- 积分
- 178
- 金钱
- 178
- 注册时间
- 2020-3-11
- 在线时间
- 17 小时
Parsing recipes: 100% |#########################################| Time: 00:00:37
Parsing of 2215 .bb files complete (0 cached, 2215 parsed). 2790 targets, 188 skipped, 5 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION = "1.30.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "Ubuntu-16.04"
TARGET_SYS = "arm-poky-linux-gnueabi"
MACHINE = "imx6ull14x14evk"
DISTRO = "fsl-imx-x11"
DISTRO_VERSION = "4.1.15-2.1.0"
TUNE_FEATURES = "arm armv7ve vfp neon callconvention-hard cortexa7"
TARGET_FPU = "hard"
meta
meta-yocto
meta-oe
meta-multimedia
meta-fsl-arm
meta-fsl-arm-extra
meta-fsl-demos
meta-bsp
meta-sdk
meta-browser
meta-gnome
meta-networking
meta-python
meta-filesystems
meta-qt5 = "<unknown>:<unknown>"
NOTE: Preparing RunQueue
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: qtbase-5.6.1+gitAUTOINC+7bf002c3b3-r0 do_configure: Function failed: do_configure (log file is located at /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/work/cortexa7hf-neon-poky-linux-gnueabi/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0/temp/log.do_configure.71228)
ERROR: Logfile of failure stored in: /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/work/cortexa7hf-neon-poky-linux-gnueabi/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0/temp/log.do_configure.71228
Log data follows:
| DEBUG: Executing python function sysroot_cleansstate
| DEBUG: Python function sysroot_cleansstate finished
| DEBUG: Executing shell function qmake5_base_preconfigure
| DEBUG: Shell function qmake5_base_preconfigure finished
| DEBUG: Executing shell function do_configure
| This is the Qt Open Source Edition.
| You are licensed to use this software under the terms of
| the Lesser GNU General Public License (LGPL) versions 2.1.
| You are also licensed to use this software under the terms of
| the GNU Lesser General Public License (LGPL) versions 3.
| You have already accepted the terms of the Open Source license.
| /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/work/cortexa7hf-neon-poky-linux-gnueabi/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0/git/configure: 1: /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/work/cortexa7hf-neon-poky-linux-gnueabi/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0/git/configure: /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/work/cortexa7hf-neon-poky-linux-gnueabi/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0/git/config.tests/unix/makeabs: not found
| Performing shadow build...
| Preparing build tree...
| Running configuration tests (phase 1)...
| WARNING: Unable to find file /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/work/cortexa7hf-neon-poky-linux-gnueabi/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0/git/mkspecs/linux-oe-g++/../oe-device-extra.pri
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -c -fvisibility=hidden fvisibility.c
| Symbol visibility control enabled.
| /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi-ld.gold: error: cannot open crt1.o: No such file or directory
| /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi-ld.gold: error: cannot open crti.o: No such file or directory
| /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi-ld.gold: error: cannot open crtbegin.o: No such file or directory
| /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi-ld.gold: error: cannot open crtend.o: No such file or directory
| /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi-ld.gold: error: cannot open crtn.o: No such file or directory
| /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi-ld.gold: error: cannot find -lgcc
| /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi-ld.gold: error: /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk/usr/lib/libstdc++.so uses VFP register arguments, output does not
| /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi-ld.gold: error: /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk/usr/lib/libm.so uses VFP register arguments, output does not
| /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi-ld.gold: error: /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk/lib/libgcc_s.so.1 uses VFP register arguments, output does not
| /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi-ld.gold: error: /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk/lib/libc.so.6 uses VFP register arguments, output does not
| /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi-ld.gold: error: /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk/lib/ld-linux-armhf.so.3 uses VFP register arguments, output does not
| collect2: error: ld returned 1 exit status
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -o libtest.so -shared -Wl,-Bsymbolic-functions -fPIC bsymbolic_functions.c
| bsymbolic_functions.c:2:2: error: #error "Symbolic function binding on this architecture may be broken, disabling it (see QTBUG-36129)."
