查看: 4653|回复: 1
用STM32f042配Si4463通信死活不成功
77
77
2019-1-19
16 小时
发表于 2020-5-26 17:21:14 | 显示全部楼层 |阅读模式
大家好!
     最近本人在开发Si4463,开始用STM32f103开发Si4463实现了无线通信,公司为了节省成本,缩小元器件的空间,换STM32f042芯片,但死活不成功。硬件外围电路是一样的,
就主控芯片不一样。下面是我SPI配置代码,请问有错吗?麻烦大家帮看看。
实现收发通信的STM32f103 SPI配置:
#define SPI_CLK_GPIO_PORT                        GPIOA
#define SPI_CLK_GPIO_CLK                        RCC_APB2Periph_GPIOA
#define SPI_CLK_GPIO_PIN                        GPIO_Pin_5
#define SPI_MISO_GPIO_PORT                        GPIOA
#define SPI_MISO_GPIO_CLK                        RCC_APB2Periph_GPIOA
#define SPI_MISO_GPIO_PIN                        GPIO_Pin_6
#define SPI_MOSI_GPIO_PORT                        GPIOA
#define SPI_MOSI_GPIO_CLK                        RCC_APB2Periph_GPIOA
#define SPI_MOSI_GPIO_PIN                        GPIO_Pin_7
#define SPI_NSS_GPIO_PORT                        GPIOA
#define SPI_NSS_GPIO_CLK                        RCC_APB2Periph_GPIOA
#define SPI_NSS_GPIO_PIN                        GPIO_Pin_4
#define spi_set_nss_high( )                        SPI_NSS_GPIO_PORT->ODR |= SPI_NSS_GPIO_PIN
#define spi_set_nss_low( )                        SPI_NSS_GPIO_PORT->ODR &= (uint32_t)( ~((uint32_t)SPI_NSS_GPIO_PIN ))
#define SPI_PORT                                        SPI1
#define SPI_PORT_CLK                                RCC_APB2Periph_SPI1
void drv_spi_init( void );
unsigned char drv_spi_read_write_byte( unsigned char TxByte );
#define SPI_WAIT_TIMEOUT                        ((unsigned short int)0xFFFF)
        GPIO_InitTypeDef        SpiGpioInitStructer;
        SPI_InitTypeDef                SpiInitStructer;
        RCC_APB2PeriphClockCmd( SPI_CLK_GPIO_CLK | SPI_MISO_GPIO_CLK | SPI_MOSI_GPIO_CLK | SPI_NSS_GPIO_CLK, ENABLE );
        SpiGpioInitStructer.GPIO_Speed = GPIO_Speed_10MHz;
        SpiGpioInitStructer.GPIO_Mode = GPIO_Mode_AF_PP;
        SpiGpioInitStructer.GPIO_Pin = SPI_CLK_GPIO_PIN;
        GPIO_Init( SPI_CLK_GPIO_PORT, &SpiGpioInitStructer );
        SpiGpioInitStructer.GPIO_Pin = SPI_MOSI_GPIO_PIN;
        GPIO_Init( SPI_MOSI_GPIO_PORT, &SpiGpioInitStructer );
        GPIO_SetBits( SPI_MOSI_GPIO_PORT, SPI_MOSI_GPIO_PIN );
        SpiGpioInitStructer.GPIO_Pin = SPI_MISO_GPIO_PIN;
        GPIO_Init( SPI_MISO_GPIO_PORT, &SpiGpioInitStructer );
        GPIO_SetBits( SPI_MISO_GPIO_PORT, SPI_MISO_GPIO_PIN );
        SpiGpioInitStructer.GPIO_Mode = GPIO_Mode_Out_PP;
        SpiGpioInitStructer.GPIO_Pin = SPI_NSS_GPIO_PIN;
        GPIO_Init( SPI_NSS_GPIO_PORT, &SpiGpioInitStructer );
        GPIO_SetBits( SPI_NSS_GPIO_PORT, SPI_NSS_GPIO_PIN );
