查看: 5099|回复: 3
新人初学EMWIN,困难重重,请问各位大佬,如何在窗口标题栏显示时间电量或者其他信息。
103
103
2019-9-16
37 小时
发表于 2020-4-22 20:45:14 | 显示全部楼层 |阅读模式
新人初学EMWIN,困难重重,请问各位大佬,如何在窗口标题栏显示时间电量或者其他信息。我的做法是利用EMwin的定时器,定时更新窗口的标题栏,发现不行,求大佬指点。
*       Display_Time_BatteryData
int temp = 1;
static void Display_Time_BatteryData(WM_MESSAGE* pMsg)
    char Temp_Now[5] = { 0 };
    WM_HWIN hItem;
//time display
   hItem = WM_GetClientWindow;//(pMsg->hWin, ID_FRAMEWIN_0);
   FRAMEWIN_SetText(hItem, "text");
*       _cbDialog
static void _cbDialog(WM_MESSAGE * pMsg)
      WM_HWIN hItem;
      int     NCode;
      int     Id;
      switch (pMsg->MsgId)
          case WM_INIT_DIALOG://初始化消息ID,当窗口第一次创建时,此处的代码被运行一次,后面不会再运行。
                // Initialization of 'Demo'  初始化窗口
                hItem = pMsg->hWin;
                FRAMEWIN_SetTitleHeight(hItem, 16);
                FRAMEWIN_SetTextAlign(hItem, GUI_TA_LEFT | GUI_TA_VCENTER);
                FRAMEWIN_SetTextColor(hItem, GUI_MAKE_COLOR(0x004080FF));
                FRAMEWIN_SetText(hItem, "BMU DEMO                   Time:2020/4/20  00:00:00");
                FRAMEWIN_SetFont(hItem, GUI_FONT_16B_1);
                FRAMEWIN_SetBarColor(hItem,1 , GUI_MAKE_COLOR(0xFF0000));
                FRAMEWIN_SetSkinClassic(hItem);
                FRAMEWIN_SetClientColor(hItem, GUI_GRAY_AA);
                // Initialization of 'Battery2:'
                hItem = WM_GetDialogItem(pMsg->hWin, ID_TEXT_0);
                TEXT_SetFont(hItem, GUI_FONT_16B_1);
                // Initialization of 'Battery3:'
                hItem = WM_GetDialogItem(pMsg->hWin, ID_TEXT_1);
                // Initialization of 'Battery4:'
                hItem = WM_GetDialogItem(pMsg->hWin, ID_TEXT_2);
                // Initialization of 'Battery5:'
                hItem = WM_GetDialogItem(pMsg->hWin, ID_TEXT_3);
                // Initialization of 'Battery6:'
                hItem = WM_GetDialogItem(pMsg->hWin, ID_TEXT_4);
                // Initialization of 'Battery8:'
                hItem = WM_GetDialogItem(pMsg->hWin, ID_TEXT_5);
                // Initialization of 'Battery7:'
                hItem = WM_GetDialogItem(pMsg->hWin, ID_TEXT_6);
                // Initialization of 'SOC'
                hItem = WM_GetDialogItem(pMsg->hWin, ID_TEXT_7);
                TEXT_SetText(hItem, "SOC:");
                // Initialization of 'Battery1:'
                hItem = WM_GetDialogItem(pMsg->hWin, ID_TEXT_8);
                // Initialization of 'Listview'
                hItem = WM_GetDialogItem(pMsg->hWin, ID_LISTVIEW_0);
                LISTVIEW_AddColumn(hItem, 120, "TIME", GUI_TA_HCENTER | GUI_TA_VCENTER);
                LISTVIEW_AddColumn(hItem, 160, "Fault Type", GUI_TA_HCENTER | GUI_TA_VCENTER);
                LISTVIEW_AddRow(hItem, NULL);
                LISTVIEW_SetGridVis(hItem, 1);
                // Initialization of 'Alarm Record'
                hItem = WM_GetDialogItem(pMsg->hWin, ID_TEXT_9);
                TEXT_SetText(hItem, "Alarm Record:");
                // Initialization of 'Edit'
                hItem = WM_GetDialogItem(pMsg->hWin, ID_EDIT_0);
                EDIT_SetText(hItem, "0.000V");
                EDIT_SetTextAlign(hItem, GUI_TA_HCENTER | GUI_TA_VCENTER);
                hItem = WM_GetDialogItem(pMsg->hWin, ID_EDIT_1);
                hItem = WM_GetDialogItem(pMsg->hWin, ID_EDIT_2);
                hItem = WM_GetDialogItem(pMsg->hWin, ID_EDIT_3);
                hItem = WM_GetDialogItem(pMsg->hWin, ID_EDIT_4);
                hItem = WM_GetDialogItem(pMsg->hWin, ID_EDIT_5);
