查看: 7360|回复: 1
阿尔法开发板开发环境搭建中的交叉编译工具安装成功后安装其他库出现失败情况提示文件依赖信息,怎么解决?
80
188
698
698
2013-8-16
41 小时
发表于 2020-4-10 10:13:09 | 显示全部楼层 |阅读模式
论坛里的各位大神,我刚买正点原子大神的阿尔法开发板,准备入手linux,在按照开发指南上的步骤安装完成交叉编译工具后安装其他库的时候出现了失败情况,提示
C:\Users\ADMINI~1\AppData\Local\Temp\企业微信截图_15864844608073.pngReading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
lib32stdc++6 : Depends: lib32gcc1 (>= 1:4.2) but it is not going to be installed
                Depends: libc6-i386 (>= 2.18) but it is not going to be installed
lsb-core : Depends: mailx or
                     mailutils but it is not going to be installed
            Depends: alien (>= 8.36) but it is not going to be installed
            Depends: libc6:i386 or
                     libc6-i386 but it is not going to be installed
            Depends: zlib1g:i386 or
                     lib32z1 but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
大致意思就是缺少依赖文件,我根据网上的一些资料将apt下载源更新为阿里源了,还是没有解决,请问有哪位大神有遇到并解决了这个问题,还请指点一下,谢谢。
88
7369
14980
14980
2013-11-13
1823 小时
发表于 2020-4-10 10:20:47 | 显示全部楼层
帮顶,看看有没有其他朋友遇到过
GMT+8, 2026-10-31 05:59
