIMOSI
        GPIO_PinAFConfig(GPIOA, GPIO_PinSource6, GPIO_AF_0 );//PA6  SPIMISO
                GPIO_SetBits(GPIOA, GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);   //PA4,5,6,7设置为上拉
                //SPI_I2S_DeInit(SPI1);
        SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; //SPI1设置为两线全双工
        SPI_InitStructure.SPI_Mode = SPI_Mode_Master;                      //设置SPI1为主模式
        SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;                  //SPI发送接收8位帧结构
        SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;                        //串行时钟在不操作时,时钟为高电平
        SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;                       //第二个时钟沿开始采样数据
        SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;                          //NSS信号由软件(使用SSI位)管理
        SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_128; //定义波特率预分频的值:波特率预分频值为8
        SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;                 //数据传输从MSB位开始
        SPI_InitStructure.SPI_CRCPolynomial = 7;                           //CRC值计算的多项式
                SPI_Init(SPI1, &SPI_InitStructure);
        //SPI_RxFIFOThresholdConfig(SPI1, SPI_RxFIFOThreshold_QF);//设置接收缓冲
        /* Enable SPI1  */
        SPI_Cmd(SPI1, ENABLE);  //使能 SPI 外设
                SPI1_ReadWriteByte(0xff);//启动传输
//SPI 速度设置函数
//SpeedSet:
//SPI_BaudRatePrescaler_2   2分频
//SPI_BaudRatePrescaler_8   8分频
//SPI_BaudRatePrescaler_16  16分频
//SPI_BaudRatePrescaler_256 256分频
void SPI1_SetSpeed(u8 SPI_BaudRatePrescaler)
  assert_param(IS_SPI_BAUDRATE_PRESCALER(SPI_BaudRatePrescaler));
        SPI1->CR1&=0XFFC7;
        SPI1->CR1|=SPI_BaudRatePrescaler;        //设置SPI1速度
        SPI_Cmd(SPI1,ENABLE);
//SPIx 读写一个字节
//TxData:要写入的字节
//返回值:读取到的字节
u8 SPI1_ReadWriteByte(u8 TxData)
        u8 retry=0;
        while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET) //检查指定的SPI标志位设置与否:发送缓存空标志位
                retry++;
                if(retry>200)return 0;
    SPI_I2S_SendData16(SPI1, TxData); //通过外设SPIx发送一个数据
//        SPI_I2S_SendData(SPI2, TxData); //通过外设SPIx发送一个数据
        retry=0;
        while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET) //检查指定的SPI标志位设置与否:接受缓存非空标志位
                retry++;
//    return  SPI_ReceiveData8(SPI1);        //返回通过SPIx最近接收的数据
                return SPI_I2S_ReceiveData16(SPI1); //返回通过SPIx最近接收的数据
SPI.H文件
#ifndef __SPI_H
#define __SPI_H
#include "sys.h"
void SPI1_Init(void);                         //初始化SPI口
void SPI1_SetSpeed(u8 SpeedSet); //设置SPI速度
u8 SPI1_ReadWriteByte(u8 TxData);//SPI总线读写一个字节
#endif
W25Q80.C文件
#include "w25qxx.h"
#include "spi.h"
#include "delay.h"
#include "usart.h"
u16 W25QXX_TYPE=W25Q80;        //默认是W25Q80
//4Kbytes为一个Sector
//16个扇区为1个Block
//W25Q80
//容量为1M字节,共有8个Block,256个Sector
//初始化SPI FLASH的IO口
void W25QXX_Init(void)
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE); //PORTA时钟使能
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;              // PA4
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;         //输出模式
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_Level_3;  //高速
        GPIO_InitStructure.GPIO_OType=GPIO_OType_PP;  //推挽输出
          GPIO_SetBits(GPIOA,GPIO_Pin_4);
    W25QXX_CS=1;                                //SPI FLASH不选中
        SPI1_Init();                           //初始化SPI
        SPI1_SetSpeed(SPI_BaudRatePrescaler_2);//设置为18M时钟,高速模式
        W25QXX_TYPE=W25QXX_ReadID();//读取FLASH ID.