                hItem = WM_GetDialogItem(pMsg->hWin, ID_EDIT_6);
                hItem = WM_GetDialogItem(pMsg->hWin, ID_EDIT_7);
                // USER START (Optionally insert additional code for further widget initialization)
                // USER END
                break;
          case WM_NOTIFY_PARENT:  //告知父窗口,其子窗口中发生了某些改变。有动作活动的消息ID,当有窗口活动时,此处代码被运行一次,后面不会运行。
                Id= WM_GetId(pMsg->hWinSrc);
                NCode = pMsg->Data.v;
                switch(Id)
                    case ID_LISTVIEW_0: // Notifications sent by 'Listview'
                          switch(NCode)
                              case WM_NOTIFICATION_CLICKED:
                                break;
                              case WM_NOTIFICATION_RELEASED:
                                break;
                              case WM_NOTIFICATION_SEL_CHANGED:
                                break;
                          break;
                    case ID_EDIT_0: // Notifications sent by 'Edit'
                          switch(NCode)
                                break;
                                break;
                              case WM_NOTIFICATION_VALUE_CHANGED:
                                break;
                         break;
                    case ID_EDIT_1: // Notifications sent by 'Edit'
                          switch(NCode)
                                break;
                                break;
                                break;
                          break;
                    case ID_EDIT_2: // Notifications sent by 'Edit'
                          switch(NCode)
                                break;
                                break;
                                break;
                          break;
                    case ID_EDIT_3: // Notifications sent by 'Edit'
                          switch(NCode)
                                break;
                                break;
                                break;
                          break;
                    case ID_EDIT_4: // Notifications sent by 'Edit'
                          switch(NCode)
                                break;
                                break;
                                break;
                          break;
                    case ID_EDIT_5: // Notifications sent by 'Edit'
                          switch(NCode)
                                break;
                                break;
                                break;
                          break;
                    case ID_EDIT_6: // Notifications sent by 'Edit'
                          switch(NCode)
                                break;
                                break;
                                break;
                          break;
                    case ID_EDIT_7: // Notifications sent by 'Edit'
                          switch(NCode)
                                break;
                                break;
                                break;
                          break;
                break;
          case WM_TIMER:
              Display_Time_BatteryData(pMsg);
              WM_RestartTimer(pMsg->Data.v, 1000);
            break;
        default:
                WM_DefaultProc(pMsg);
                break;
你这个只是更新窗口标题,如果你想在窗口的指定位置显示指定内容,比如图片这些,需要重写控件动作。
39
597
1652
1652
2017-7-17
325 小时
发表于 2020-4-22 20:45:15 | 显示全部楼层
103
103
2019-9-16
37 小时
 楼主| 发表于 2020-4-25 11:17:12 | 显示全部楼层
顶一下
277
949
949
2018-4-21
264 小时
发表于 2020-4-30 15:59:16 来自手机 | 显示全部楼层
GMT+8, 2026-11-12 03:40
