查看: 7250|回复: 3
开发指南第三十八章-38.3根文件系统初步测试,出现问题。
2019-7-24
发表于 2020-4-10 18:16:28 | 显示全部楼层 |阅读模式
搭建完根目录系统后,通过nfs挂载出现以下错误[    5.906998] VFS: Mounted root (nfs filesystem) on device 0:14.
[    5.914162] devtmpfs: error mounting -2
[    5.918624] Freeing unused kernel memory: 440K (80b42000 - 80bb0000)
[   24.003226] nfs: server 192.168.2.103 not responding, still trying
[   24.012217] nfs: server 192.168.2.103 OK
mount: mounting proc on /proc failed: No such file or directory
mount: mounting tmpfs on /tmp failed: No such file or directory
mount: mounting sysfs on /sys failed: No such file or directory
mkdir: can't create directory '/dev/pts': No such file or directory
mount: mounting devpts on /dev/pts failed: No such file or directory
/etc/init.d/rcS: line 10: can't create /proc/sys/kernel/hotplug: nonexistent directory
mdev: can't change directory to '/dev': No such file or directory
can't open /dev/tty4: No such file or directory
can't open /dev/tty3: No such file or directory
can't open /dev/tty2: No such file or directory
23
23
2020-3-28
发表于 2020-4-10 18:58:50 | 显示全部楼层
看一下你的Lib库,我之前是应为usr/lib中的内容出问题导致的
888
2397
2397
2019-9-25
398 小时
发表于 2020-4-17 22:23:36 | 显示全部楼层
试试:
cd /etc/init.d
chmod 777 rcS
不行的话就试试:
ln -sf /dev/null /dev/tty2
ln -sf /dev/null /dev/tty3
ln -sf /dev/null /dev/tty4
2019-5-12
发表于 2020-4-18 17:37:23 | 显示全部楼层
楼主解决了吗?我原来在Ubuntu16.04可以,后来在ubuntu18.04也成这样了
GMT+8, 2026-10-31 05:17