| Symbolic function binding disabled.
| DEFAULT_INCDIRS="/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk/usr/include/c++/5.3.0
| /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk/usr/include/c++/5.3.0/arm-poky-linux-gnueabi
| /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk/usr/include/c++/5.3.0/backward
| /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux/usr/lib/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/5.3.0/include
| /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk/usr/lib/gcc/arm-poky-linux-gnueabi/5.3.0/include
| /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux/usr/lib/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/5.3.0/include-fixed
| DEFAULT_LIBDIRS="/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux/usr/lib/arm-poky-linux-gnueabi/gcc/arm-poky-linux-gnueabi/5.3.0
| /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk/usr/lib/arm-poky-linux-gnueabi/5.3.0
| Done running configuration tests.
| <srcbase> = /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/work/cortexa7hf-neon-poky-linux-gnueabi/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0/git
| <outbase> = /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/work/cortexa7hf-neon-poky-linux-gnueabi/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0/build
| QtCore: created fwd-include header(s) for <srcbase>/src/corelib/animation/ { qabstractanimation.h (1), qabstractanimation_p.h (1), qanimationgroup.h (1), qanimationgroup_p.h (1), qparallelanimationgroup.h (1), qparallelanimationgroup_p.h (1), qpauseanimation.h (1), qpropertyanimation.h (1), qpropertyanimation_p.h (1), qsequentialanimationgroup.h (1), qsequentialanimationgroup_p.h (1), qvariantanimation.h (1), qvariantanimation_p.h (1) }
| QtCore: created fwd-include header(s) for <srcbase>/src/corelib/arch/ { qatomic_armv5.h (1), qatomic_armv6.h (1), qatomic_armv7.h (1), qatomic_bootstrap.h (1), qatomic_cxx11.h (1), qatomic_gcc.h (1), qatomic_ia64.h (1), qatomic_msvc.h (1), qatomic_unix.h (1), qatomic_x86.h (1) }
| QtCore: created fwd-include header(s) for <srcbase>/src/corelib/codecs/ { cp949codetbl_p.h (1), qbig5codec_p.h (1), qeucjpcodec_p.h (1), qeuckrcodec_p.h (1), qgb18030codec_p.h (1), qiconvcodec_p.h (1), qicucodec_p.h (1), qisciicodec_p.h (1), qjiscodec_p.h (1), qjpunicode_p.h (1), qlatincodec_p.h (1), qsimplecodec_p.h (1), qsjiscodec_p.h (1), qtextcodec.h (1), qtextcodec_p.h (1), qtsciicodec_p.h (1), qutfcodec_p.h (1), qwindowscodec_p.h (1) }
| QtCore: created fwd-include header(s) for <srcbase>/src/corelib/global/ { qcompilerdetection.h (1), qconfig-dist.h (1), qconfig-large.h (1), qconfig-medium.h (1), qconfig-minimal.h (1), qconfig-nacl.h (1), qconfig-small.h (1), qendian.h (1), qflags.h (1), qglobal.h (1), qglobalstatic.h (1), qhooks_p.h (1), qisenum.h (1), qlibraryinfo.h (1), qlogging.h (1), qnamespace.h (1), qnumeric.h (1), qnumeric_p.h (1), qprocessordetection.h (1), qsysinfo.h (1), qsystemdetection.h (1), qt_pch.h (1), qt_windows.h (1), qtypeinfo.h (1), qtypetraits.h (1), qversiontagging.h (1) }
