查看: 11160|回复: 6
哪位有STM32+ST7789V,驱动例程可以分享一下吗
58
334
334
2019-9-15
126 小时
发表于 2020-6-1 15:39:29 | 显示全部楼层 |阅读模式
最近拿到一块2.4寸  spi驱动的ST779V得屏,但是根据商家给的驱动程序,改写完后,屏幕只是亮起背光没有其他反应,哪位大神有这块屏的stm32的例程啊,可不可以分享一下,谢谢
下面是我改的LCD的初始化
        SPILCD_RST_SET ;        //LCD_RST=1
        delay_ms(1);
        SPILCD_RST_RESET ;        //LCD_RST=0         //SPI接口复位
        delay_ms(1); // delay 20 ms
        delay_ms(120);
        lcddev.width=240;
        lcddev.height=320;
        lcddev.wramcmd=0X2C;  //存储
        lcddev.setxcmd=0X2A;  //列地址
        lcddev.setycmd=0X2B;  //页地址
//        LCD_RESET=1;
//        delay (100); //Delay 100ms
//        LCD_RESET=0;
//        delay (200); //Delay 200ms
//        LCD_RESET=1;
//        delay (500); //Delay 500ms
        LCD_WR_REG(0x11);
        delay_ms(120); //Delay 120ms
        //------------------------------display and color format setting--------------------------------//
        LCD_WR_REG(0x36);
        LCD_WR_DATA8(0x00);
        LCD_WR_REG(0x3a);
        LCD_WR_DATA8(0x05);
        //--------------------------------ST7789V Frame rate setting----------------------------------//
        LCD_WR_REG(0xb2);
        LCD_WR_DATA8(0x0c);
        LCD_WR_DATA8(0x0c);
        LCD_WR_DATA8(0x00);
        LCD_WR_DATA8(0x33);
        LCD_WR_DATA8(0x33);
        LCD_WR_REG(0xb7);
        LCD_WR_DATA8(0x35);
        //---------------------------------ST7789V Power setting--------------------------------------//
        LCD_WR_REG(0xbb);
        LCD_WR_DATA8(0x1c);
        LCD_WR_REG(0xc0);
        LCD_WR_DATA8(0x2c);
        LCD_WR_REG(0xc2);
        LCD_WR_DATA8(0x01);
        LCD_WR_REG(0xc3);
        LCD_WR_DATA8(0x0b);
        LCD_WR_REG(0xc4);
        LCD_WR_DATA8(0x20);
        LCD_WR_REG(0xc6);
        LCD_WR_DATA8(0x0f);
        LCD_WR_REG(0xd0);
        LCD_WR_DATA8(0xa4);
        LCD_WR_DATA8(0xa1);
        //--------------------------------ST7789V gamma setting---------------------------------------//
        LCD_WR_REG(0xe0);
        LCD_WR_DATA8(0xd0);
        LCD_WR_DATA8(0x00);
        LCD_WR_DATA8(0x03);
        LCD_WR_DATA8(0x09);
        LCD_WR_DATA8(0x13);
        LCD_WR_DATA8(0x1c);
        LCD_WR_DATA8(0x3a);
        LCD_WR_DATA8(0x55);
        LCD_WR_DATA8(0x48);
        LCD_WR_DATA8(0x18);
        LCD_WR_DATA8(0x12);
        LCD_WR_DATA8(0x0e);
        LCD_WR_DATA8(0x19);
        LCD_WR_DATA8(0x1e);
        LCD_WR_REG(0xe1);
        LCD_WR_DATA8(0xd0);
        LCD_WR_DATA8(0x00);
        LCD_WR_DATA8(0x03);
        LCD_WR_DATA8(0x09);
        LCD_WR_DATA8(0x05);
        LCD_WR_DATA8(0x25);
        LCD_WR_DATA8(0x3a);
        LCD_WR_DATA8(0x55);
        LCD_WR_DATA8(0x50);
        LCD_WR_DATA8(0x3d);
        LCD_WR_DATA8(0x1c);
        LCD_WR_DATA8(0x1d);
        LCD_WR_DATA8(0x1d);
        LCD_WR_DATA8(0x1e);
        LCD_WR_REG(0x21);
        LCD_WR_REG(0x11);
        delay_ms(120);
        LCD_Clear(BLACK);
        LCD_WR_REG(0x29);
