查看: 7035|回复: 4
Uboot和内核编译时提示警告信息是什么原因
43
43
2018-6-30
发表于 2020-7-30 10:04:49 | 显示全部楼层 |阅读模式
ubuntu 20.04 编译 uboot 和内核时候 执行默认配置命令  都会有一些警告信息   这个问题在ubuntu16.04中没有  哪位大神 知道这属于什么原因造成的? 有什么解决方法没有?
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- imx_alientek_emmc_defconfig
  HOSTCC  scripts/basic/fixdep
  HOSTCC  scripts/kconfig/conf.o
  SHIPPED scripts/kconfig/zconf.tab.c
  SHIPPED scripts/kconfig/zconf.lex.c
  SHIPPED scripts/kconfig/zconf.hash.c
  HOSTCC  scripts/kconfig/zconf.tab.o
In file included from scripts/kconfig/zconf.tab.c:2534:
scripts/kconfig/confdata.c: In function ‘conf_write’:
scripts/kconfig/confdata.c:773:19: warning: ‘%s’ directive writing likely 7 or more bytes into a region of size between 1 and 4097 [-Wformat-overflow=]
  773 |  sprintf(newname, "%s%s", dirname, basename);
scripts/kconfig/confdata.c:773:19: note: assuming directive output of 7 bytes
In file included from /usr/include/stdio.h:867,
                 from scripts/kconfig/zconf.tab.c:84:
/usr/include/x86_64-linux-gnu/bits/stdio2.h:36:10: note: ‘__builtin___sprintf_chk’ output 1 or more bytes (assuming 4104) into a destination of size 4097
   36 |   return __builtin___sprintf_chk (__s, __USE_FORTIFY_LEVEL - 1,
   37 |       __bos (__s), __fmt, __va_arg_pack ());
scripts/kconfig/confdata.c:776:20: warning: ‘.tmpconfig.’ directive writing 11 bytes into a region of size between 1 and 4097 [-Wformat-overflow=]
  776 |   sprintf(tmpname, "%s.tmpconfig.%d", dirname, (int)getpid());
/usr/include/x86_64-linux-gnu/bits/stdio2.h:36:10: note: ‘__builtin___sprintf_chk’ output between 13 and 4119 bytes into a destination of size 4097
  HOSTLD  scripts/kconfig/conf
# configuration written to .config
编译器 按照教程给的 版本 只是 ubuntu 是20.04 环境 但是在16.04环境下没有这个提示
43
43
2018-6-30
 楼主| 发表于 2020-7-30 10:04:50 | 显示全部楼层
无忧花开 发表于 2020-8-1 15:33
这个不会吧?你编译器用的什么版本
144
442
442
2019-5-16
143 小时
发表于 2020-7-30 14:47:32 | 显示全部楼层
那就用Ubuntu16吧
134
301
301
2020-5-8
20 小时
发表于 2020-8-1 15:33:03 | 显示全部楼层
68
68
2019-10-16
18 小时
发表于 2020-10-23 20:28:43 | 显示全部楼层
是因为在confdata.c 771行,sprintf(newname, "%s%s", dirname, basename);中 newname的大小和dirname的大小相等,然后将dirname和basename中的数据写到newname中,编译器提示数据溢出,第774行也是同样的问题.@ubuntu12
GMT+8, 2026-10-31 06:28