| QtCore: created fwd-include header(s) for <srcbase>/src/corelib/io/ { qabstractfileengine_p.h (1), qbuffer.h (1), qdatastream.h (1), qdatastream_p.h (1), qdataurl_p.h (1), qdebug.h (1), qdebug_p.h (1), qdir.h (1), qdir_p.h (1), qdiriterator.h (1), qfile.h (1), qfile_p.h (1), qfiledevice.h (1), qfiledevice_p.h (1), qfileinfo.h (1), qfileinfo_p.h (1), qfileselector.h (1), qfileselector_p.h (1), qfilesystemengine_p.h (1), qfilesystementry_p.h (1), qfilesystemiterator_p.h (1), qfilesystemmetadata_p.h (1), qfilesystemwatcher.h (1), qfilesystemwatcher_fsevents_p.h (1), qfilesystemwatcher_inotify_p.h (1), qfilesystemwatcher_kqueue_p.h (1), qfilesystemwatcher_p.h (1), qfilesystemwatcher_polling_p.h (1), qfilesystemwatcher_win_p.h (1), qfsfileengine_iterator_p.h (1), qfsfileengine_p.h (1), qiodevice.h (1), qiodevice_p.h (1), qipaddress_p.h (1), qlockfile.h (1), qlockfile_p.h (1), qloggingcategory.h (1), qloggingregistry_p.h (1), qnoncontiguousbytedevice_p.h (1), qprocess.h (1), qprocess_p.h (1), qresource.h (1), qresource_iterator_p.h (1), qresource_p.h (1), qsavefile.h (1), qsavefile_p.h (1), qsettings.h (1), qsettings_p.h (1), qstandardpaths.h (1), qstorageinfo.h (1), qstorageinfo_p.h (1), qtemporarydir.h (1), qtemporaryfile.h (1), qtemporaryfile_p.h (1), qtextstream.h (1), qtextstream_p.h (1), qtldurl_p.h (1), qurl.h (1), qurl_p.h (1), qurlquery.h (1), qurltlds_p.h (1), qwindowspipereader_p.h (1), qwindowspipewriter_p.h (1), qwinoverlappedionotifier_p.h (1) }
| QtCore: created fwd-include header(s) for <srcbase>/src/corelib/itemmodels/ { qabstractitemmodel.h (1), qabstractitemmodel_p.h (1), qabstractproxymodel.h (1), qabstractproxymodel_p.h (1), qidentityproxymodel.h (1), qitemselectionmodel.h (1), qitemselectionmodel_p.h (1), qsortfilterproxymodel.h (1), qstringlistmodel.h (1) }
| QtCore: created fwd-include header(s) for <srcbase>/src/corelib/json/ { qjson_p.h (1), qjsonarray.h (1), qjsondocument.h (1), qjsonobject.h (1), qjsonparser_p.h (1), qjsonvalue.h (1), qjsonwriter_p.h (1) }
| QtCore: created fwd-include header(s) for <srcbase>/src/corelib/kernel/ { qabstracteventdispatcher.h (1), qabstracteventdispatcher_p.h (1), qabstractnativeeventfilter.h (1), qbasictimer.h (1), qcfsocketnotifier_p.h (1), qcore_mac_p.h (1), qcore_unix_p.h (1), qcoreapplication.h (1), qcoreapplication_p.h (1), qcorecmdlineargs_p.h (1), qcoreevent.h (1), qcoreglobaldata_p.h (1), qcrashhandler_p.h (1), qeventdispatcher_blackberry_p.h (1), qeventdispatcher_cf_p.h (1), qeventdispatcher_glib_p.h (1), qeventdispatcher_unix_p.h (1), qeventdispatcher_win_p.h (1), qeventdispatcher_winrt_p.h (1), qeventloop.h (1), qeventloop_p.h (1), qfunctions_fake_env_p.h (1), qfunctions_nacl.h (1), qfunctions_p.h (1), qfunctions_vxworks.h (1), qfunctions_wince.h (1), qfunctions_winrt.h (1), qjni_p.h (1), qjnihelpers_p.h (1), qmath.h (1), qmetaobject.h (1), qmetaobject_moc_p.h (1), qmetaobject_p.h (1), qmetaobjectbuilder_p.h (1), qmetatype.h (1), qmetatype_p.h (1), qmetatypeswitcher_p.h (1), qmimedata.h (1), qobject.h (1), qobject_impl.h (1), qobject_p.h (1), qobjectcleanuphandler.h (1), qobjectdefs.h (1), qobjectdefs_impl.h (1), qpointer.h (1), qppsattribute_p.h (1), qppsattributeprivate_p.h (1), qppsobject_p.h (1), qppsobjectprivate_p.h (1), qsharedmemory.h (1), qsharedmemory_p.h (1), qsignalmapper.h (1), qsocketnotifier.h (1), qsystemerror_p.h (1), qsystemsemaphore.h (1), qsystemsemaphore_p.h (1), qtimer.h (1), qtimerinfo_unix_p.h (1), qtranslator.h (1), qtranslator_p.h (1), qvariant.h (1), qvariant_p.h (1), qwineventnotifier.h (1) }