        SPI_I2S_DeInit( SPI_PORT );
        if( SPI1 == SPI_PORT )
                RCC_APB2PeriphClockCmd( SPI_PORT_CLK, ENABLE );
                RCC_APB1PeriphClockCmd( SPI_PORT_CLK, ENABLE );
        SPI_Cmd( SPI_PORT, DISABLE );
        SpiInitStructer.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
        SpiInitStructer.SPI_Mode = SPI_Mode_Master;
        SpiInitStructer.SPI_CPOL = SPI_CPOL_Low;
        SpiInitStructer.SPI_CPHA = SPI_CPHA_1Edge;
        SpiInitStructer.SPI_DataSize = SPI_DataSize_8b;
        SpiInitStructer.SPI_NSS = SPI_NSS_Soft;
        SpiInitStructer.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_32;
        SpiInitStructer.SPI_FirstBit = SPI_FirstBit_MSB;
        SpiInitStructer.SPI_CRCPolynomial = 7;
        SPI_Init( SPI_PORT, &SpiInitStructer );
        SPI_Cmd( SPI_PORT, ENABLE );
        uint8_t l_Data = 0;
        uint16_t l_WaitTime = 0;
        while( RESET == SPI_I2S_GetFlagStatus( SPI_PORT, SPI_I2S_FLAG_TXE ) )
                if( SPI_WAIT_TIMEOUT == ++l_WaitTime )
                        break;
        l_WaitTime = SPI_WAIT_TIMEOUT / 4;
        SPI_PORT->DR = TxByte;
        while( RESET == SPI_I2S_GetFlagStatus( SPI_PORT, SPI_I2S_FLAG_RXNE ) )
                        break;
        l_Data = (uint8_t)SPI_PORT->DR;
        return l_Data;
void SI446x_Gpio_Init( void )
        GPIO_InitTypeDef GpioInitStructer;
        //打开引脚端口时钟
        RCC_APB2PeriphClockCmd( SI4463_SDN_CLK | SI4463_IRQ_CLK | SI4463_GPIO0_CLK | SI4463_GPIO1_CLK | SI4463_GPIO2_CLK | SI4463_GPIO3_CLK, ENABLE );
        //SDN 引脚配置为推挽输出
        GpioInitStructer.GPIO_Pin = SI4463_SDN_PIN;
        GPIO_Init( SI4463_SDN_PORT, &GpioInitStructer );
        GPIO_ResetBits( SI4463_SDN_PORT, SI4463_SDN_PIN );        //SDN 置低 使能设备
        //IRQ GPIO0~GPIO3输入 可做外部信号中断输入 Demo程序采用查询方式 未配置成中断
        GpioInitStructer.GPIO_Mode = GPIO_Mode_IPU;
        GpioInitStructer.GPIO_Pin = SI4463_IRQ_PIN;
        GPIO_Init( SI4463_IRQ_PORT, &GpioInitStructer );        //IRQ
通信s死活不成功的的STM32f042 SPI配置:
#define SPI_CLK_GPIO_CLK                        RCC_AHBPeriph_GPIOA
#define SPI_MISO_GPIO_CLK                        RCC_AHBPeriph_GPIOA
#define SPI_MOSI_GPIO_CLK                        RCC_AHBPeriph_GPIOA
#define SPI_NSS_GPIO_CLK                        RCC_AHBPeriph_GPIOA
//#define spi_set_nss_high()                SPI_NSS_GPIO_PORT->ODR |= SPI_NSS_GPIO_PIN
//#define spi_set_nss_low()                        SPI_NSS_GPIO_PORT->ODR &= (uint32_t)( ~((uint32_t)SPI_NSS_GPIO_PIN ))
