查看: 5108|回复: 0
这是霍尔编程的结构体定义,不明白为什么定义这些数据,求解。
68
68
2020-7-27
11 小时
发表于 2020-8-12 16:22:33 | 显示全部楼层 |阅读模式
typedef struct { Uint16 CmtnTrigHall;    // Output: Commutation trigger for Mod6cnt input (0 or 0x7FFF)
                 Uint16 CapCounter;      // Variable: Running count of detected edges on ECAP1,2,3
                 Uint16 DebounceCount;   // Variable: Counter/debounce delay current value
                 Uint16 DebounceAmount;  // Parameter: Counter delay amount to validate/debounce GPIO readings
                 Uint16 HallGpio;        // Variable: Most recent logic level on ECAP/GPIO
                 Uint16 HallGpioBuffer;  // Variable: Buffer of last logic level on ECAP/GPIO while being debounced
                 Uint16 HallGpioAccepted; // Variable: Debounced logic level on ECAP/GPIO
                 Uint16 EdgeDebounced;   // Variable: Trigger from Debounce function to Hall_Drv, if = 0x7FFF edge is debounced
                 Uint16 HallMap[6];      // Variable: ECAP/GPIO logic levels for HallMapPointer = 0-5
                 Uint16 CapFlag;          // Variable: ECAP flags, indicating which ECAP detected the edge
                 Uint16 StallCount;       // Variable: If motor stalls, this counter overflow triggers
                                          //           commutation to start rotation. Rotation is defined as
                                          //           an edge detection of a hall signal.
                 Uint16 HallMapPointer;   // Input/Output (see note below): During hall map creation, this variable points to the
                                          //            current commutation state.  After map creation, it
                                          //            points to the next commutation state.
                 int16 Revolutions;       // Parameter: Running counter, with a revolution defined as 1-cycle
                                          //            of the 6 hall states
GMT+8, 2026-11-5 20:22