//读取W25QXX的状态寄存器
//BIT7  6   5   4   3   2   1   0
//SPR   RV  TB BP2 BP1 BP0 WEL BUSY
//SPR:默认0,状态寄存器保护位,配合WP使用
//TB,BP2,BP1,BP0:FLASH区域写保护设置
//WEL:写使能锁定
//BUSY:忙标记位(1,忙;0,空闲)
//默认:0x00
u8 W25QXX_ReadSR(void)
        u8 byte=0;
        W25QXX_CS=0;                            //使能器件
        SPI1_ReadWriteByte(W25X_ReadStatusReg); //发送读取状态寄存器命令
        byte=SPI1_ReadWriteByte(0Xff);          //读取一个字节
        W25QXX_CS=1;                            //取消片选
        return byte;
//写W25QXX状态寄存器
//只有SPR,TB,BP2,BP1,BP0(bit 7,5,4,3,2)可以写!!!
void W25QXX_Write_SR(u8 sr)
        W25QXX_CS=0;                            //使能器件
        SPI1_ReadWriteByte(W25X_WriteStatusReg);//发送写取状态寄存器命令
        SPI1_ReadWriteByte(sr);                       //写入一个字节
        W25QXX_CS=1;                            //取消片选
//W25QXX写使能
//将WEL置位
void W25QXX_Write_Enable(void)
        W25QXX_CS=0;                                  //使能器件
    SPI1_ReadWriteByte(W25X_WriteEnable);         //发送写使能
        W25QXX_CS=1;                                   //取消片选
//W25QXX写禁止
//将WEL清零
void W25QXX_Write_Disable(void)
        W25QXX_CS=0;                            //使能器件
    SPI1_ReadWriteByte(W25X_WriteDisable);  //发送写禁止指令
        W25QXX_CS=1;                            //取消片选
//读取芯片ID
//返回值如下:
//0XEF13,表示芯片型号为W25Q80
//0XEF14,表示芯片型号为W25Q16
//0XEF15,表示芯片型号为W25Q32
//0XEF16,表示芯片型号为W25Q64
//0XEF17,表示芯片型号为W25Q128
u16 W25QXX_ReadID(void)
        u16 Temp = 0;
        W25QXX_CS=0;
        SPI1_ReadWriteByte(0x90);//发送读取ID命令
        SPI1_ReadWriteByte(0x00);
//        SPI1_ReadWriteByte(0xFF); //自己加上去的
        Temp|=SPI1_ReadWriteByte(0xFF)<<8;
        Temp|=SPI1_ReadWriteByte(0xFF);
        W25QXX_CS=1;
        return Temp;
//读取SPI FLASH
//在指定地址开始读取指定长度的数据
//pBuffer:数据存储区
//ReadAddr:开始读取的地址(24bit)
//NumByteToRead:要读取的字节数(最大65535)
void W25QXX_Read(u8* pBuffer,u32 ReadAddr,u16 NumByteToRead)
        u16 i;
        W25QXX_CS=0;                                    //使能器件
    SPI1_ReadWriteByte(W25X_ReadData);                 //发送读取命令
    SPI1_ReadWriteByte((u8)((ReadAddr)>>16));          //发送24bit地址
    SPI1_ReadWriteByte((u8)((ReadAddr)>>8));
    SPI1_ReadWriteByte((u8)ReadAddr);
    for(i=0;i<NumByteToRead;i++)
        pBuffer[i]=SPI1_ReadWriteByte(0XFF);           //循环读数
        W25QXX_CS=1;
//SPI在一页(0~65535)内写入少于256个字节的数据
//在指定地址开始写入最大256字节的数据
//pBuffer:数据存储区
//WriteAddr:开始写入的地址(24bit)
//NumByteToWrite:要写入的字节数(最大256),该数不应该超过该页的剩余字节数!!!
void W25QXX_Write_Page(u8* pBuffer,u32 WriteAddr,u16 NumByteToWrite)
        u16 i;
    W25QXX_Write_Enable();                          //SET WEL
        W25QXX_CS=0;                                    //使能器件
    SPI1_ReadWriteByte(W25X_PageProgram);              //发送写页命令
    SPI1_ReadWriteByte((u8)((WriteAddr)>>16));         //发送24bit地址
    SPI1_ReadWriteByte((u8)((WriteAddr)>>8));
    SPI1_ReadWriteByte((u8)WriteAddr);
    for(i=0;i<NumByteToWrite;i++)SPI1_ReadWriteByte(pBuffer[i]);//循环写数
        W25QXX_CS=1;                                    //取消片选
        W25QXX_Wait_Busy();                                                           //等待写入结束
//无检验写SPI FLASH
//必须确保所写的地址范围内的数据全部为0XFF,否则在非0XFF处写入的数据将失败!
//具有自动换页功能
//在指定地址开始写入指定长度的数据,但是要确保地址不越界!