| QtCore: created fwd-include header(s) for <srcbase>/src/corelib/mimetypes/ { qmimedatabase.h (1), qmimedatabase_p.h (1), qmimeglobpattern_p.h (1), qmimemagicrule_p.h (1), qmimemagicrulematcher_p.h (1), qmimeprovider_p.h (1), qmimetype.h (1), qmimetype_p.h (1), qmimetypeparser_p.h (1) }
| QtCore: created fwd-include header(s) for <srcbase>/src/corelib/plugin/ { qelfparser_p.h (1), qfactoryinterface.h (1), qfactoryloader_p.h (1), qlibrary.h (1), qlibrary_p.h (1), qmachparser_p.h (1), qplugin.h (1), qpluginloader.h (1), qsystemlibrary_p.h (1), quuid.h (1) }
| QtCore: created fwd-include header(s) for <srcbase>/src/corelib/statemachine/ { qabstractstate.h (1), qabstractstate_p.h (1), qabstracttransition.h (1), qabstracttransition_p.h (1), qeventtransition.h (1), qeventtransition_p.h (1), qfinalstate.h (1), qfinalstate_p.h (1), qhistorystate.h (1), qhistorystate_p.h (1), qsignaleventgenerator_p.h (1), qsignaltransition.h (1), qsignaltransition_p.h (1), qstate.h (1), qstate_p.h (1), qstatemachine.h (1), qstatemachine_p.h (1) }
| QtCore: created fwd-include header(s) for <srcbase>/src/corelib/thread/ { qatomic.h (1), qbasicatomic.h (1), qexception.h (1), qfuture.h (1), qfutureinterface.h (1), qfutureinterface_p.h (1), qfuturesynchronizer.h (1), qfuturewatcher.h (1), qfuturewatcher_p.h (1), qgenericatomic.h (1), qmutex.h (1), qmutex_p.h (1), qmutexpool_p.h (1), qorderedmutexlocker_p.h (1), qreadwritelock.h (1), qreadwritelock_p.h (1), qresultstore.h (1), qrunnable.h (1), qsemaphore.h (1), qthread.h (1), qthread_p.h (1), qthreadpool.h (1), qthreadpool_p.h (1), qthreadstorage.h (1), qwaitcondition.h (1) }
| QtCore: created fwd-include header(s) for <srcbase>/src/corelib/tools/ { qalgorithms.h (1), qarraydata.h (1), qarraydataops.h (1), qarraydatapointer.h (1), qbitarray.h (1), qbytearray.h (1), qbytearray_p.h (1), qbytearraylist.h (1), qbytearraymatcher.h (1), qbytedata_p.h (1), qcache.h (1), qchar.h (1), qcollator.h (1), qcollator_p.h (1), qcommandlineoption.h (1), qcommandlineparser.h (1), qcontainerfwd.h (1), qcontiguouscache.h (1), qcryptographichash.h (1), qdatetime.h (1), qdatetime_p.h (1), qdatetimeparser_p.h (1), qeasingcurve.h (1), qelapsedtimer.h (1), qfreelist_p.h (1), qharfbuzz_p.h (1), qhash.h (1), qhashfunctions.h (1), qiterator.h (1), qline.h (1), qlinkedlist.h (1), qlist.h (1), qlocale.h (1), qlocale_blackberry.h (1), qlocale_data_p.h (1), qlocale_p.h (1), qlocale_tools_p.h (1), qmap.h (1), qmargins.h (1), qmessageauthenticationcode.h (1), qpair.h (1), qpodlist_p.h (1), qpoint.h (1), qqueue.h (1), qrect.h (1), qrefcount.h (1), qregexp.h (1), qregularexpression.h (1), qringbuffer_p.h (1), qscopedpointer.h (1), qscopedpointer_p.h (1), qscopedvaluerollback.h (1), qset.h (1), qshareddata.h (1), qsharedpointer.h (1), qsharedpointer_impl.h (1), qsimd_p.h (1), qsize.h (1), qstack.h (1), qstring.h (1), qstringalgorithms_p.h (1), qstringbuilder.h (1), qstringiterator_p.h (1), qstringlist.h (1), qstringmatcher.h (1), qtextboundaryfinder.h (1), qtimeline.h (1), qtimezone.h (1), qtimezoneprivate_data_p.h (1), qtimezoneprivate_p.h (1), qtools_p.h (1), qunicodetables_p.h (1), qunicodetools_p.h (1), qvarlengtharray.h (1), qvector.h (1), qversionnumber.h (1) }
| QtCore: created fwd-include header(s) for <srcbase>/src/corelib/xml/ { qxmlstream.h (1), qxmlstream_p.h (1), qxmlutils_p.h (1) }
| Creating qmake...
