查看: 6406|回复: 3
数码管延时多屏切换消隐的问题
2020-7-19
发表于 2020-7-26 17:51:57 | 显示全部楼层 |阅读模式
2金钱
enenene  写了这个 一部分然后主函数中 不加多页面切换的时候8个都显示正常,但是加了之后前7个正常最后一个消隐了和没弄一样。之后我自己从第一个调试发现只让第一个亮但是最后一个也亮、只让第二个亮最后一个也亮就是不太明显。后几个都这样。。这是咋回事。一下午了   害。
void Display()
static        u8 i=0;
        switch (1)
          case 0:
                GPIO_DIG = smgduan[LEDBuf[0]];
                GPIO_PLACE = weixuan[0];
                delay(1);
                GPIO_DIG = 0x00;
                GPIO_PLACE =0x00;
                i++;
                break;
          case 1:
                GPIO_DIG = smgduan[LEDBuf[1]];
                GPIO_PLACE = weixuan[1];
                delay(1);
                GPIO_DIG = 0x00;
                GPIO_PLACE =0x00;
                i++;
                break;
                case 2:
                GPIO_DIG = smgduan[LEDBuf[2]];
                GPIO_PLACE = weixuan[2];
                delay(1);
                GPIO_DIG = 0x00;
                GPIO_PLACE =0x00;
                i++;
                break;
                case 3:
                GPIO_DIG = smgduan[LEDBuf[3]];
                GPIO_PLACE = weixuan[3];
                delay(1);
                GPIO_DIG = 0x00;
                GPIO_PLACE =0x00;
                i++;
                break;
                case 4:
                GPIO_DIG = smgduan[LEDBuf[4]];
                GPIO_PLACE = weixuan[4];
                delay(1);
                GPIO_DIG = 0x00;
                GPIO_PLACE =0x00;
                i++;
                break;
                case 5:
                GPIO_DIG = smgduan[LEDBuf[5]];
                GPIO_PLACE = weixuan[5];
                delay(1);
                GPIO_DIG = 0x00;
                GPIO_PLACE =0x00;
                i++;
                break;
                case 6:
                GPIO_DIG = smgduan[LEDBuf[6]];
                GPIO_PLACE = weixuan[6];
                delay(1);
                GPIO_DIG = 0x00;
                GPIO_PLACE =0x00;
                i++;
                break;
                /*case 7:
                GPIO_DIG = smgduan[LEDBuf[7]];
                GPIO_PLACE = weixuan[7];
                delay(1);
                GPIO_DIG = 0x00;
                GPIO_PLACE =0x00;
                i=0;
                break;*/
          default:break;
void main()
        u16 i;
        for(i=0;i<5000;i++)
                Display();
                switch (wnd)
            case 0:
                        LEDBuf[0] =0;
                        LEDBuf[1] =1;
                        LEDBuf[2] =2;
                        LEDBuf[3] =3;
                        LEDBuf[4] =4;
                        LEDBuf[5] =8;
                        LEDBuf[6] =3;
                        LEDBuf[7] =4;
                        for(i=0;i<5000;i++)
                                Display();
                        wnd++;
                        break;
            case 1:
                        LEDBuf[0] =2;
                        LEDBuf[1] =3;
                        LEDBuf[2] =5;
                        LEDBuf[3] =7;
                        LEDBuf[4] =6;
                        LEDBuf[5] =8;
                        LEDBuf[6] =3;
                        LEDBuf[7] =4;
                        for(i=0;i<5000;i++)
                                Display();
                        wnd=0;
                        break;
                        case 2:break;
            case 3:break;
                        case 4:break;
            case 5:break;
            default:
                    break;
扫描方式有问题,正确流程应该是:关闭上一个位选,送段码,开通位选...
79
2525
2525
2018-10-11
298 小时
发表于 2020-7-26 17:51:58 | 显示全部楼层
2020-7-19
 楼主| 发表于 2020-7-27 17:23:38 | 显示全部楼层
void Display()
static        u8 i=0;
        switch (1)
          case 0:
                delay(1);
                GPIO_DIG = 0x00;
                i++;
                break;
          case 1:
                delay(1);
                GPIO_DIG = 0x00;
                i++;
                break;
void main()
Display();
我如果只这样写就可以运行而且可以消隐,如果改成下边这样初始第一屏可以消隐后边的就不能消隐了。好难搞啊
void main()
        u16 i,wnd=0;
        for(i=0;i<5000;i++)
                Display();
                switch (wnd)
            case 0:
                        LEDBuf[0] =0;
                        LEDBuf[1] =1;
                        for(i=0;i<5000;i++)
                                Display();
                        wnd++;
                        break;
            case 1:
                        LEDBuf[0] =2;
                        LEDBuf[1] =3;
                        for(i=0;i<5000;i++)
                                Display();
                        wnd=0;
                        break;
79
2525
2525
2018-10-11
298 小时
发表于 2020-7-28 08:14:29 | 显示全部楼层
GMT+8, 2026-11-14 09:15