//pBuffer:数据存储区
//NumByteToWrite:要写入的字节数(最大65535)
//CHECK OK
void W25QXX_Write_NoCheck(u8* pBuffer,u32 WriteAddr,u16 NumByteToWrite)
        u16 pageremain;
        pageremain=256-WriteAddr%256; //单页剩余的字节数
        if(NumByteToWrite<=pageremain)pageremain=NumByteToWrite;//不大于256个字节
                W25QXX_Write_Page(pBuffer,WriteAddr,pageremain);
                if(NumByteToWrite==pageremain)break;//写入结束了
                 else //NumByteToWrite>pageremain
                        pBuffer+=pageremain;
                        WriteAddr+=pageremain;
                        NumByteToWrite-=pageremain;                          //减去已经写入了的字节数
                        if(NumByteToWrite>256)pageremain=256; //一次可以写入256个字节
                        else pageremain=NumByteToWrite;           //不够256个字节了
//写SPI FLASH
//在指定地址开始写入指定长度的数据
//该函数带擦除操作!
//pBuffer:数据存储区
u8 W25QXX_BUFFER[4096];
void W25QXX_Write(u8* pBuffer,u32 WriteAddr,u16 NumByteToWrite)
        u32 secpos;
        u16 secoff;
        u16 secremain;
        u16 i;
        u8 * W25QXX_BUF;
           W25QXX_BUF=W25QXX_BUFFER;
        secpos=WriteAddr/4096;//扇区地址
        secoff=WriteAddr%4096;//在扇区内的偏移
        secremain=4096-secoff;//扇区剩余空间大小
        //printf("ad:%X,nb:%X\r\n",WriteAddr,NumByteToWrite);//测试用
        if(NumByteToWrite<=secremain)secremain=NumByteToWrite;//不大于4096个字节
                W25QXX_Read(W25QXX_BUF,secpos*4096,4096);//读出整个扇区的内容
                for(i=0;i<secremain;i++)//校验数据
                        if(W25QXX_BUF[secoff+i]!=0XFF)break;//需要擦除
                if(i<secremain)//需要擦除
                        W25QXX_Erase_Sector(secpos);                //擦除这个扇区
                        for(i=0;i<secremain;i++)                           //复制
                                W25QXX_BUF[i+secoff]=pBuffer[i];
                        W25QXX_Write_NoCheck(W25QXX_BUF,secpos*4096,4096);//写入整个扇区
                }else W25QXX_Write_NoCheck(pBuffer,WriteAddr,secremain);//写已经擦除了的,直接写入扇区剩余区间.
                if(NumByteToWrite==secremain)break;//写入结束了
                else//写入未结束
                        secpos++;//扇区地址增1
                        secoff=0;//偏移位置为0
                           pBuffer+=secremain;                                  //指针偏移
                        WriteAddr+=secremain;                                //写地址偏移
                           NumByteToWrite-=secremain;                        //字节数递减
                        if(NumByteToWrite>4096)secremain=4096;//下一个扇区还是写不完
                        else secremain=NumByteToWrite;                //下一个扇区可以写完了
//擦除整个芯片
//等待时间超长...
void W25QXX_Erase_Chip(void)
    W25QXX_Wait_Busy();
          W25QXX_CS=0;                                    //使能器件
    SPI1_ReadWriteByte(W25X_ChipErase);                //发送片擦除命令
        W25QXX_CS=1;                                    //取消片选
        W25QXX_Wait_Busy();                                                      //等待芯片擦除结束
//擦除一个扇区
//Dst_Addr:扇区地址 根据实际容量设置
//擦除一个山区的最少时间:150ms
void W25QXX_Erase_Sector(u32 Dst_Addr)
        //监视falsh擦除情况,测试用
        printf("fe:%x\r\n",Dst_Addr);
        Dst_Addr*=4096;
    W25QXX_Wait_Busy();
          W25QXX_CS=0;                                    //使能器件
    SPI1_ReadWriteByte(W25X_SectorErase);              //发送扇区擦除指令
    SPI1_ReadWriteByte((u8)((Dst_Addr)>>16));          //发送24bit地址
    SPI1_ReadWriteByte((u8)((Dst_Addr)>>8));
    SPI1_ReadWriteByte((u8)Dst_Addr);
        W25QXX_CS=1;                                    //取消片选
    W25QXX_Wait_Busy();                                                      //等待擦除完成
//等待空闲
void W25QXX_Wait_Busy(void)
        while((W25QXX_ReadSR()&0x01)==0x01);                  // 等待BUSY位清空
//进入掉电模式
void W25QXX_PowerDown(void)
