查看: 5506|回复: 2
关于LWIP 热拔插 卡在tcp_fasttmr的问题
2020-8-20
发表于 2020-8-20 09:58:58 | 显示全部楼层 |阅读模式
在STM32F207+LAN8720硬件组合平台上,移植LWIP 1.4.1 用的原子例程 做的是TCP MODBUS从站 也就是TCP Server
采用LAN8720寄存器检测是否插入网线
拔出时
插入时
遇到了一个问题 热拔插第一次可以恢复链接 第二次时卡在了 LWIP的tcp.c的tcp_fasttmr函数循环中
求问大神如何解决
2020-8-20
 楼主| 发表于 2020-8-20 10:01:52 | 显示全部楼层
拔出时
eMBTCPDisable();
eMBTCPClose();
netif_set_iink_down(&lwip_netif);
netif_set_down(&lwip_netif);
插入时
eMBTCPInit(502);
netif_set_link_up(&lwip_netif);
netif_set_up (&lwip_netif);
MBTCPEnable();
2020-8-20
 楼主| 发表于 2020-8-20 10:03:39 | 显示全部楼层
tcp_fasttmr函数:
* Is called every TCP_FAST_INTERVAL (250 ms) and process data previously
* "refused" by upper layer (application) and sends delayed ACKs.
* Automatically called from tcp_tmr().
void
tcp_fasttmr(void)
  struct tcp_pcb *pcb;
  ++tcp_timer_ctr;
tcp_fasttmr_start:
  pcb = tcp_active_pcbs;
  while(pcb != NULL) {
    if (pcb->last_timer != tcp_timer_ctr) {
      struct tcp_pcb *next;
      pcb->last_timer = tcp_timer_ctr;
      /* send delayed ACKs */
      if (pcb->flags & TF_ACK_DELAY) {
        LWIP_DEBUGF(TCP_DEBUG, ("tcp_fasttmr: delayed ACK\n"));
        tcp_ack_now(pcb);
        tcp_output(pcb);
        pcb->flags &= ~(TF_ACK_DELAY | TF_ACK_NOW);
      next = pcb->next;
      /* If there is data which was previously "refused" by upper layer */
      if (pcb->refused_data != NULL) {
        tcp_active_pcbs_changed = 0;
        tcp_process_refused_data(pcb);
        if (tcp_active_pcbs_changed) {
          /* application callback has changed the pcb list: restart the loop */
          goto tcp_fasttmr_start;
      pcb = next;
GMT+8, 2026-11-4 02:56
