查看: 8265|回复: 3
#0: wm8960-audio/random: nonblocking pool is initialized根文件系统问题求解
132
341
341
2018-7-20
120 小时
发表于 2020-12-3 18:26:01 | 显示全部楼层 |阅读模式
20金钱
根据正点原子提供的开发指南手册,已经移植u-boot和linux的情况下,构建根文件系统时初步测试,已经使用该命令测试,
setenv bootargs 'console=ttymxc0,115200 root=/dev/nfs rw nfsroot=192.168.0.109:/home/fang/linux/nfs/rootfs,proto=tcp ip=192.168.0.104:192.168.0.109:192.168.0.1:255.255.255.0::eth0ff'
出现如图的问题,然后系统就卡在这里了,
有人遇到过吗,可以指导一下吗谢谢
可能是nfs的配置有问题,可以看下这个帖子https://www.openedv.com/forum.php?mod=viewthread&tid=302907&highlight=nfs 还有你的Ubuntu是什么版本的?Ubuntu18及以上的需要修改下配置,这个帖子里也有写
我只喜欢喜欢我的人
214
1191
1191
2020-12-1
153 小时
发表于 2020-12-3 18:26:02 | 显示全部楼层
可能是nfs的配置有问题,可以看下这个帖子https://www.openedv.com/forum.php ... 7&highlight=nfs
132
341
341
2018-7-20
120 小时
 楼主| 发表于 2020-12-3 18:29:10 | 显示全部楼层
  1. [  137.922562] random: nonblocking pool is initialized
  2. [  458.402594] VFS: Unable to mount root fs via NFS, trying floppy.
  3. [  458.409215] VFS: Cannot open root device "nfs" or unknown-block(2,0): error -6
  4. [  458.416576] Please append a correct "root=" boot option; here are the available partitions:
  5. [  458.425014] 0100           65536 ram0  (driver?)
  6. [  458.429661] 0101           65536 ram1  (driver?)
  7. [  458.434433] 0102           65536 ram2  (driver?)
  8. [  458.439076] 0103           65536 ram3  (driver?)
  9. [  458.443785] 0104           65536 ram4  (driver?)
  10. [  458.448429] 0105           65536 ram5  (driver?)
  11. [  458.453138] 0106           65536 ram6  (driver?)
  12. [  458.457784] 0107           65536 ram7  (driver?)
  13. [  458.462425] 0108           65536 ram8  (driver?)
  14. [  458.467140] 0109           65536 ram9  (driver?)
  15. [  458.471781] 010a           65536 ram10  (driver?)
  16. [  458.476542] 010b           65536 ram11  (driver?)
  17. [  458.481269] 010c           65536 ram12  (driver?)
  18. [  458.486016] 010d           65536 ram13  (driver?)
  19. [  458.490744] 010e           65536 ram14  (driver?)
  20. [  458.495497] 010f           65536 ram15  (driver?)
  21. [  458.500235] b300         1955840 mmcblk0  driver: mmcblk
  22. [  458.505599] b308         7634944 mmcblk1  driver: mmcblk
  23. [  458.510937]   b309          131072 mmcblk1p1 58313c4b-01
  24. [  458.516303]   b30a         7493632 mmcblk1p2 58313c4b-02
  25. [  458.521640] b320             512 mmcblk1rpmb  (driver?)
  26. [  458.526942] b318            4096 mmcblk1boot1  (driver?)
  27. [  458.532279] b310            4096 mmcblk1boot0  (driver?)
  28. [  458.537637] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
  29. [  458.545915] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
我只喜欢喜欢我的人
132
341
341
2018-7-20
120 小时
 楼主| 发表于 2020-12-4 13:42:51 | 显示全部楼层
起个什么名字好 发表于 2020-12-3 18:53
可能是nfs的配置有问题,可以看下这个帖子https://www.openedv.com/forum.php?mod=viewthread&tid=302907&hi ...
感谢,是bootcmd 和bootargs 没有设置好的原因
  1. setenv bootcmd 'tftp 80800000 zImage; tftp 83000000 imx6ull-alientek-emmc1.dtb; bootz 80800000 - 83000000'
  2. setenv bootargs 'console=ttymxc0,115200 root=/dev/nfs rw nfsroot=192.168.0.109:/home/fang/linux/nfs/rootfs ip=192.168.0.106:192.168.0.109:192.168.0.1:255.255.255.0::eth0:off'
  3. saveenv
我只喜欢喜欢我的人
GMT+8, 2026-10-31 05:37
