查看: 5914|回复: 2
关于lwip库驱动DP3848,指定upd的远程IP地址问题
207
207
2015-8-3
46 小时
发表于 2020-10-27 15:34:26 | 显示全部楼层 |阅读模式
10金钱
##netconn_connect(conn_send, addr_local_send, port_send);在这个函数中无法指定远端的IP  ,addr_local_send,请问这个 addr_local_send怎么赋值初始化?用这个IP4_ADDR(addr_local_send, 192, 168, 0, 123)无法初始化
##netconn_connect第二个参数怎么初始化?
//****代码如下****************************************
static void UdpSendData_thread(void *arg)
static struct netconn *conn_send;
static struct netbuf *buf_send;
static struct ip_addr *addr_local_send,*addr_me,*addr_lu;
static unsigned short port_send;
err_t err_0,recv_err;
TypedefStatusMsg StatusMsg;
BaseType_t xResult;
uint8_t *data_rec;
u16 len_rec;
LWIP_UNUSED_ARG(arg);
conn_send = netconn_new(NETCONN_UDP);//初始化创建UDP网络服务
if (conn_send!= NULL)
  IP4_ADDR(addr_me, IP_ADDR0, IP_ADDR1, IP_ADDR2, IP_ADDR3);//本地IP
  IP4_ADDR(addr_local_send, 192, 168, 0, 123);//发送对端IP
//  printf("addr_me: %ld addr0: %ld \r\n",addr_me->addr,addr_local_send->addr);
    err_0 = netconn_bind(conn_send, addr_me, 2883);//绑定 IP port :IP_ADDR_ANY时,则绑定到所有的本地IP地址
  port_send = 2883;
  if(err_0==ERR_OK)
    recv_err = netconn_recv(conn_send, &buf_send);//阻塞等待数据
        if (recv_err == ERR_OK)
          addr_lu = netbuf_fromaddr(buf_send);//读取对方地址 IP
          port_send = netbuf_fromport(buf_send);//读取对方端口 port
     netbuf_data(buf_send,(void **) &data_rec, &len_rec);
//          addr_local_send->addr=addr_lu->addr ;
     buf_send->addr.addr = 0;//发送原始对方数据
//     netconn_sendto(conn_send,buf_send,addr_local_send,port_send);
          netconn_send(conn_send,buf_send);
     netbuf_delete(buf_send);
     printf("udp-data time out \r\n");
    //vTaskDelayUntil(&xLastWakeTime,100);
      netconn_delete(conn_send);
      printf(" 1 can not bind netconn");
    printf("can create new UDP netconn");
发表于 2020-10-27 23:21:16 | 显示全部楼层
207
207
2015-8-3
46 小时
 楼主| 发表于 2020-10-29 11:17:41 | 显示全部楼层
还有遇到程序卡死在netconn_recv(conn,&buf)函数了,求大神帮解决@正点原子
GMT+8, 2026-11-4 02:56
