查看: 11624|回复: 9
编译minicom出错,不知道什么原因?
42
185
185
2019-5-24
39 小时
发表于 2020-5-24 16:24:11 | 显示全部楼层 |阅读模式
minicom配置正常:
./configure CC=arm-linux-gnueabihf-gcc --prefix=/home/shigang/linux-alient/tool/minicom --host=arm-linux-gnueabihf CPPFLAGS=-I/home/shigang/linux-alient/tool/ncurses/include LDFLAGS=-L/home/shigang/linux-alient/tool/ncurses/lib -enable-cfgdir=/etc/minicom
---正常,只是最后有个警告
config.status: creating po/POTFILES
config.status: creating po/Makefile
configure: WARNING: unrecognized options: --enable-cfgdir
make-编译时出错:(已经在/etc下建立了minicom目录)
window.c:2009:6: warning: assignment makes pointer from integer without a cast
   TS = tgetstr("ts", &_tptr);
window.c:2010:6: warning: assignment makes pointer from integer without a cast
   FS = tgetstr("fs", &_tptr);
window.c:2011:6: warning: assignment makes pointer from integer without a cast
   DS = tgetstr("ds", &_tptr);
window.c:2036:3: warning: implicit declaration of function ‘tgetflag’ [-Wimplicit-function-declaration]
   if (!tgetflag("hs") || !tgetflag("es") || !TS || !FS)
Makefile:515: recipe for target 'window.o' failed
make[2]: *** [window.o] Error 1
make[2]: Leaving directory '/home/shigang/linux-alient/tool/minicom-2.7.1/src'
Makefile:388: recipe for target 'all-recursive' failed
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory '/home/shigang/linux-alient/tool/minicom-2.7.1'
Makefile:326: recipe for target 'all' failed
make: *** [all] Error 2
不知道什么原因?
42
185
185
2019-5-24
39 小时
 楼主| 发表于 2020-5-24 16:57:26 | 显示全部楼层
在make编译时:编译到:
arm-linux-gnueabihf-gcc -DHAVE_CONFIG_H -I. -I..  -I/home/shigang/linux-alient/tool/ncurses/include -I../lib -DCONFDIR=\"/home/shigang/linux-alient/tool/minicom/etc\" -DLOCALEDIR=\"/home/shigang/linux-alient/tool/minicom/share/locale\" -I/home/shigang/linux-alient/tool/ncurses/include  -g -O2 -W -Wall -Wextra -std=gnu99 -MT window.o -MD -MP -MF .deps/window.Tpo -c -o window.o window.c
window.c: In function ‘outstr’:
window.c:196:3: warning: implicit declaration of function ‘tputs’ [-Wimplicit-function-declaration]
   tputs(s, 1, outchar);
window.c: In function ‘_gotoxy’:
window.c:294:7: warning: implicit declaration of function ‘tgoto’ [-Wimplicit-function-declaration]
       outstr(tgoto(CM, x, y));
window.c:294:14: warning: passing argument 1 of ‘outstr’ makes pointer from integer without a cast
window.c:194:13: note: expected ‘const char *’ but argument is of type ‘int’
static void outstr(const char *s)
window.c:302:16: warning: passing argument 1 of ‘outstr’ makes pointer from integer without a cast
         outstr(tgoto(TS, x, x));
window.c:338:12: error: ‘BC’ undeclared (first use in this function)
707
2180
2180
2018-8-27
258 小时
发表于 2020-5-25 09:29:32 | 显示全部楼层
回帖奖励 +1 金钱
帮顶!
193
193
2019-5-12
51 小时
发表于 2020-6-21 00:26:05 | 显示全部楼层
楼主解决了吗,我也遇到和你一样的问题,主要是error: ‘BC’ undeclared (first use in this function)
198
1065
1065
2019-9-19
195 小时
发表于 2020-6-21 12:23:54 | 显示全部楼层
请检查minicom配置指令,建议亲手敲一遍,不要复制粘贴。出现这问题都是ncurses库路径配置没起作用导致,minicom的源代码中会使用ncurses提供的函数。
出征,嗒嗒嗒——
快点上车!
69
69
2020-2-17
19 小时
发表于 2021-1-7 21:34:43 | 显示全部楼层
兄弟请问minicom 2.7.1 编写失败的问题是怎么解决的呢?
45
45
2020-7-4
发表于 2021-7-19 11:45:23 | 显示全部楼层
我这边碰到这样的,目前尚未解决
2022-6-8
发表于 2022-7-8 09:14:52 | 显示全部楼层
flyzeng 发表于 2020-6-21 12:23
请检查minicom配置指令,建议亲手敲一遍,不要复制粘贴。出现这问题都是ncurses库路径配置没起作用导致,mi ...
亲手敲才更容易出错吧,稍微不注意打错了一个字母就废了,这么长,还不如直接写个脚本
2019-8-31
发表于 2022-8-30 18:00:47 | 显示全部楼层
解决了,重新解压ncurses和minicom的包,从头来一遍就可以了
记得交叉编译器要安装好
2023-8-27
发表于 2023-9-18 09:22:11 | 显示全部楼层
记得交叉编译器要安装好
请教下你的ubuntu是什么版本,我的20.4移植失败
GMT+8, 2026-10-31 01:43