| WARNING: Unable to find file /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux/usr/lib/qt5/mkspecs/linux-oe-g++/../oe-device-extra.pri
| Running configuration tests (phase 2)...
| Found pkg-config from $PATH: /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux/usr/bin/pkg-config
| Determining architecture... ()
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -c -pipe -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/work/cortexa7hf-neon-poky-linux-gnueabi/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0=/usr/src/debug/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0 -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk= -fvisibility-inlines-hidden -g -DLINUX=1 -Wall -W -fPIC -I../../../git/config.tests/arch -I. -I../../../git/mkspecs/linux-oe-g++ -o arch.o ../../../git/config.tests/arch/arch.cpp
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -o arch arch.o
| Found architecture in binary
| CFG_CPUFEATURES=" neon"
| CFG_ARCH="arm"
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -c -pipe -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/work/cortexa7hf-neon-poky-linux-gnueabi/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0=/usr/src/debug/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0 -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk= -fvisibility-inlines-hidden -g -Wall -W -fPIC -I../../../git/config.tests/arch -I. -I/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux/usr/lib/qt5/mkspecs/linux-oe-g++ -o arch.o ../../../git/config.tests/arch/arch.cpp
| CFG_HOST_CPUFEATURES=" neon"
| CFG_HOST_ARCH="arm"
| System architecture: 'arm'
| Host architecture: 'arm'
| checking for C++11...
| Cannot read /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/work/cortexa7hf-neon-poky-linux-gnueabi/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0/git/mkspecs/oe-device-extra.pri: No such file or directory
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -c -pipe -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/work/cortexa7hf-neon-poky-linux-gnueabi/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0=/usr/src/debug/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0 -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk= -fvisibility-inlines-hidden -O2 -DLINUX=1 -std=gnu++0x -Wall -W -fPIC -I../../../../git/config.tests/common/c++11 -I. -I../../../../git/mkspecs/linux-oe-g++ -o c++11.o ../../../../git/config.tests/common/c++11/c++11.cpp
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -Wl,-O1 -o c++11 c++11.o
| C++11 enabled.
| checking for C++14...
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -c -pipe -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/work/cortexa7hf-neon-poky-linux-gnueabi/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0=/usr/src/debug/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0 -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk= -fvisibility-inlines-hidden -O2 -DLINUX=1 -std=gnu++1y -Wall -W -fPIC -I../../../../git/config.tests/common/c++14 -I. -I../../../../git/mkspecs/linux-oe-g++ -o c++14.o ../../../../git/config.tests/common/c++14/c++14.cpp
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -Wl,-O1 -o c++14 c++14.o
| C++14 enabled.
| checking for C++1z...
