查看: 7652|回复: 5
MPU6050读数一直是257或771
2020-3-13
发表于 2020-9-1 16:57:07 | 显示全部楼层 |阅读模式
4金钱
准备自己画板做个小四轴,先用原子的探索者(STM32F4)学学各个模块,自己接了MPU6050和oled,想着把MPU6050读出来的数据显示在oled上,但是一直读出来数据都是257或者771,不然就是65565和00000。不知道有没有遇到过相同问题的朋友,知不知道怎么解决,源码放下面
#ifndef __MPU_H
#define __MPU_H
#include "sys.h"
#include "stdlib.h"
#include "delay.h"
#define MPU_SCLK_Clr() GPIO_ResetBits(GPIOB,GPIO_Pin_4)//SCL
#define MPU_SCLK_Set() GPIO_SetBits(GPIOB,GPIO_Pin_4)
#define MPU_SDIN_Clr() GPIO_ResetBits(GPIOB,GPIO_Pin_5)//DIN
#define MPU_SDIN_Set() GPIO_SetBits(GPIOB,GPIO_Pin_5)
#define        SMPLRT_DIV                0x19        //陀螺仪采样率,典型值:0x07(125Hz)
#define        CONFIG                          0x1A        //低通滤波频率,典型值:0x06(5Hz)
#define        GYRO_CONFIG                0x1B        //陀螺仪自检及测量范围,典型值:0x18(不自检,2000deg/s)
#define        ACCEL_CONFIG        0x1C        //加速计自检、测量范围及高通滤波频率,典型值:0x01(不自检,2G,5Hz)
#define        ACCEL_XOUT_H        0x3B
#define        ACCEL_XOUT_L        0x3C
#define        ACCEL_YOUT_H        0x3D
#define        ACCEL_YOUT_L        0x3E
#define        ACCEL_ZOUT_H        0x3F
#define        ACCEL_ZOUT_L        0x40
#define        TEMP_OUT_H                0x41
#define        TEMP_OUT_L                0x42
#define        GYRO_XOUT_H                0x43
#define        GYRO_XOUT_L                0x44
#define        GYRO_YOUT_H                0x45
#define        GYRO_YOUT_L                0x46
#define        GYRO_ZOUT_H                0x47
#define        GYRO_ZOUT_L                0x48
#define        PWR_MGMT_1                0x6B        //电源管理,典型值:0x00(正常启用)
#define        WHO_AM_I                        0x75        //IIC地址寄存器(默认数值0x68,只读)
#define        SlaveAddress        0xD0        //IIC写入时的地址字节数据,+1为读取
void MPU_Init(void);
void MPU_IN(void);
void MPU_OUT(void);
void I2C_Start(void);
void I2C_Stop(void);
void I2C_SendACK(u8 ack);
u8 I2C_RecvACK(void);
u8 IIC_Wait_Ack(void);
void I2C_SendByte(u8 dat);
u8 I2C_RecvByte(u8 ack);
u8 Single_WriteI2C(u8 REG_Address,u8 REG_data);
u8 Single_ReadI2C(u8 REG_Address);
void InitMPU6050(void);
int GetData(u8 REG_Address);
#endif
#include "mpu.h"
void MPU_Init()
        GPIO_InitTypeDef  GPIO_InitStructure;
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);//使能GPIOF时钟
  //GPIOB4,B5初始化设置
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;//普通输出模式
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽输出
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100MHz
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉
  GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化
void MPU_IN()
  //GPIOB4,B5初始化设置
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;//普通输入模式
void MPU_OUT()
  //GPIOB4,B5初始化设置
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;//普通输入模式
//I2C起始信号
void I2C_Start()
    MPU_SDIN_Set();                    //拉高数据线
    MPU_SCLK_Set();                    //拉高时钟线
    delay_us(5);                       //延时
    MPU_SDIN_Clr();                    //产生下降沿
    delay_us(5);                       //延时
    MPU_SCLK_Clr();                    //拉低时钟线
//I2C停止信号
void I2C_Stop()
    MPU_SDIN_Clr();                    //拉低数据线
          delay_us(5);                       //延时
    MPU_SDIN_Set();                    //产生上升沿
    delay_us(5);                       //延时
//I2C发送应答信号
//入口参数:ack (0:ACK 1:NAK)
        if(ack)
    MPU_SDIN_Set();        //写应答信号
                MPU_SDIN_Clr();
          delay_us(5);                 //延时
    delay_us(5);                 //延时
    delay_us(5);                 //延时
//I2C接收应答信号
u8 I2C_RecvACK()
        u8 CY;
        MPU_IN();