#define spi_set_nss_high()                (SPI_NSS_GPIO_PORT->BSRR = SPI_NSS_GPIO_PIN)
#define spi_set_nss_low()                        (SPI_NSS_GPIO_PORT->BRR  = SPI_NSS_GPIO_PIN)
void SPI_SetSpeed(u8 SPI_BaudRatePrescaler);
        RCC_AHBPeriphClockCmd( SPI_CLK_GPIO_CLK | SPI_MISO_GPIO_CLK | SPI_MOSI_GPIO_CLK | SPI_NSS_GPIO_CLK, ENABLE );
  GPIO_PinAFConfig(GPIOA,GPIO_PinSource5, GPIO_AF_0);
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource6, GPIO_AF_0);
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource7, GPIO_AF_0);
        SPI_StructInit(&SpiInitStructer);
        SpiGpioInitStructer.GPIO_Mode = GPIO_Mode_AF;
  SpiGpioInitStructer.GPIO_OType = GPIO_OType_PP;
  SpiGpioInitStructer.GPIO_PuPd  = GPIO_PuPd_UP ;
        GPIO_Init(SPI_CLK_GPIO_PORT , &SpiGpioInitStructer);
        SpiGpioInitStructer.GPIO_Mode = GPIO_Mode_OUT;
        SpiGpioInitStructer.GPIO_OType= GPIO_OType_OD;
        SpiInitStructer.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_16;
        SPI_RxFIFOThresholdConfig(SPI_PORT, SPI_RxFIFOThreshold_QF);
        drv_spi_read_write_byte(0xff);//Æô¶ˉ′«êä
        SPI_SetSpeed(SPI_BaudRatePrescaler_16);//éèÖÃÎa18Mê±Öó,¸ßËùÄ£ê½
        //′ò¿aòy½Å¶Ë¿úê±Öó
  RCC_AHBPeriphClockCmd( SI4463_SDN_CLK | SI4463_IRQ_CLK , ENABLE );
        //SDN òy½ÅÅäÖÃÎaíÆíìêä3ö
        GpioInitStructer.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_ResetBits( SI4463_SDN_PORT, SI4463_SDN_PIN );        //SDN ÖÆμí ê1Äüé豸
        //IRQ BAT  êäèë ¿é×öía2¿DÅoÅêäèë Demo3ìDò2éóÃ2éÑˉ·½ê½ Î′ÅäÖÃ3éÖD¶Ï
        GpioInitStructer.GPIO_Mode = GPIO_Mode_IN;
        GpioInitStructer.GPIO_PuPd = GPIO_PuPd_NOPULL;
共同部分
        uint8_t l_Data = 0;
        while(SPI_I2S_GetFlagStatus( SPI_PORT, SPI_I2S_FLAG_TXE )==RESET )
                        break;
                        break;
  return l_Data;
void SI446x_Init( void )
        SI446x_Gpio_Init( );                //SI4463òy½Å
        SI446x_Reset( );                        //SI4463¸′λ
        SI446x_Power_Up( 30000000 );//reset oóDèòaPower upé豸 ¾§Õñ30MHz
        SI446x_Config_Init( );                //SI4463Ä£¿é3õê¼»ˉ
        SI446x_Set_Power( 0x7F );        //1|ÂêéèÖÃ
        //SI446x_Change_Status( 6 );        //ÇD»»μ½RX×′ì¬
        //while( 6 != SI446x_Get_Device_Status( ));
        SI446x_Start_Rx( 0, 0, PACKET_LENGTH,0,0,3 );
        SI446x_Get_Part_Informatoin();
求助!各位大神!谢谢帮忙看看。拉线都是的,就是换了IO口和SPI初始化配置。
77
77
2019-1-19
16 小时
 楼主| 发表于 2020-5-27 18:28:29 | 显示全部楼层
本人已解决问题,原来F0SPI与F1SPI函数有比较多的区别。把收发函数改下即可,F0如果传送 数据是8bit,请用8bit的库函数,如果传送 数据是16bit,请用16bit的库函数.
GMT+8, 2026-11-3 21:24
