查看: 5746|回复: 6
STM32F429 USB CustomHID 0x82端点发送不出数据
200
200
2019-12-5
48 小时
发表于 2020-5-7 23:41:29 | 显示全部楼层 |阅读模式
6金钱
使用原子哥的MSC工程里USB驱动文件,修改usbd_customhid_core.c中的配置描述符,枚举成custom HID设备,用#define HID_IN_EP                    0x82#define HID_OUT_EP                 0x02
枚举成功,可以正常接收PC发送的数据,但是调用函数
USBD_CUSTOM_HID_SendReport()
发送数据到PC使用BUS BOUND监听确接收不到STM32发送的数据。
改成
#define HID_IN_EP                    0x81#define HID_OUT_EP                 0x01
就能正常收发了
是哪个描述符没有配置对,还是别的什么原因呢?请大家指教
下面是我的配置描述符和报告描述符
__ALIGN_BEGIN static uint8_t USBD_CUSTOM_HID_CfgDesc[USB_CUSTOM_HID_CONFIG_DESC_SIZ] __ALIGN_END =
0x09, /* bLength: Configuration Descriptor size */
  USB_CONFIGURATION_DESCRIPTOR_TYPE, /* bDescriptorType: Configuration */
  USB_CUSTOM_HID_CONFIG_DESC_SIZ,
  /* wTotalLength: Bytes returned */
  0x00,
  0x01,         /*bNumInterfaces: 1 interface*/
  0x01,         /*bConfigurationValue: Configuration value*/
  0x00,         /*iConfiguration: Index of string descriptor describing
  the configuration*/
  0xC0,         /*bmAttributes: bus powered and Support Remote Wake-up */
  0x32,         /*MaxPower 100 mA: this current is used for detecting Vbus*/
  /************** Descriptor of Custom HID interface ****************/
  /* 09 */
  0x09,         /*bLength: Interface Descriptor size*/
  USB_INTERFACE_DESCRIPTOR_TYPE,/*bDescriptorType: Interface descriptor type*/
  0x00,         /*bInterfaceNumber: Number of Interface*/
  0x00,         /*bAlternateSetting: Alternate setting*/
  0x02,         /*bNumEndpoints*/
  0x03,         /*bInterfaceClass: HID*/
  0x00,         /*bInterfaceSubClass : 1=BOOT, 0=no boot*/
  0x00,         /*nInterfaceProtocol : 0=none, 1=keyboard, 2=mouse*/
  0,            /*iInterface: Index of string descriptor*/
  /******************** Descriptor of Custom HID ********************/
  /* 18 */
  0x09,         /*bLength: HID Descriptor size*/
  CUSTOM_HID_DESCRIPTOR_TYPE, /*bDescriptorType: HID*/
  0x11,         /*bcdHID: HID Class Spec release number*/
  0x01,
  0x00,         /*bCountryCode: Hardware target country*/
  0x01,         /*bNumDescriptors: Number of HID class descriptors to follow*/
  0x22,         /*bDescriptorType*/
  USBD_CUSTOM_HID_REPORT_DESC_SIZE,/*wItemLength: Total length of Report descriptor*/
  0x00,
  /******************** Descriptor of Custom HID endpoints ***********/
  /* 27 */
  0x07,          /* bLength: Endpoint Descriptor size */
  USB_ENDPOINT_DESCRIPTOR_TYPE, /* bDescriptorType: */
  HID_IN_EP,     /* bEndpointAddress: Endpoint Address (IN) */
  0x03,          /* bmAttributes: Interrupt endpoint */
  HID_IN_PACKET, /* wMaxPacketSize:  Bytes max */
  0x00,
  0x20,          /* bInterval: Polling Interval (32 ms) */
  /* 34 */
  /*        Endpoint descriptor type */
  HID_OUT_EP,        /* bEndpointAddress: */
  /*        Endpoint Address (OUT) */
  HID_OUT_PACKET,        /* wMaxPacketSize: 2 Bytes max  */
  0x00,
  0x20,        /* bInterval: Polling Interval (20 ms) */
  /* 41 */
__ALIGN_BEGIN static uint8_t CustomHID_ReportDesc[USBD_CUSTOM_HID_REPORT_DESC_SIZE] __ALIGN_END =
  0x06,0x00,0xff,/* USAGE_PAGE  */
  0x05, 0x8c, /* USAGE_PAGE (ST Page) */
  0x09, 0x01, /* USAGE (Demo Kit) */
  0xa1, 0x01, /* COLLECTION (Application) */
  // The Input report
  0x09,0x03, // USAGE ID - Vendor defined
  0x15,0x00, // LOGICAL_MINIMUM (0)
  0x26,0x00, 0xFF, // LOGICAL_MAXIMUM (255)
  0x75,0x08, // REPORT_SIZE (8bit)
  0x95,0x40, // REPORT_COUNT (64Byte)
  0x81,0x02, // INPUT (Data,Var,Abs)
  // The Output report
  0x09,0x04, // USAGE ID - Vendor defined
  0x26,0x00,0xFF, // LOGICAL_MAXIMUM (255)
  0x91,0x02, // OUTPUT (Data,Var,Abs)
  0xc0                          /*     END_COLLECTION                     */
57
59
59
2018-12-27
发表于 2020-5-7 23:41:31 | 显示全部楼层
帮顶!!!!!!
61
79
79
2020-5-4
发表于 2020-5-8 16:15:59 | 显示全部楼层
不懂,帮顶,勇于提问总是好的!!
165779
165779
发表于 2020-5-10 00:00:32 | 显示全部楼层
200
200
2019-12-5
48 小时
 楼主| 发表于 2020-5-11 20:19:16 | 显示全部楼层
BusBound接收到的数据为3个或者7个无序的数,如下图:
应该是哪里还没有改到,唉,继续一点一点找吧!
165779
165779
发表于 2020-5-12 01:33:53 | 显示全部楼层
继续加油
2021-10-1
发表于 2026-3-28 12:11:58 | 显示全部楼层
FIFO没有设置好。
GMT+8, 2026-10-23 11:35