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -c -pipe -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/work/cortexa7hf-neon-poky-linux-gnueabi/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0=/usr/src/debug/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0 -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk= -fvisibility-inlines-hidden -O2 -DLINUX=1 -std=gnu++1z -Wall -W -fPIC -I../../../../git/config.tests/common/c++1z -I. -I../../../../git/mkspecs/linux-oe-g++ -o c++1z.o ../../../../git/config.tests/common/c++1z/c++1z.cpp
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -Wl,-O1 -o c++1z c++1z.o
| C++1z enabled.
| checking for default C++ standard edition...
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -pipe -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/work/cortexa7hf-neon-poky-linux-gnueabi/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0=/usr/src/debug/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0 -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk= -fvisibility-inlines-hidden -O2 -DLINUX=1 -Wall -W -fPIC -I../../../../git/config.tests/common/c++default -I. -I../../../../git/mkspecs/linux-oe-g++ -o c++default.ii -E ../../../../git/config.tests/common/c++default/c++default.cpp
| default C++ standard edition enabled.
| checking for 64-bit std::atomic...
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -c -pipe -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/work/cortexa7hf-neon-poky-linux-gnueabi/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0=/usr/src/debug/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0 -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk= -fvisibility-inlines-hidden -O2 -DLINUX=1 -std=gnu++0x -Wall -W -fPIC -I../../../../git/config.tests/common/atomic64 -I. -I../../../../git/mkspecs/linux-oe-g++ -o atomic64.o ../../../../git/config.tests/common/atomic64/atomic64.cpp
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -Wl,-O1 -o atomic64 atomic64.o
| 64-bit std::atomic enabled.
| checking for sse2...
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -c -pipe -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/work/cortexa7hf-neon-poky-linux-gnueabi/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0=/usr/src/debug/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0 -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk= -fvisibility-inlines-hidden -msse2 -g -DLINUX=1 -Wall -W -fPIC -I../../../../git/config.tests/common/sse2 -I. -I../../../../git/mkspecs/linux-oe-g++ -o sse2.o ../../../../git/config.tests/common/sse2/sse2.cpp
| arm-poky-linux-gnueabi-g++: error: unrecognized command line option '-msse2'
| Makefile:177: recipe for target 'sse2.o' failed
| make: *** [sse2.o] Error 1
| sse2 disabled.
| checking for ipc_sysv...
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -c -pipe -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/work/cortexa7hf-neon-poky-linux-gnueabi/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0=/usr/src/debug/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0 -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk= -fvisibility-inlines-hidden -O2 -DLINUX=1 -Wall -W -fPIC -I../../../../git/config.tests/unix/ipc_sysv -I. -I../../../../git/mkspecs/linux-oe-g++ -o ipc.o ../../../../git/config.tests/unix/ipc_sysv/ipc.cpp
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -Wl,-O1 -o ipc_sysv ipc.o
| ipc_sysv enabled.
| checking for dlopen...
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -c -pipe -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/work/cortexa7hf-neon-poky-linux-gnueabi/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0=/usr/src/debug/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0 -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk= -fvisibility-inlines-hidden -O2 -DLINUX=1 -Wall -W -fPIC -I../../../../git/config.tests/unix/dlopen -I. -I../../../../git/mkspecs/linux-oe-g++ -o dlopen.o ../../../../git/config.tests/unix/dlopen/dlopen.cpp
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -Wl,-O1 -o dlopen dlopen.o
| dlopen.o: In function `main':
| /usr/src/debug/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0/git/config.tests/unix/dlopen/dlopen.cpp:38: undefined reference to `dlopen'
| Makefile:85: recipe for target 'dlopen' failed
| make: *** [dlopen] Error 1
| dlopen disabled.
| checking for libdl...
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -c -pipe -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/work/cortexa7hf-neon-poky-linux-gnueabi/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0=/usr/src/debug/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0 -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk= -fvisibility-inlines-hidden -O2 -DLINUX=1 -Wall -W -fPIC -I../../../../git/config.tests/unix/libdl -I. -I../../../../git/mkspecs/linux-oe-g++ -o dlopen.o ../../../../git/config.tests/unix/dlopen/dlopen.cpp
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -Wl,-O1 -o libdl dlopen.o -ldl
| libdl enabled.
| checking for D-Bus...
