查看: 8907|回复: 14
800*480电容触摸屏问题求助!!!
56
178
178
2020-3-11
17 小时
发表于 2020-4-12 23:29:47 | 显示全部楼层 |阅读模式
2金钱
问题描述:
1、设备树已经按照教程更改如下
        ft5426: edt-ft5x06@38 {
                compatible = "atk,ft5x06";
                reg = <0x38>;
                pinctrl-names = "default";
                pinctrl-0 = <&pinctrl_tsc>;
                interrupt-parent = <&gpio1>;
                interrupt-gpios = <&gpio1 9 GPIO_ACTIVE_LOW>;
                interrupts = <9 0>;
                reset-gpios = <&gpio5 9 GPIO_ACTIVE_LOW>;
pinctrl_tsc: tscgrp {
                        fsl,pins = <
                                MX6UL_PAD_GPIO1_IO09__GPIO1_IO09        0xf080
                                MX6UL_PAD_SNVS_TAMPER9__GPIO5_IO09         0x10b0
pinctrl_i2c2: i2c2grp {
                        fsl,pins = <
                                MX6UL_PAD_UART5_TX_DATA__I2C2_SCL 0x4001b8b0
                                MX6UL_PAD_UART5_RX_DATA__I2C2_SDA 0x4001b8b0
&tsc {
        xnur-gpio = <&gpio1 3 GPIO_ACTIVE_LOW>;
        measure-delay-time = <0xffff>;
        pre-charge-time = <0xfff>;
        status = "disable";
};  //原来tsc 上的status 是okay, 但是加载驱动的时候会报错,错误为:
/23_mulitiouch # insmod ft5x06.ko
[   94.504859] imx6ul-pinctrl 20e0000.iomuxc: pin MX6UL_PAD_GPIO1_IO09 already requested by 2040000.tsc; cannot claim for 1-0038
[   94.521168] imx6ul-pinctrl 20e0000.iomuxc: pin-32 (1-0038) status -22
[   94.530066] imx6ul-pinctrl 20e0000.iomuxc: could not request pin 32 (MX6UL_PAD_GPIO1_IO09) from group tscgrp  on device 20e0000.iomuxc
[   94.547052] edt_ft5x06 1-0038: Error applying setting, reverse things back
[   94.881608] input: ft5x06 as /devices/platform/soc/2100000.aips-bus/21a4000.i2c/i2c-1/1-0038/input/input3
将status 的值改为 disable后 已经可以正常加载
insmod ft5x06.ko
[   26.361738] input: ft5x06 as /devices/platform/soc/2100000.aips-bus/21a4000.i2c/i2c-1/1-0038/input/input2
加载驱动之前 input中的设备:
/23_multitouch # ls /dev/input/
event0  mice
加载驱动后input中的设备
/23_multitouch # insmod ft5x06.ko
[ 4959.621623] input: ft5x06 as /devices/platform/soc/2100000.aips-bus/21a4000.i2c/i2c-1/1-0038/input/input3
event0  event1  mice    mouse0
现在使用 hexdump /dev/input/event1  然后触摸屏幕的任何地方,都没有input信息上报,请问各位大侠这是为什么呢?
