查看: 5513|回复: 1
如何查看内核的补丁是否满足要求,可以怎么查看补丁列表
57
2018-11-15
40 小时
发表于 2020-4-28 11:50:08 | 显示全部楼层 |阅读模式
20金钱
就是在做看文档时候有说查看补丁列表,我需要如何查看补丁是否为最新的,百度搜了都没说怎么查看补丁,
  1. 5e962a0 usb: gadget: f_uac2: fix some issues for Windows recognized
  2. 14e0a40 UPSTREAM: usb: gadget: f_uac2: disable IN/OUT ep if unused
  3. a90af74 UPSTREAM: usb: gadget: u_audio: protect stream runtime fields with stream spinlock
  4. 7335245 UPSTREAM: usb: gadget: u_audio: remove cached period bytes value
  5. deb045e UPSTREAM: usb: gadget: u_audio: remove caching of stream buffer parameters
  6. 6ec0a4d UPSTREAM: usb: gadget: u_audio: update hw_ptr in iso_complete after data copiedf81ce6a UPSTREAM: usb: gadget: u_audio: fix pcm/card naming in g_audio_setup()
  7. bbd7715 UPSTREAM: usb: gadget: f_uac2: fix error handling in afunc_bind (again)
  8. 1adbd21 UPSTREAM: usb: gadget: make snd_pcm_hardware const
  9. de6e281 UPSTREAM: usb: gadget: f_uac2: constify snd_pcm_ops structures
  10. 0106bd0 UPSTREAM: usb: gadget: f_uac2: endianness fixes.
  11. 98492ac UPSTREAM: usb: gadget: f_uac1: endianness fixes.
  12. 45e29d4 UPSTREAM: usb: gadget: add f_uac1 variant based on a new u_audio api
  13. 55f51fc UPSTREAM: usb: gadget: function: make current f_uac1 implementation legacy
  14. ef10d9e UPSTREAM: usb: gadget: f_uac2: split out audio core
  15. dc16803 UPSTREAM: usb: gadget: f_uac2: remove platform driver/device creation
  16. 7d1ddce UPSTREAM: usb: gadget: f_uac2: calculate wMaxPacketSize before endpoint match
  17. 4f76843 UPSTREAM: usb: gadget: uac2: add req_number as parameter
  18. 2b9c1a8 UPSTREAM: usb: gadget: f_uac2: improve error handling
  19. 70f4537 UPSTREAM: usb: gadget: uac2: Drop unused device qualifier descriptor
给出的补丁列表是这样子的,这个我要怎么查看我的源码有没有啊
发表于 2020-4-28 11:50:09 | 显示全部楼层
GMT+8, 2026-11-7 02:00