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -c -pipe -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/work/cortexa7hf-neon-poky-linux-gnueabi/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0=/usr/src/debug/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0 -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk= -fvisibility-inlines-hidden -O2 -DLINUX=1 -Wall -W -fPIC -I../../../../git/config.tests/unix/dbus -I. -I/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk/usr/include/dbus-1.0 -I/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk/usr/lib/dbus-1.0/include -I../../../../git/mkspecs/linux-oe-g++ -o dbus.o ../../../../git/config.tests/unix/dbus/dbus.cpp
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -Wl,-O1 -o dbus dbus.o -ldbus-1
| D-Bus enabled.
| checking for Glib...
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -c -pipe -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/work/cortexa7hf-neon-poky-linux-gnueabi/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0=/usr/src/debug/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0 -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk= -fvisibility-inlines-hidden -O2 -DLINUX=1 -Wall -W -fPIC -I../../../../git/config.tests/unix/glib -I. -I/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk/usr/include/glib-2.0 -I/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk/usr/lib/glib-2.0/include -I../../../../git/mkspecs/linux-oe-g++ -o glib.o ../../../../git/config.tests/unix/glib/glib.cpp
| ../../../../git/config.tests/unix/glib/glib.cpp: In function 'int main(int, char**)':
| ../../../../git/config.tests/unix/glib/glib.cpp:44:9: warning: 'void g_thread_init(gpointer)' is deprecated [-Wdeprecated-declarations]
| g_thread_init(NULL);
| In file included from /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk/usr/include/glib-2.0/glib.h:107:0,
| from ../../../../git/config.tests/unix/glib/glib.cpp:36:
| /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk/usr/include/glib-2.0/glib/deprecated/gthread.h:265:10: note: declared here
| void g_thread_init (gpointer vtable);
| ../../../../git/config.tests/unix/glib/glib.cpp:44:27: warning: 'void g_thread_init(gpointer)' is deprecated [-Wdeprecated-declarations]
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -Wl,-O1 -o glib glib.o -lgthread-2.0 -pthread -lglib-2.0
| Glib enabled.
| checking for PulseAudio...
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -c -pipe -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/work/cortexa7hf-neon-poky-linux-gnueabi/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0=/usr/src/debug/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0 -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk= -fvisibility-inlines-hidden -D_REENTRANT -O2 -DLINUX=1 -Wall -W -fPIC -I../../../../git/config.tests/unix/pulseaudio -I. -I/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk/usr/include/glib-2.0 -I/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk/usr/lib/glib-2.0/include -I../../../../git/mkspecs/linux-oe-g++ -o pulseaudio.o ../../../../git/config.tests/unix/pulseaudio/pulseaudio.cpp
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -Wl,-O1 -o pulseaudio pulseaudio.o -lpulse-mainloop-glib -lpulse -lglib-2.0
| PulseAudio enabled.
| checking for OpenGL ES 2.0...
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -c -pipe -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/work/cortexa7hf-neon-poky-linux-gnueabi/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0=/usr/src/debug/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0 -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk= -fvisibility-inlines-hidden -O2 -DLINUX=1 -Wall -W -fPIC -I../../../../git/config.tests/unix/opengles2 -I. -I../../../../git/mkspecs/linux-oe-g++ -o opengles2.o ../../../../git/config.tests/unix/opengles2/opengles2.cpp
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -Wl,-O1 -o opengles2 opengles2.o -lGLESv2 -lEGL
| OpenGL ES 2.0 enabled.
| checking for OpenGL ES 3.0...
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -c -pipe -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/work/cortexa7hf-neon-poky-linux-gnueabi/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0=/usr/src/debug/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0 -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk= -fvisibility-inlines-hidden -O2 -DLINUX=1 -Wall -W -fPIC -I../../../../git/config.tests/unix/opengles3 -I. -I../../../../git/mkspecs/linux-oe-g++ -o opengles3.o ../../../../git/config.tests/unix/opengles3/opengles3.cpp
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -Wl,-O1 -o opengles3 opengles3.o -lGLESv2 -lEGL
| OpenGL ES 3.0 enabled.
| checking for OpenGL ES 3.1...
