查看: 7271|回复: 1
请问sim900a可以打电话但是发短信手机却收不到怎么回事
2020-4-17
发表于 2020-4-17 16:23:14 | 显示全部楼层 |阅读模式
#include <REG51.H>
#include <string.H>
#include <intrins.h>
#define uchar unsigned char
#define uint unsigned int
#define FOSC_110592M
//#define FOSC_12M
sbit P10=P1^0;
sbit P11=P1^1;
sbit P12=P1^2;
sbit P13=P2^3;
sbit P14=P2^4;
sbit P15=P1^5;
unsigned int  rec_data_len_uart=0;
unsigned char idata Buffer_Uart0_Rec[25]={0};
void SerialInti()
        TMOD=0x20;
#ifdef FOSC_12M
        TH1=0xf3;
        TL1=0xf3;
#else
        TH1=0xfd;
        TL1=0xfd;
#endif //end of SOC_12M
        TR1=1;
        SM0=0;
        SM1=1;
        REN=1;
        EA=1;
        ES=1;
void Serial_interrupt() interrupt 4
        unsigned char temp_rec_data_uart0;
        temp_rec_data_uart0 = SBUF;
        RI=0;
        Buffer_Uart0_Rec[rec_data_len_uart]=temp_rec_data_uart0;
        rec_data_len_uart++;
        if(rec_data_len_uart>24)
void Uart1Send(uchar c)
        SBUF=c;
        while(!TI);
        TI=0;
void Uart1Sends(uchar *str)
        while(*str!='\0')
                SBUF=*str;
                while(!TI);
                TI=0;
                str++;
void DelaySec(int sec)
        uint i , j= 0;
        for(i=0; i<sec; i++)
                for(j=0; j<65535; j++)
void main()
        uchar i = 0;
        SerialInti();
    DelaySec(10);
    P14=0;
          Uart1Sends("AT+CMGF=0\r\n");
        DelaySec(1);
        Uart1Sends("AT+CSCS=\"USC2\"\r\n");
        DelaySec(1);
        Uart1Sends("AT+CSCA?\r\n");
        DelaySec(1);
        Uart1Sends("+CSCA:\"002B0038003600310033003800300030003700350034003500300030\",145\r\n");
        DelaySec(1);
        Uart1Sends("AT+CMGS=23\r\n");
    DelaySec(1);
        Uart1Sends("0011000D91688121150710F700080108521B601D901A4FE1");
    DelaySec(1);
        Uart1Sends("+CMGS: 10\r\n");
        DelaySec(1);
    Uart1Send(0X1A);
    DelaySec(15);
        P13=0;
    while(1);
这是我的程序,试过打电话可以,那就应该是程序的问题,请问是我哪里写的不规范吗,求教
2020-4-17
 楼主| 发表于 2020-4-17 18:07:39 | 显示全部楼层
用串口可以发送短信,说明就是程序的问题
GMT+8, 2026-11-14 09:15