          W25QXX_CS=0;                                            //使能器件
    SPI1_ReadWriteByte(W25X_PowerDown);        //发送掉电命令
        W25QXX_CS=1;                                    //取消片选
    delay_us(3);                               //等待TPD
//唤醒
void W25QXX_WAKEUP(void)
          W25QXX_CS=0;                                    //使能器件
    SPI1_ReadWriteByte(W25X_ReleasePowerDown);        //  send W25X_PowerDown command 0xAB
        W25QXX_CS=1;                                    //取消片选
    delay_us(3);                                    //等待TRES1
W25Q80.H文件
#ifndef __FLASH_H
#define __FLASH_H
#include "sys.h"
//W25X系列/Q系列芯片列表
//W25Q80  ID  0XEF13
//W25Q16  ID  0XEF14
//W25Q32  ID  0XEF15
//W25Q64  ID  0XEF16
//W25Q128 ID  0XEF17
#define W25Q80         0XEF13
#define W25Q16         0XEF14
#define W25Q32         0XEF15
#define W25Q64         0XEF16
#define W25Q128        0XEF17
extern u16 W25QXX_TYPE;                                        //定义W25QXX芯片型号
#define        W25QXX_CS                 PAout->b4                 //W25QXX的片选信号 PA4
//指令表
#define W25X_WriteEnable                0x06
#define W25X_WriteDisable                0x04
#define W25X_ReadStatusReg                0x05
#define W25X_WriteStatusReg                0x01
#define W25X_ReadData                        0x03
#define W25X_FastReadData                0x0B
#define W25X_FastReadDual                0x3B
#define W25X_PageProgram                0x02
#define W25X_BlockErase                        0xD8
#define W25X_SectorErase                0x20
#define W25X_ChipErase                        0xC7
#define W25X_PowerDown                        0xB9
#define W25X_ReleasePowerDown        0xAB
#define W25X_DeviceID                        0xAB
#define W25X_ManufactDeviceID        0x90
#define W25X_JedecDeviceID                0x9F
void W25QXX_Init(void);
u16  W25QXX_ReadID(void);                              //读取FLASH ID
u8         W25QXX_ReadSR(void);                        //读取状态寄存器
void W25QXX_Write_SR(u8 sr);                          //写状态寄存器
void W25QXX_Write_Enable(void);                  //写使能
void W25QXX_Write_Disable(void);                //写保护
void W25QXX_Write_NoCheck(u8* pBuffer,u32 WriteAddr,u16 NumByteToWrite);
void W25QXX_Read(u8* pBuffer,u32 ReadAddr,u16 NumByteToRead);   //读取flash
void W25QXX_Write(u8* pBuffer,u32 WriteAddr,u16 NumByteToWrite);//写入flash
void W25QXX_Erase_Chip(void);                      //整片擦除
void W25QXX_Erase_Sector(u32 Dst_Addr);        //扇区擦除
void W25QXX_Wait_Busy(void);                   //等待空闲
void W25QXX_PowerDown(void);                //进入掉电模式
void W25QXX_WAKEUP(void);                                //唤醒
#endif
主函数
#include "sys.h"
#include "usart.h"
#include "delay.h"
#include "hal_led.h"
#include "hal_timer.h"
#include "w25qxx.h"
#include "spi.h"
#include "stdio.h"
//要写入到W25Q80的字符串数组
//const u8 TEXT_Buffer[]={"ELITE STM32 SPI TEST"};
//#define SIZE sizeof(TEXT_Buffer)
int main(void)          //主函数
        delay_init();     //延时函数初始化
        uart_init(115200); //串口初始化
        HAL_LEDInit();   //led初始化
        W25QXX_Init();                        //W25QXX初始化
        SPI1_SetSpeed( SPI_BaudRatePrescaler_256);  //速度最低
//   USART_SendData(USART1, 255);
        if(W25QXX_ReadID() ==W25Q80){      //W25QXX_ReadID() ==W25Q80
        printf("HELLO");
        }else {
        printf("id=%X\n",W25QXX_ReadID());
        GPIOA->BRR=GPIO_Pin_3;
    delay_ms(500);
        GPIOA->BSRR=GPIO_Pin_3;
        delay_ms(500);
    return  0;
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *   where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
69
586
586
2016-7-29
132 小时
发表于 2025-8-7 18:17:48 | 显示全部楼层
前辈,您的问题解决没,可以分享下吗?我也遇到无法通信的问题了,我用的SPI
Planets, no limit!
GMT+8, 2026-10-31 02:17