SPI_InitTypeDef  SPI_InitStructure;
void SPI1_Init(void)
        GPIO_InitTypeDef  GPIO_InitStructure;
        RCC_APB2PeriphClockCmd(        RCC_APB2Periph_SPI1,  ENABLE );//SPI1时钟使能
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOD, ENABLE);         //使能A端口时钟   //RES
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                  //推挽输出
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//速度50MHz
        GPIO_Init(GPIOA, &GPIO_InitStructure);          //初始化GPIOD3,6
        //GPIO_SetBits(GPIOA,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_4);
//        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);         //使能A端口时钟   PA4 CS  PA6 DC
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4|GPIO_Pin_6;
//         GPIO_SetBits(GPIOB,GPIO_Pin_4|GPIO_Pin_1|GPIO_Pin_8);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_7;  //sck sda
//        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
//         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                  //推挽输出
//        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//速度50MHz
//         GPIO_Init(GPIOD, &GPIO_InitStructure);
        GPIO_SetBits(GPIOA ,GPIO_Pin_9|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
//        GPIO_SetBits(GPIOA,GPIO_Pin_5|GPIO_Pin_7);  //PB13/14/15上拉
        SPI_InitStructure.SPI_Direction = SPI_Direction_1Line_Tx;  //设置SPI单向或者双向的数据模式:SPI设置为双线双向全双工  SPI_Direction_1Line_Tx
        SPI_InitStructure.SPI_Mode = SPI_Mode_Master;                //设置SPI工作模式:设置为主SPI
        SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;                //设置SPI的数据大小:SPI发送接收8位帧结构
        SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;                //选择了串行时钟的稳态:时钟悬空高
        SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;        //数据捕获于第二个时钟沿
        SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;                //NSS信号由硬件(NSS管脚)还是软件(使用SSI位)管理:内部NSS信号有SSI位控制
        SPI_InitStructure.SPI_BaudRatePrescaler =SPI_BaudRatePrescaler_8;                //定义波特率预分频的值:波特率预分频值为16
        SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;        //指定数据传输从MSB位还是LSB位开始:数据传输从MSB位开始
        SPI_InitStructure.SPI_CRCPolynomial = 7;        //CRC值计算的多项式
        SPI_Init(SPI1, &SPI_InitStructure);  //根据SPI_InitStruct中指定的参数初始化外设SPIx寄存器
        SPI_Cmd(SPI1, ENABLE); //使能SPI外设
        SPI1_ReadWriteByte(0xff);//启动传输
//        SPI1_SetSpeed(SPI_BaudRatePrescaler_256);//设置为18M时钟,高速模式
58
64
64
2015-12-27
帮顶!!!!!!!!!!!!!
110
989
989
2013-4-21
307 小时
发表于 2020-6-1 20:05:50 | 显示全部楼层
原子家有款开发板用的7789的芯片,在此基础上移植吧,不难的,以前我就是这么干的!
58
334
334
2019-9-15
126 小时
 楼主| 发表于 2020-6-2 08:59:53 | 显示全部楼层
谢谢,我不知道他家用过这款屏,我找一找
42
183
183
2021-3-11
30 小时
发表于 2023-4-18 17:33:23 | 显示全部楼层
你试试修改
1.屏幕的驱动
2.驱动部分复位时间 调整一下,1ms可能太短暂
驱动:
Void ST7789V CTC 28panelgamma(void)
//-----------------------------------ST7789V reset sequence------------------------------------//
