查看: 7586|回复: 3
51单片机电子钟不走来大佬看看
29
96
96
2019-9-29
19 小时
发表于 2020-11-18 20:34:17 | 显示全部楼层 |阅读模式
#include<reg52.h>
typedef unsigned char uchar;
typedef unsigned int uint;
#define lcd P0
sbit rs=P2^6;         //数据命令选择
sbit rw=P2^5;         //读写选择
sbit e=P2^7;        //使能
uint t;
//uchar m_1,m_2,f_1,f_2,s_1,s_2;
uchar sj[3]={1,2,3};
uchar sz[]={0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39};
void delayms(uchar c)   //误差 0us
    unsigned char a,b;
    for(;c>0;c--)
        for(b=142;b>0;b--)
            for(a=2;a>0;a--);
//lcd
void lcd_xzl(uchar com) //写指令
        delayms(10);
        rs=0;
        rw=0;
        e=1;
        delayms(1);
        lcd=com;
        delayms(1);
        e=0;
        //delayms(5);
void lcd_xsj(uchar dat) //写数据
        delayms(10);
        rs=1;
        rw=0;
        e=1;
        delayms(1);
        lcd=dat;
        delayms(1);
        e=0;
        //delayms(5);
void lcd_init()        //初始化
        lcd=0x00;
        lcd_xzl(0x38); //设置 8 位格式,2 行,5x7
        lcd_xzl(0x38);
        lcd_xzl(0x38);
        lcd_xzl(0x06); //设定输入方式,增量不位移
        lcd_xzl(0x0c); //整体显示,关光标,不闪烁
        lcd_xzl(0x01); //清屏
//计时
void InitTimer0(void)
    TMOD = 0x01;
    TH0 = 0x0FC;
    TL0 = 0x18;
    EA = 1;
    ET0 = 1;
    TR0 = 1;
void sj_js()
        if(t==1000)
                t=0;
                sj[0]++;
                if(sj[0]==60)
                        sj[1]++;
                        sj[0]=0;
                        if(sj[1]==60)
                                sj[2]++;
                                sj[1]=0;
                                if(sj[2]==24)
                                        sj[2]=0;
void lcd_szxs()
        //sj_js();
        m_1=sj[0]/10;
        m_2=sj[0]%10;
        f_1=sj[1]/10;
        f_2=sj[1]%10;
        s_1=sj[2]/10;
        s_2=sj[2]%10;
        lcd_xzl(0x00+0x80);
        lcd_xsj(0x20);
        lcd_xsj(0x20);
        lcd_xsj(0x20);
        lcd_xsj(0x20);
        lcd_xsj(sz[s_1]);
        lcd_xsj(sz[s_2]);
        lcd_xsj(0x3a);
        lcd_xsj(sz[f_1]);
        lcd_xsj(sz[f_2]);
        lcd_xsj(0x3a);
        lcd_xsj(sz[m_1]);
        lcd_xsj(sz[m_2]);
void main()
        lcd_init();
        InitTimer0();
                sj_js();
                lcd_szxs();
2为rs 3为rw 1为e
2为rs 3为rw 1为e
void Timer0Interrupt(void) interrupt 1
    TH0 = 0x0FC;
    TL0 = 0x18;
    t++;
求大佬指导,像是计时这有问题
29
96
96
2019-9-29
19 小时
 楼主| 发表于 2020-11-18 20:35:58 | 显示全部楼层
2为rs 3为rw 1为e
29
96
96
2019-9-29
19 小时
 楼主| 发表于 2020-11-18 20:37:26 | 显示全部楼层
#include<reg52.h>
#define lcd P0
sbit e=P2^7;        //使能
uint t;
    unsigned char a,b;
    for(;c>0;c--)
        for(b=142;b>0;b--)
            for(a=2;a>0;a--);
//lcd
        delayms(10);
        rs=0;
        rw=0;
        e=1;
        delayms(1);
        lcd=com;
        delayms(1);
        e=0;
        //delayms(5);
        delayms(10);
        rs=1;
        rw=0;
        e=1;
        delayms(1);
        lcd=dat;
        delayms(1);
        e=0;
        //delayms(5);
        lcd=0x00;
        lcd_xzl(0x38);
        lcd_xzl(0x38);
        lcd_xzl(0x01); //清屏
//计时
    TMOD = 0x01;
    TH0 = 0x0FC;
    TL0 = 0x18;
    EA = 1;
    ET0 = 1;
    TR0 = 1;
void sj_js()
        if(t==1000)
                t=0;
                sj[0]++;
                if(sj[0]==60)
                        sj[1]++;
                        sj[0]=0;
                        if(sj[1]==60)
                                sj[2]++;
                                sj[1]=0;
                                if(sj[2]==24)
                                        sj[2]=0;
void lcd_szxs()
        //sj_js();
        m_1=sj[0]/10;
        m_2=sj[0]%10;
        f_1=sj[1]/10;
        f_2=sj[1]%10;
        s_1=sj[2]/10;
        s_2=sj[2]%10;
        lcd_xzl(0x00+0x80);
        lcd_xsj(0x20);
        lcd_xsj(0x20);
        lcd_xsj(0x20);
        lcd_xsj(0x20);
        lcd_xsj(sz[s_1]);
        lcd_xsj(sz[s_2]);
        lcd_xsj(0x3a);
        lcd_xsj(sz[f_1]);
        lcd_xsj(sz[f_2]);
        lcd_xsj(0x3a);
        lcd_xsj(sz[m_1]);
        lcd_xsj(sz[m_2]);
void main()
        lcd_init();
        InitTimer0();
                sj_js();
                lcd_szxs();
    TH0 = 0x0FC;
    TL0 = 0x18;
    t++;
3515
9343
9343
2020-5-11
5170 小时
发表于 2020-11-19 11:03:47 | 显示全部楼层
专治疑难杂症
GMT+8, 2026-11-14 09:15