贴出代码:
#include <linux/ide.h>
#include <linux/types.h>
#include <linux/kernel.h>
#include <linux/delay.h>
#include <linux/module.h>
#include <linux/i2c.h>
#include <linux/of.h>
#include <linux/input.h>
#include <linux/platform_device.h>
#include <linux/gpio.h>
#include <linux/of_address.h>
#include <linux/of_device.h>
#include <linux/of_gpio.h>
#include <linux/errno.h>
#include <linux/device.h>
#include <asm/mach/map.h>
#include <asm/uaccess.h>
#include <asm/io.h>
#include <linux/ratelimit.h>
#include <linux/interrupt.h>
#include <linux/input/mt.h>
#include <linux/input/touchscreen.h>
#define MAX_SUPPORT_POINTS                5
#define TOUCH_EVENT_DOWN                0x00
#define TOUCH_EVENT_UP                        0x01
#define TOUCH_EVENT_ON                        0x02
#define TOUCH_EVENT_RESERVED    0x03
#define FT5X06_TD_STATUS_REG    0x02
#define FT5x06_DEVICE_MODE_REG  0X00
#define FT5426_IDG_MODE_REG     0XA4
#define FT5X06_READLEN          29
struct ft5x06{
    struct i2c_client *client;
    struct input_dev *input;
    struct device_node *nd;
    int irq_pin;
    int reset_pin;
    int irqnum;
    void *private_data;
struct ft5x06 ft5x06_dev;
static int ft5x06_ts_reset(struct i2c_client *client, struct ft5x06 *dev)
    int error = 0;
    if(gpio_is_valid(dev->reset_pin)){
        error = devm_gpio_request_one(&client->dev,dev->reset_pin,GPIOF_OUT_INIT_LOW,"edt-ft5x06 wake");
        if(error){
                        return error;
        msleep(5);
        gpio_set_value(dev->reset_pin, 1);
                msleep(300);
    return 0;
static int ft5x06_read_regs(struct ft5x06 *dev, u8 reg, u8 *buf, u8 len)
        struct i2c_client *client = (struct i2c_client *)dev->client;
        struct i2c_msg msg[2];
        int ret;
        msg[0].addr = client->addr;
        msg[0].flags = 0;
        msg[0].buf = &reg;
        msg[0].len = 1;
        msg[1].addr = client->addr;
        msg[1].flags =  client->flags | I2C_M_RD;
        msg[1].buf = buf;
        msg[1].len = len;
        if ((ret =i2c_transfer(client->adapter, msg, 2)) != 2) {
                dev_err(&client->dev, "i2c transfer failed\n");
                return -EIO;
        return ret;
static s32 ft5x06_write_regs(struct ft5x06 *dev, u8 reg, u8 *buf, u8 len)
        struct i2c_msg msg;
        u8 b[256];
        int ret;
        b[0] = reg;
        memcpy(&b[1] ,buf ,len);
        msg.addr = client->addr;
        msg.flags = 0;
        msg.buf = b;
        msg.len = len+1;
        ret = i2c_transfer(client->adapter, &msg,1);
        return ret;
static void ft5x06_write_reg(struct ft5x06 *dev, u8 reg, u8 data )
        u8 buf;
        buf = data;
        ft5x06_write_regs(dev, reg, &buf, 1);
static irqreturn_t ft5x06_handler(int irq, void *dev_id)
        struct ft5x06 *mutitouch = dev_id;
        //struct device *dev = &mutitouch->client->dev;
        u8 rdbuf[29];
        int i, type, x, y, id;
        int offset = 1, tplen = 6;
        int error = 0;
    memset(rdbuf, 0, sizeof(rdbuf));
        error = ft5x06_read_regs(&ft5x06_dev, FT5X06_TD_STATUS_REG, rdbuf, FT5X06_READLEN );
        if(error){
                goto out;
        for(i = 0 ;i< MAX_SUPPORT_POINTS ; i++){
                u8 *buf = &rdbuf[i * tplen + offset];
                bool down;
                type = buf[0] >> 6;
                if (type == TOUCH_EVENT_RESERVED)
                        continue;
                y = ((buf[0] << 8) | buf[1]) & 0x0fff;
                x = ((buf[2] << 8) | buf[3]) & 0x0fff;
                id = (buf[2] >> 4) & 0x0f;
                down = type != TOUCH_EVENT_UP;
                input_mt_slot(mutitouch->input, id);
                input_mt_report_slot_state(mutitouch->input, MT_TOOL_FINGER, down);
                if (!down)
                        continue;
                input_report_abs(mutitouch->input, ABS_MT_POSITION_X, x);
                input_report_abs(mutitouch->input, ABS_MT_POSITION_Y, y);
        input_mt_report_pointer_emulation(mutitouch->input, true);
        input_sync(mutitouch->input);