LCD_RESET=1;
Delayms(1);                  //Delay 1ms
LCD_RESET=0;
Delayms(10);                  //Delay 10ms
LCD_RESET=1;
Delayms(120);                //Delay 120ms
LCD_CtrlWrite_ST7789V(0x11);
LCD_Delayms(120); //Delay 120ms
LCD_CtrlWrite_ST7789V(0x36);
LCD_DataWrite_ST7789V(0x00);
LCD_CtrlWrite_ST7789V(0x3a);
LCD_DataWrite_ST7789V(0x05);//0x55
LCD_CtrlWrite_ST7789V(0xb2);
LCD_DataWrite_ST7789V(0x0c);
LCD_DataWrite_ST7789V(0x33);
LCD_CtrlWrite_ST7789V(0xb7);
LCD_DataWrite_ST7789V(0x35);
LCD_CtrlWrite_ST7789V(0xbb);
LCD_DataWrite_ST7789V(0x19);//0x28
LCD_CtrlWrite_ST7789V(0xc0);
LCD_DataWrite_ST7789V(0x2c);
LCD_CtrlWrite_ST7789V(0xc2);
LCD_DataWrite_ST7789V(0x01);
LCD_CtrlWrite_ST7789V(0xc3);
LCD_DataWrite_ST7789V(0x12);//0x10
LCD_CtrlWrite_ST7789V(0xc4);
LCD_DataWrite_ST7789V(0x20);
LCD_CtrlWrite_ST7789V(0xc6);
LCD_DataWrite_ST7789V(0x0f);
LCD_CtrlWrite_ST7789V(0xd0);
LCD_DataWrite_ST7789V(0xa4);
LCD_DataWrite_ST7789V(0xa1);
LCD_CtrlWrite_ST7789V(0xe0);
LCD_DataWrite_ST7789V(0xd0);
LCD_DataWrite_ST7789V(0x04);//0x00
LCD_DataWrite_ST7789V(0x0d);//0x02
LCD_DataWrite_ST7789V(0x11);//0x07
LCD_DataWrite_ST7789V(0x13);//0x0a
LCD_DataWrite_ST7789V(0x2b);//0x28
LCD_DataWrite_ST7789V(0x3f);//0x32
LCD_DataWrite_ST7789V(0x54);//0x44
LCD_DataWrite_ST7789V(0x4c);//0x42
LCD_DataWrite_ST7789V(0x18);//0x06
LCD_DataWrite_ST7789V(0x0d);//0x0e
LCD_DataWrite_ST7789V(0x0b);//0x12
LCD_DataWrite_ST7789V(0x1f);//0x14
LCD_DataWrite_ST7789V(0x23);//0x17
LCD_CtrlWrite_ST7789V(0xe1);
LCD_DataWrite_ST7789V(0xd0);//0xd0
LCD_DataWrite_ST7789V(0x0c);//0x02
LCD_DataWrite_ST7789V(0x2c);//0x28
LCD_DataWrite_ST7789V(0x3f);//0x31
LCD_DataWrite_ST7789V(0x44);//0x54
LCD_DataWrite_ST7789V(0x51);//0x47
LCD_DataWrite_ST7789V(0x2f);//0x0e
LCD_DataWrite_ST7789V(0x1f);//0x1c
LCD_DataWrite_ST7789V(0x1f);//0x17
LCD_DataWrite_ST7789V(0x20);//0x1b
LCD_DataWrite_ST7789V(0x23);//0x1e
LCD_CtrlWrite_ST7789V(0x29);
Void ST7789VPanelTurnOnDisplay (void)
Write command 0x29;
Void ST7789VPanelTurnOffDisplay (void)
Write command 0x28;
Void ST7789VPanelTurnOnPartial (void)
Write command 0x30;
Write data 0x00;
Write PSL;    //PSL: Start Line
Write data 0x00;
Write PEL;    //PEL: End Line
Write command 0x12;
Void ST7789VPanelTurnOffPartial (void)
Write command 0x13;
Void ST7789VPanelTurnOnIdle (void)
Write command 0x39;
Void ST7789VPanelTurnOffIdle (void)
Write command 0x38;
Void ST7789VPanelSleepInMode (void)
Write command 0x10;
Delayms (120);
Void ST7789VPanelSleepOutMode (void)
Write command 0x11;
Delayms (120);
勤学如春起之苗,不见其增,日有所长
2020-10-20
发表于 2023-6-27 11:45:04 | 显示全部楼层
大家使用st7789v的时候有没有出现SPI+DMA传输时,全屏刷新不同的单色,有时候会有割裂感(就是刷到一半顿了一下),有时候挺丝滑的,而且这个现象随着SPI频率的提高出现的概率变小;割裂感这个现象在用上gui及动画时会比较恶心
下面是SPI频率30MHz和60MHz时的慢动作视频对比,能看到60MHz时有时候好的,有时候割裂的,而30MHz时几乎都是割裂的
刷屏对比.rar
4.63 MB, 下载次数: 24
36
36
2016-9-6
发表于 2025-11-1 10:46:33 | 显示全部楼层
修道者I 发表于 2023-4-18 17:33
你试试修改
1.屏幕的驱动
必须赞一个,厂商的例程都是配ILI9341的显示的偏色,找了一整晚,找到这里终于解决了
GMT+8, 2026-10-30 22:58
