查看: 7260|回复: 2
内核启动后,网络驱动初始化以及激活的流程
42
115
238
238
2019-8-20
90 小时
发表于 2020-4-3 11:30:53 | 显示全部楼层 |阅读模式
10金钱
最近在研究内核打印信息,如下图:
[    1.240324] libphy: Fixed MDIO Bus: probed
[    1.313128] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[    1.320858] davinci_mdio 4a101000.mdio: detected phy mask fffffffc
[    1.329727] libphy: 4a101000.mdio: probed
[    1.333934] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver Micrel KSZ8001 or KS8721
[    1.343595] davinci_mdio 4a101000.mdio: phy[1]: device 4a101000.mdio:01, driver Micrel KSZ8001 or KS8721
[    1.354505] cpsw 4a100000.ethernet: Detected MACID = f8:36:9b:1e:49:9f
[    1.361224] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
[    1.367816] cpsw 4a100000.ethernet: ALE Table size 1024
比较靠前的位置。。。
随后我看到在NFS挂载前面,又有如下信息:
[    7.972477] net eth0: initializing cpsw version 1.12 (0)
[    8.073530] Micrel KSZ8001 or KS8721 4a101000.mdio:00: attached PHY driver [Micrel KSZ8001 or KS8721] (mii_bus:phy_addr=4a101000.mdio:00, irq=POLL)
[    8.087054] net eth0: could not add device link to 4a101000.mdio:01 err -17
[    8.193620] Micrel KSZ8001 or KS8721 4a101000.mdio:01: attached PHY driver [Micrel KSZ8001 or KS8721] (mii_bus:phy_addr=4a101000.mdio:01, irq=POLL)
[    8.211068] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   10.164019] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[   10.193146] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
发现之前的cpsw又来了一遍。。
想请教下内核网络这块工作流程。。
谢谢
88
7369
14980
14980
2013-11-13
1823 小时
发表于 2020-4-5 13:59:14 | 显示全部楼层
前面应该是只是通过MDIO接口查找到了PHY芯片为KSZ8001或KSZ8721,但是网络没有初始化呢。后面是打开eth0网卡,然后真正初始化网卡信息
42
115
238
238
2019-8-20
90 小时
 楼主| 发表于 2020-4-7 09:09:25 | 显示全部楼层
zuozhongkai 发表于 2020-4-5 13:59
前面应该是只是通过MDIO接口查找到了PHY芯片为KSZ8001或KSZ8721,但是网络没有初始化呢。后面是打开eth0网 ...
左神,那么等于我这个网络初始化不对么,
因为我抓取NFS包,没发现有任何PORTMAP报文以及后续的NFS。
目前查到的错误是:net eth0: could not add device link to 4a101000.mdio:01 err -17
GMT+8, 2026-10-31 05:59