        out:
        return IRQ_HANDLED;
static int ft5x06_ts_irq(struct i2c_client *client, struct ft5x06 *dev)
        int error = 0;
        if (gpio_is_valid(dev->irq_pin)) {
                error = devm_gpio_request_one(&client->dev, dev->irq_pin,
                                        GPIOF_IN, "edt-ft5x06 irq");
                if (error) {
                                "Failed to request GPIO %d, error %d\n",
                                dev->irq_pin, error);
                        return error;
        error = devm_request_threaded_irq(&client->dev, client->irq, NULL,
                                        ft5x06_handler,
                                        IRQF_TRIGGER_FALLING | IRQF_ONESHOT,
                                        client->name, dev);
        if (error) {
                dev_err(&client->dev, "Unable to request touchscreen IRQ.\n");
                return error;
        return 0;
static int ft5x06_probe(struct i2c_client *client, const struct i2c_device_id *id)
        int error = 0 ;
        ft5x06_dev.client = client;
        ft5x06_dev.irq_pin = of_get_named_gpio(client->dev.of_node,"interrupt-gpios",0);
        ft5x06_dev.reset_pin = of_get_named_gpio(client->dev.of_node,"reset-gpios",0);
        error = ft5x06_ts_reset(client, &ft5x06_dev);
        if (error)
                return error;
        error = ft5x06_ts_irq(client, &ft5x06_dev);
        if (error)
                return error;
        ft5x06_write_reg(&ft5x06_dev,FT5x06_DEVICE_MODE_REG,0);
        ft5x06_write_reg(&ft5x06_dev,FT5426_IDG_MODE_REG,1);
        ft5x06_dev.input = devm_input_allocate_device(&client->dev);
        if (!ft5x06_dev.input) {
                dev_err(&client->dev, "failed to allocate input device.\n");
                return -ENOMEM;
        ft5x06_dev.input->name = client->name;
        ft5x06_dev.input->id.bustype = BUS_I2C;
        ft5x06_dev.input->dev.parent = &client->dev;
        __set_bit(EV_KEY, ft5x06_dev.input->evbit);
        __set_bit(EV_ABS,ft5x06_dev.input->evbit);
        __set_bit(BTN_TOUCH, ft5x06_dev.input->keybit);
        input_set_abs_params(ft5x06_dev.input, ABS_X, 0, 800 , 0, 0);
        input_set_abs_params(ft5x06_dev.input, ABS_Y, 0, 480, 0, 0);
        input_set_abs_params(ft5x06_dev.input, ABS_MT_POSITION_X,0, 800, 0, 0);
        input_set_abs_params(ft5x06_dev.input, ABS_MT_POSITION_Y, 0, 480, 0, 0);
   error = input_mt_init_slots(ft5x06_dev.input, MAX_SUPPORT_POINTS, 0);
        if (error) {
                dev_err(&client->dev, "Unable to init MT slots.\n");
                return error;
  error = input_register_device(ft5x06_dev.input);
        if (error)
                goto err_remove_attrs;
        err_remove_attrs:
        return error;
static int ft5x06_remove(struct i2c_client *client)
        input_unregister_device(ft5x06_dev.input);
        return 0;
static const struct i2c_device_id ft5x06_tsid_table[] = {
        {"edt-ft5206",0},
        {"edt-ft5426",0},
        {/*sential*/}
static const struct of_device_id        ft5x06_of_match_table[] = {
        {.compatible = "atk,ft5x06"},
        {.compatible = "edt,edt-ft5426"},
    {/****sential****/}
static struct i2c_driver ft5x06_driver = {
        .probe = ft5x06_probe,
        .remove = ft5x06_remove,
        .driver = {
                .of_match_table = of_match_ptr(ft5x06_of_match_table),
                .owner = THIS_MODULE,
                .name = "edt_ft5x06",
        .id_table = ft5x06_tsid_table,
static int __init ft5x06_init(void)
        int ret = 0 ;
        ret = i2c_add_driver(&ft5x06_driver);
        printk("touch enterance\r\n");
        return ret;
static void __exit ft5x06_exit(void)
        i2c_del_driver(&ft5x06_driver);
        printk("touch exit\r\n");
module_init(ft5x06_init);
module_exit(ft5x06_exit);
MODULE_AUTHOR("123");
MODULE_LICENSE("GPL");
56
178
178
2020-3-11
17 小时
 楼主| 发表于 2020-4-12 23:29:48 | 显示全部楼层
1491430114 发表于 2020-5-15 09:48
原子教程还没出的时候我跟着这个改的,一直使用正常
https://blog.csdn.net/qq_26943851/article/details/ ...