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -c -pipe -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/work/cortexa7hf-neon-poky-linux-gnueabi/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0=/usr/src/debug/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0 -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk= -fvisibility-inlines-hidden -O2 -DLINUX=1 -Wall -W -fPIC -I../../../../git/config.tests/unix/opengles31 -I. -I../../../../git/mkspecs/linux-oe-g++ -o opengles31.o ../../../../git/config.tests/unix/opengles31/opengles31.cpp
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -Wl,-O1 -o opengles31 opengles31.o -lGLESv2 -lEGL
| opengles31.o: In function `main':
| /usr/src/debug/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0/git/config.tests/unix/opengles31/opengles31.cpp:39: undefined reference to `glProgramUniform1i'
| Makefile:85: recipe for target 'opengles31' failed
| make: *** [opengles31] Error 1
| OpenGL ES 3.1 disabled.
| checking for libudev...
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -c -pipe -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/work/cortexa7hf-neon-poky-linux-gnueabi/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0=/usr/src/debug/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0 -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk= -fvisibility-inlines-hidden -O2 -DLINUX=1 -Wall -W -fPIC -I../../../../git/config.tests/unix/libudev -I. -I../../../../git/mkspecs/linux-oe-g++ -o libudev.o ../../../../git/config.tests/unix/libudev/libudev.cpp
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -Wl,-O1 -o libudev libudev.o -ludev
| libudev enabled.
| checking for evdev...
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -c -pipe -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/work/cortexa7hf-neon-poky-linux-gnueabi/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0=/usr/src/debug/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0 -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk= -fvisibility-inlines-hidden -O2 -DLINUX=1 -Wall -W -fPIC -I../../../../git/config.tests/unix/evdev -I. -I../../../../git/mkspecs/linux-oe-g++ -o evdev.o ../../../../git/config.tests/unix/evdev/evdev.cpp
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -Wl,-O1 -o evdev evdev.o
| evdev enabled.
| checking for tslib...
| arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk -c -pipe -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/work/cortexa7hf-neon-poky-linux-gnueabi/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0=/usr/src/debug/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0 -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/x86_64-linux= -fdebug-prefix-map=/home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/sysroots/imx6ull14x14evk= -fvisibility-inlines-hidden -O2 -DLINUX=1 -Wall -W -fPIC -I../../../../git/config.tests/unix/tslib -I. -I../../../../git/mkspecs/linux-oe-g++ -o tslib.o ../../../../git/config.tests/unix/tslib/tslib.cpp
| ../../../../git/config.tests/unix/tslib/tslib.cpp:34:19: fatal error: tslib.h: No such file or directory
| compilation terminated.
| Makefile:177: recipe for target 'tslib.o' failed
| make: *** [tslib.o] Error 1
| tslib disabled.
| The tslib functionality test failed!
| WARNING: exit code 1 from a shell command.
| ERROR: Function failed: do_configure (log file is located at /home/user/fsl-release-bsp/fsl-release-bsp/build/tmp/work/cortexa7hf-neon-poky-linux-gnueabi/qtbase/5.6.1+gitAUTOINC+7bf002c3b3-r0/temp/log.do_configure.71228)
ERROR: Task 992 (/home/user/fsl-release-bsp/fsl-release-bsp/sources/meta-qt5/recipes-qt/qt5/qtbase_git.bb, do_configure) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2340 tasks of which 0 didn't need to be rerun and 1 failed.
Waiting for 0 running tasks to finish:
Summary: 1 task failed:
Summary: There was 1 WARNING message shown.
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
user@ubuntu:~/fsl-release-bsp/fsl-release-bsp/build$
这个已经在前面有帖子说到了,你删除tslib就可以编译过了
yocto编译根文件系统出错,用的文档里的文件
https://www.openedv.com/forum.php?mod=viewthread&tid=302412&fromuid=195955
(出处: OpenEdv-开源电子网)