    delay_us(5);                 //延时
    CY = PBin(5);                   //读应答信号
    delay_us(5);                 //延时
        MPU_OUT();
    return CY;
//等待应答信号到来
//返回值:1,接收应答失败
//        0,接收应答成功
        u16 ucErrTime=0;
        MPU_SDIN_Set();delay_us(5);
        MPU_SCLK_Set();delay_us(5);
        MPU_IN();      //SDA设置为输入
  delay_us(5);
        while(PBin(5))
                ucErrTime++;
                if(ucErrTime>2500)
                        MPU_OUT();
                        I2C_Stop();
                        return 1;
        MPU_SCLK_Clr();//时钟输出0
  MPU_OUT();
        return 0;
//向I2C总线发送一个字节数据
    u8 i;
    for (i=0; i<8; i++)         //8位计数器
                        if(dat&0x80)
        MPU_SDIN_Set();               //送数据口
                                MPU_SDIN_Clr();
                          dat <<= 1;              //移出数据的最高位
                          delay_us(5);
        delay_us(5);             //延时
        delay_us(5);             //延时
//    I2C_RecvACK();
//                IIC_Wait_Ack();
//从I2C总线接收一个字节数据
    u8 i;
    u8 dat = 0;
          MPU_IN();
        delay_us(5);             //延时
        dat <<= 1;
        delay_us(5);             //延时
                        if(PBin(5))dat++;
//        dat |= PBin(5);             //读数据
              delay_us(5);             //延时
                MPU_OUT();
                I2C_SendACK(!ack);
    return dat;
//向I2C设备写入一个字节数据
    I2C_Start();                  //起始信号
    I2C_SendByte(SlaveAddress);   //发送设备地址+写信号
                if(IIC_Wait_Ack())        //等待应答
//                I2C_Stop();
                return 1;
    I2C_SendByte(REG_Address);    //内部寄存器地址,
                IIC_Wait_Ack();
    I2C_SendByte(REG_data);       //内部寄存器数据,
//                I2C_Stop();
                return 1;
    I2C_Stop();                   //发送停止信号
        return 0;
//从I2C设备读取一个字节数据
        u8 REG_data;
        I2C_Start();                   //起始信号
        IIC_Wait_Ack();
        I2C_SendByte(REG_Address);     //发送存储单元地址,从0开始
        IIC_Wait_Ack();
        I2C_Start();                   //起始信号
        I2C_SendByte(SlaveAddress+1);  //发送设备地址+读信号
        IIC_Wait_Ack();
        REG_data=I2C_RecvByte(0);       //读出寄存器数据
        I2C_Stop();                    //停止信号
        return REG_data;
//初始化MPU6050
void InitMPU6050()
        Single_WriteI2C(PWR_MGMT_1, 0x80);        //复位
  delay_ms(500);
        Single_WriteI2C(PWR_MGMT_1, 0x00);        //解除休眠状态
        Single_WriteI2C(SMPLRT_DIV, 0x07);
        Single_WriteI2C(CONFIG, 0x06);
        Single_WriteI2C(GYRO_CONFIG, 0x18);
        Single_WriteI2C(ACCEL_CONFIG, 0x01);
//合成数据
        char H,L;
        H=Single_ReadI2C(REG_Address);
        L=Single_ReadI2C(REG_Address+1);
        return (H<<8)+L;   //合成数据
2020-3-13
 楼主| 发表于 2020-9-1 16:58:03 | 显示全部楼层
又出来新的示数了,65280,就是ff00
2020-3-13
 楼主| 发表于 2020-9-1 17:03:26 | 显示全部楼层
主函数就
int main(void)
        delay_init(168);
        delay_ms(1000);
        LED_Init();                                        //初始化LED
        OLED_Init();                                //初始化OLED
  MPU_Init();
        delay_ms(1000);
        InitMPU6050();  //初始化MPU6050
        delay_ms(1000);
        LED0=0;
        delay_ms(1000);
                     OLED_ShowNum(16,16,GetData(ACCEL_XOUT_H),5,16);
                OLED_ShowChar(0,16,'X',16);
                OLED_ShowChar(0,32,'Y',16);
                OLED_ShowChar(0,48,'Z',16);
                OLED_Refresh();
2020-3-13
 楼主| 发表于 2020-9-5 13:59:18 | 显示全部楼层
2020-3-13
 楼主| 发表于 2020-9-10 10:03:09 | 显示全部楼层
不是吧这么冷清
2021-10-29
发表于 2022-5-22 22:42:38 | 显示全部楼层
帮顶帮顶
GMT+8, 2026-11-11 00:29