学习了 谢谢啦
779
5342
5342
2019-9-25
445 小时
发表于 2020-4-13 11:44:50 | 显示全部楼层
你的是input3吧,不是input1
想思考的时候,有时还可以用屁股,QQ 1252699831
88
7369
14980
14980
2013-11-13
1823 小时
发表于 2020-4-13 16:47:43 | 显示全部楼层
开往春天的手扶拖拉机
56
178
178
2020-3-11
17 小时
 楼主| 发表于 2020-4-13 21:15:12 | 显示全部楼层
茂茂2019 发表于 2020-4-13 11:44
你的是input3吧,不是input1
可是dev下面就只有一个 input/ 在这个目录下,没有input3 ,而且dev目录下 也没有input3这个节点
56
178
178
2020-3-11
17 小时
 楼主| 发表于 2020-4-13 21:17:17 | 显示全部楼层
zuozhongkai 发表于 2020-4-13 16:47
event1,event2,event3这三个都看一下,
左神来了!, 左神,我的input下 没有event2 event3, 加载驱动之后会出来一个 event1,
mice    mouse0, 这几个试了 都不行,而且我也没有插鼠标啥的
23
23
2020-4-16
发表于 2020-5-3 09:17:25 | 显示全部楼层
感觉这个设备树是有问题的,我用源码编译出来的就不行。用他那个就是ok的。感觉对不上。
23
23
2020-4-16
发表于 2020-5-3 09:18:08 | 显示全部楼层
设备树打印出来的设备号都是EP0820M09。
57
369
369
2018-1-11
74 小时
发表于 2020-5-5 20:08:15 | 显示全部楼层
博主,请看linux 驱动教程1.4。我的用的是nxp官方编译的dtbs,我的 status 是okay, 加载驱动的时候没有报错。
57
369
369
2018-1-11
74 小时
发表于 2020-5-5 20:09:33 | 显示全部楼层
我的指令是 :hexdump /dev/input/event1
56
178
178
2020-3-11
17 小时
 楼主| 发表于 2020-5-15 09:20:14 | 显示全部楼层
好的  我试试
38
249
796
796
2016-9-10
317 小时
发表于 2020-5-15 09:48:10 | 显示全部楼层
https://blog.csdn.net/qq_26943851/article/details/104417858
235
1314
1314
2017-3-1
260 小时
发表于 2020-9-1 09:31:35 | 显示全部楼层
楼主,你是怎么解决的?看了CSDN给的参考,编译进内核,和现在的思路不太一样呀,当前的问题是什么导致?
我的是4.3’屏幕800*480参考原子最新写的驱动文件,加载成功了,但是和你一样hexdump event事件没反应。。。。
2020-10-10
发表于 2020-10-27 21:10:59 | 显示全部楼层
我的问题跟你一样,使用例程源码gt9147驱动,加载驱动后读取的设备ID为0也不知道那块出现问题?????
GMT+8, 2026-10-31 06:02
